Continental Yocto Tutorial / August 2013
Continental Yocto Training
Author:
          Leonardo Sandoval
Material:
PDF Tutorial: i.MX Yocto Project: Freescale Yocto Project Tutorial
Provided Virtual Machine
Wandboard Dual Wandboard - Freescale i.MX6 ARM Cortex-A9 Opensource Community Development Board - BLOG
Tasks:
Task 1: Build and Boot your board in N-steps
    1.    Create a new folder ($ mkdir conti-fsl-community-bsp)
    2.    Follow all N-steps (from the tutorial, page 2) EXCEPT the baking
    3.     Baking has been done for you, so assume that the bake is done!
    4.    Flash:
        conti-fsl-community-bsp $ cd
        $ cd fsl-community-bsp/build
        build $ dd if=tmp/deploy/images/core-image-minimal-wandboard-dual.sdcard of=/dev/sdb bs=1M
        build $ sync # NEVER FORGET THIS STEP, You have been warned!
    5.    Boot
  • Task 2:    Folders
    1. Tree structure & size
        fsl-comunity-bsp $ tree -d -L 2
        fsl-comunity-bsp $ du -h --max-depth=2
  • Task 3:    Architecture
  • Task 4:    Metadata
  • Task 5:    Config files
        build $ cat conf/local.conf
        build $ cat conf/bblayer.conf
  • Task 6:     Layers
build $ bitbake-layers show-layers
sources $ cat meta-fsl-arm/conf/layer.conf
  • Task 7:    Adding an existing layer
    1. Clone the repo
sources $ git clone https://github.com/lsandoval/meta-fsl-test.git
    2. Add the layer to build/bblayers.conf
sources $ cd ../build
build $ vi conf/bblayers.conf
    3. Browse the new layer files
    4. Compile the kernel
build $ bitbake -f -c compile linux-wandboard
build $ bitbake -c deploy linux-wandboard
    5. Flash
   build $ sudo mkdir /media/boot
        build $ sudo mount /dev/sdb1 /media/boot
        build $ cp tmp/deploy/images/uImage /media/boot
        build $ sudo umount /media/boot
    6. Boot
  • Task 8: (Optional)
    • Check the core-image-minimal-test image, bake and flash it.
    • Run the 'helloworld' app
  • Task 9: Q&A
評価なし
バージョン履歴
最終更新日:
‎08-09-2013 11:13 AM
更新者:
