How to root android 6.0 in sabresd imx6qp board
俊宝胡
Hi all,
i build  android  image with follow command:
lunch sabresd_6dq-userdebug
we are trying to copy the file to /system/etc/firmware/   use below command:
mount -o remount -w /system
and the output was as follows:
 Buffer I/O error on dev dm-0, logical block 0, lost sync page write
 EXT4-fs (dm-0): re-mounted. Opts: (null)
I think I failed the root board.
could anyone tell me how to solve the problem ?
Every help is very appreciated
BiyongSUN
In the NXP BSP document, we have filed the Android notes into Android_User's_Guide.pdf, which is knowleadge of Android.
