Example MPC5604P FlexPWM Initialization on TRK board
This simple example shows usage of the FlexPWM module on the TRK board.
If a PWM output is connected to the LED you can see its dimming.
Petr
* Detailed Description:
* This example shows usage of FlexPWM module.
* The Submodule0 is set to generate independent PWMA and PWMB signals and vary
* its duty cycles. The PWMX is also enabled as output and is set for fixed 50%
* duty.
* You can remove LED_EN jumpers and connect FlexPWM A an B outputs to LEDs to see
* its dimming.
* Test HW: TRK-MPC5604P
* Maskset:  0M36W
* Target : internal_RAM
* Terminal: no
* Fsys:     64 MHz with 8 MHz XOSC reference
* Debugger: IDCPPCNEXUS
* TRK board connection:
* P4.10 - D[9]  .. FlexPWM X[0] output
* P1.11 - A[10] .. FlexPWM B[0] output
* P1.12 - A[11] .. FlexPWM A[0] output
Comments
%3CLINGO-SUB%20id%3D%22lingo-sub-1116831%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EExample%20MPC5604P%20FlexPWM%20Initialization%20on%20TRK%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116831%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20simple%20example%20shows%20usage%20of%20the%20FlexPWM%20module%20on%20the%20TRK%20board.%3C%2FP%3E%3CP%3EIf%20a%20PWM%20output%20is%20connected%20to%20the%20LED%20you%20can%20see%20its%20dimming.%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3EPetr%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20Detailed%20Description%3A%20%3C%2FP%3E%3CP%3E*%20%3C%2FP%3E%3CP%3E*%20This%20example%20shows%20usage%20of%20FlexPWM%20module.%3C%2FP%3E%3CP%3E*%20The%20Submodule0%20is%20set%20to%20generate%20independent%20PWMA%20and%20PWMB%20signals%20and%20vary%3C%2FP%3E%3CP%3E*%20its%20duty%20cycles.%20The%20PWMX%20is%20also%20enabled%20as%20output%20and%20is%20set%20for%20fixed%2050%25%20%3C%2FP%3E%3CP%3E*%20duty.%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E*%20You%20can%20remove%20LED_EN%20jumpers%20and%20connect%20FlexPWM%20A%20an%20B%20outputs%20to%20LEDs%20to%20see%20%3C%2FP%3E%3CP%3E*%20its%20dimming.%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20Test%20HW%3A%20TRK-MPC5604P%3C%2FP%3E%3CP%3E*%20Maskset%3A%26nbsp%3B%200M36W%3C%2FP%3E%3CP%3E*%20Target%20%3A%20internal_RAM%3C%2FP%3E%3CP%3E*%20Terminal%3A%20no%3C%2FP%3E%3CP%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2064%20MHz%20with%208%20MHz%20XOSC%20reference%3C%2FP%3E%3CP%3E*%20Debugger%3A%20IDCPPCNEXUS%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20TRK%20board%20connection%3A%20%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20P4.10%20-%20D%5B9%5D%26nbsp%3B%20..%20FlexPWM%20X%5B0%5D%20output%3C%2FP%3E%3CP%3E*%20P1.11%20-%20A%5B10%5D%20..%20FlexPWM%20B%5B0%5D%20output%20%3C%2FP%3E%3CP%3E*%20P1.12%20-%20A%5B11%5D%20..%20FlexPWM%20A%5B0%5D%20output%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E********************************************************************************%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1116831%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGeneral%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
100% helpful (1/1)
Version history
Last update:
‎02-27-2014 12:26 AM
Updated by:
