32bit additon on the HC08
2,188件の閲覧回数
Bloodhound
Hi all,
I am assuming this is possible?
I need to be able to increment a number by 254 until it reaches
$06000000.
Can anybody please demonstrate in assembler how this might be done?
Ross
2 返答(返信)
1,362件の閲覧回数
Bloodhound
Thanks Peg, makes perfect sense, much appreciated.
Cheers,
Ross
1,362件の閲覧回数
peg
Senior Contributor IV
Hi Ross,
Anything can be done, it just a matter of how much code is required.
here is a full programme that will run in GP32 simulator.
Code:
 org $40num rmb 4  ;4 bytes of storage org $8000start clr num  ;clear storage clr num+1 clr num+2 clr num+3 loop lda num+3 sta $FFFF  ;reset COP add #$FE  ;add 254 sta num+3 bcc loop inc num+2 bne loop inc num+1 bne loop inc num lda num  ;test MSByte cmp #6  ;for $06 bne loop  ;loop back if not equalend sta $FFFF  ;reset COP bra end  ;loop here when finished org $FFFE  ;reset vector dw start
