YuriMuhin_ng
Hi Yuri,
The document helped , thanks a lot for that ...
I now know the registers that can be used to handle the tamper functionality.
But the problem is that , quite some registers are marked "Privileged Write access" .... They say that, only privileged software can write to these registers .... but i didn't quite get as to what is meant by privileged software ....
Can you pls point me to what could the document mean by privileged software .... ?? i.e. how can I get an access to these privileged registers ... ??
Thanks in advance !!
