How to write RootFS into QuadSPI-NOR via MFGTool in i.MX6SX
erickang
Dear All,
I have a question how to write RootFS into QuadSPI-NOR via MFGTool.
My development environment is like as below,
- AP : i.MX6SX
- Board type : i.MX6SX-SDB
- Linux version : Linux 3.10.53
- Storage : QuadSPI-NOR
In this case, I could confirm the operation of u-boot, kernel and DTB.
But I couldn't find how to write RootFS into QuadSPI-NOR via MFGTool.
I think Partitioning and Writing method will be needed to write RootFS into QuadSPI-NOR.
Could you tell me how to write RootFS into QuadSPI-NOR via MFGTool?
Eric.
Labels (3)
jimmychan
I think the NOR is /dev/mtd0. You can take mksdcard-android.sh.tar for reference how to create the partition. or you can try to use fdisk command.
Then use 'mount' command to mount the NOR to a folder.
Then use 'tar' command to extract the rootfs to the NOR.
