Can I flash the MPC5602P over flexcan?
1,425件の閲覧回数
martinmarmsoler
Is ther a possibility to programm the MPC5602P over flexcan?
1,191件の閲覧回数
lukaszadrapa
there are two options - flash resident bootloader or serial boot using BAM module.
In case of flash resident bootloader, you can take a look at my draft of application note:
https://community.freescale.com/servlet/JiveServlet/download/427962-279359/bootloader.zip
It uses UART but I hope this is a nice start point also for CAN version.
Then take a look at BAM chapter in reference manual for MPC5602P and also check this application note:
http://www.freescale.com/files/microcontrollers/doc/app_note/AN4674.pdf
Lukas
