USB wifi dongle on imx28 with Linux
samuelsalas
Who had installed a USB/Wifi client dongle on imx28/Linux 2.6.35 and which one?
Labels (2)
samuelsalas
thank you for your proposals. The main problem is the temperature range. We need -1 / +70°C at least. Both solutions (Atheros and Whiznets) don't fulifill our temperature requirement.
I tried to compile Sparklan driver for 2 USB dongles (WUBR608GN and WUBR170GN) with no success.
So if any more proposal let me know.
Sam
vedad
Check WHZ7188. it will work on iMX28 over Linux 2.6.35.
SergioSolis
Hello Samuel,
You can try with an Atheros wifi card, the driver is the generic one in Linux kernel 2.6.x , so you shouldn't have problems using an Atheros one.
Please let me know if you have any questions.
