Services performed by FREESCALE in this matter are performed AS IS and without any warranty.
CUSTOMER retains the final decision relative to the total design and functionality of the end product.
FREESCALE neither guarantees nor will be held liable by CUSTOMER for the success of this project.
FREESCALE disclaims all warranties, express, implied or statutory including, but not limited to,
implied warranty of merchantability or fitness for a particular purpose on any hardware, software
ore advise supplied to the project by FREESCALE, and or any product resulting from FREESCALE services.
In no event shall FREESCALE be liable for incidental or consequential damages arising out of
this agreement. CUSTOMER agrees to hold FREESCALE harmless against any and all claims demands or
actions by anyone on account of any damage,or injury, whether commercial, contractual, or
tortuous, rising directly or indirectly as a result of the advise or assistance supplied CUSTOMER
in connection with product, services or goods supplied under this Agreement.
Hello all.
I would like to share a couple of example projects for some S08 devices for EEPROM emulation on the regular Flash memory. Some of the projects are for CodeWarrior v6.3 (Classic), and others are for CodeWarrior v10.x (Eclipse).
The attached document TN228 explains how to run part of the code in RAM, as devices with single Flash array must run from RAM when erasing or programming, so, you could use it as reference.
Application Note AN3822 explains the implementation on Dual Flash array devices; this document is available at the following link:
www.freescale.com/files/microcontrollers/doc/app_note/AN3822.pdf
Hope this will be useful for you.
Best regards!
/Carlos
I have been looking at the ProcessorExpert Flash component. Is there any reason why I can not use the IFsh1 component and set the write method to
"Destructive Write (with erase)"?
It appears to be a very simple solution - so what's the catch?
