Adding keil support for KINETIS_SC
Document created by Kan_Li Employee on Oct 11, 2013Last modified by Adrian Puga Candelario on Jan 21, 2020
Version 4Show Document
  • View in full screen mode
My customer wanted to use K60 in his design but he only has the Keil IDE, so I helped to port some examples in KINETIS_SC for him as a starting point. The attachment is my porting work, which also includes a exe file to create new keil project. You may refer to "keil\build\uv4\make_new_project_keil.exe" for details.
Hope that helps,
B.R
Kan
Outcomes
