Hi to all
I'm try to use in the K70 the CAN0 and CAN1 connected to two different Can Bus.
If I configure only 1 of this, it's work good but if I configure this, the result of second "flexcan_init" is error 1040.
it's not important which CAN is configured like second....it's doesn't work.
this is my code :
uint32_t u32_error = 0;
uint32_t u32_bitrate_get = 0;
uint32_t rx_fifo_id[8];
/* Set CAN1 device parameters */
instance = CAN_1;
flexcan1_data.num_mb = 16;
flexcan1_data.max_num_mb = 16;
flexcan1_data.num_id_filters = kFlexCanRxFifoIDFilters_8;
flexcan1_data.is_rx_fifo_needed = FALSE;
flexcan1_data.is_rx_mb_needed = TRUE;
/* Set rx code status params */
rx_cs1.code = kFlexCanRX_Ranswer;
rx_cs1.msg_id_type = kFlexCanMbId_Std;
rx_cs1.data_length = 1;
rx_cs1.substitute_remote = 0;
rx_cs1.remote_transmission = 0;
rx_cs1.local_priority_enable = 0;
rx_cs1.local_priority_val = 0;
id_table.is_extended_mb = 0;
id_table.is_remote_mb = 0;
id_table.id_filter = rx_fifo_id;
/* Init CAN device */
u32_error = flexcan_init(instance, &flexcan1_data, FALSE);
if (u32_error){
return u32_error;
/* Set CAN bitrate */
u32_error = flexcan_set_bitrate(instance, 1000000);
if (u32_error){
return u32_error;
/* Get CAN bitrate */
u32_error = flexcan_get_bitrate(instance, &u32_bitrate_get);
if (u32_error){
return u32_error;
/* Set mask type */
u32_error = flexcan_set_mask_type(instance, kFlexCanRxMask_Global);
if (u32_error){
return u32_error;
/* Set CAN rx fifo and mailbox mask */
if (flexcan1_data.is_rx_fifo_needed) {
u32_error = flexcan_set_rx_fifo_global_mask(instance, kFlexCanMbId_Std, 0x7FF);
if (u32_error){
return u32_error;
if (flexcan1_data.is_rx_mb_needed) {
u32_error = flexcan_set_rx_mb_global_mask(instance, kFlexCanMbId_Std, u32_MyAddressCan);
if (u32_error){
return u32_error;
/* Configure CAN rx resources for selected instance */
if (flexcan1_data.is_rx_fifo_needed){
u32_error = flexcan_rx_fifo_config(instance, &flexcan1_data, kFlexCanRxFifoIdElementFormat_A, &id_table);
if (u32_error){
return u32_error;
/* Set CAN0 device parameters */
instance = CAN_0;
flexcan0_data.num_mb = 16;
flexcan0_data.max_num_mb = 16;
flexcan0_data.num_id_filters = kFlexCanRxFifoIDFilters_8;
flexcan0_data.is_rx_fifo_needed = FALSE;
flexcan0_data.is_rx_mb_needed = TRUE;
rx_cs0.code = kFlexCanRX_Ranswer;
rx_cs0.msg_id_type = kFlexCanMbId_Std;
rx_cs0.data_length = 1;
rx_cs0.substitute_remote = 0;
rx_cs0.remote_transmission = 0;
rx_cs0.local_priority_enable = 0;
rx_cs0.local_priority_val = 0;
u32_error = flexcan_init(instance, &flexcan0_data, FALSE); // <----- ERROR ----- u32_error exit with value 1040
if (u32_error){
return u32_error;
if (u32_error){
return u32_error;
if (u32_error){
return u32_error;
/* Set mask type */
if (u32_error){
return u32_error;
if (flexcan0_data.is_rx_fifo_needed) {
if (u32_error){
return u32_error;
if (flexcan0_data.is_rx_mb_needed) {
if (u32_error){
return u32_error;
if (flexcan0_data.is_rx_fifo_needed){
u32_error = flexcan_rx_fifo_config(instance, &flexcan0_data, kFlexCanRxFifoIdElementFormat_A, &id_table);
if (u32_error){
return u32_error;
I'm using MQX 3.9
thanks.
gianfranco
