i.MX RT1020, when will be available ?
luishs
Senior Contributor I
Hello
Does anyone know when the i.MX RT1020 will be available?
arimendes
Joan,
  When the I.MX RT1020 datasheet will be available?
  And when the MIMXRT1020-EVK will be available also?
  Ari.
luishs
Hello
Any news about the availability of samples, will be in early March or the end of the month?
I am really very interested in this powerful microcontroller, I want to make a small evaluation board with some samples to test it in my designs, probably to replace the Kinetis MK66 with the RT1020.
I also see that these are much cheaper than the Kinetis, being much more powerful.. Hopefully there is stock and it does not happen as with the Kinetis that are always out of stock.
robertlouis
Thanks Joan for the accurate information you provided...
Looking to the vendors sites, the i.MX RT1020 is now pre-orderable, under the following references:
      - MIMXRT1021CAF4A for the LQFP100, and
      - MIMXRT1021DAG5A for the LQFP144
https://www.digikey.ca/product-detail/en/nxp-usa-inc/MIMXRT1021CAF4A/MIMXRT1021CAF4A-ND/8135063
https://www.avnet.com/shop/us/products/nxp/mimxrt1021daf5a-3074457345634258699/
Also, the corresponding Evaluation kit is annunced under the reference MIMXRT1020-EVK.
Is there any way now to have the related datasheet ? The EVK design files ?
Thanks.
joanxie
yes should be use MCUExpresso. for detailed ording information, you need to contact local DFAE.
