about i.MX6 wm8962's mic bias
liangyu
Board:i.MX6Q EVK
Audio Codec Chip:wm8962
When I run Linux version on i.MX6Q,and I record file from MIC-Jack,no voice.And I check the EVK,found it no Mic Bias Voltage.How to Setup?
When I run Android version on i.MX6Q,have this Mic Bios Level
Labels (3)
karina_valencia
NXP Apps Support
NXP Apps Support
Employee
Hi Dan wang
    For recording, user need to set the some parameters through amixer.  please try below command.
amixer cset numid=10,iface=MIXER,name='Capture Switch' on
amixer sset 'Capture' 100
amixer sset 'INPGAR IN3R' on
amixer sset 'MIXINR IN3R' on
eugenephua
Hi Karina,
Could you show me how to connect an electret microphone to the MIC IN jack?
I tried shorting the MIC BIAS and MIC IN connections but there is no voice recorded, thanks!
karina_valencia
NXP Apps Support
NXP Apps Support
Employee
Hi Dan wang
