Modified AN2295 UART bootloader for K21 (It's applicable to all Kinetis)
Hi, all
The default AN2295 UART bootloader doesn't work well on K21/other Kinetis because of using FEI and complicated autocalibration mechanism. I made a simple version to make it works on MK21DX128VMC5, FYI.
Readm.txt:
UART bootloader for K21. (Default is MK21DX128VMC5)
128KB_Pflash_64KB_Dflash.icf is application link script example for MK21DX128 used together with UART bootloader, UART bootloader use 0x0 - 0xFFF.
Q: Why need this patch?
A: The original AN2295 use internal RC and FLL output as system clock. The calibration mechanism is not stable. The main change of this patch is to use external cystal plus PLL as system clock to communicate with PC software.
Changes to AN2295
1) Add MK21D5.h for K21 support
2) Add AN2295_TWR_K21_cfg.h for K21 support(Copy from AN2295_TWR_K60_cfg.h)
3) AN2295_TWR_K21_cfg.h
   1> #define KINETIS_MODEL K21_50MHz
   2> #define KINETIS_FLASH FLASH_128K
   3> #define BOOT_UART_BASE UART2_BASE_PTR
      #define BOOT_UART_GPIO_PORT PORTE_BASE_PTR
      #define BOOT_UART_GPIO_PIN_RX   17
      #define BOOT_UART_GPIO_PIN_TX   16
   4> #define BOOT_PIN_ENABLE_NUM        7
4) Add mcg folder and mcg.c/mcg.h
5) kinetis_params.h:
   1> Modify SRS_REG/SRS_POR_MASK/INIT_CLOCKS_TO_MODULES to meet MK21D5.h
   2> Add PORT_PCR_PS_MASK for BOOTLOADER_PIN_ENABLE_INIT to enable Pull-up.
6) bootloader.h: #define BOOT_WAITING_TIMEOUT 500. PC software can't communicate to bootloader if only 1s delay.
7) bootloader.c:
   1> #include "mcg.h"
   2> Use 25MHz PEE:
      SIM_CLKDIV1 = ( 0    | SIM_CLKDIV1_OUTDIV1(1)
                           | SIM_CLKDIV1_OUTDIV2(1)
                           | SIM_CLKDIV1_OUTDIV4(1));
      (void)pll_init(8000000,       /* CLKIN0 frequency */
                     LOW_POWER,     /* Set the oscillator for low power mode */
                     CRYSTAL,       /* Crystal or canned oscillator clock input */
                     4,             /* PLL predivider value */
                     25,            /* PLL multiplier */
                     MCGOUT);       /* Use the output from this PLL as the MCGOUT */
   3> Restore to FEI mode before jump to Application:
      pee_pbe(8000000);
      pbe_fbe(8000000);
      fbe_fei(32768);
Knowing issues:
1) Don't use virtualCOM from OSJTAG, it's very hard to communicate with PC software. Use RS232 in TWR-SER2.
2) BOOTLOADER_CRC_ENABLE must be 0, otherwise PC software will report unknown protocol version
添付
%3CLINGO-SUB%20id%3D%22lingo-sub-1118844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EK21%E7%94%A8%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%9FAN2295%20UART%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC(%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEKinetis%E3%81%AB%E9%81%A9%E7%94%A8%E5%8F%AF%E8%83%BD)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSTRONG%3E%E7%9A%86%E3%81%95%E3%82%93%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AEAN2295%20UART%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%81%AF%E3%80%81FEI%E3%81%A8%E8%A4%87%E9%9B%91%E3%81%AA%E8%87%AA%E5%8B%95%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%A1%E3%82%AB%E3%83%8B%E3%82%BA%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81K21%2F%E4%BB%96%E3%81%AEKineti%E3%81%A7%E3%81%AF%E3%81%86%E3%81%BE%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81MK21DX128VMC5%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E7%B0%A1%E5%8D%98%E3%81%AA%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EReadm.txt%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CEM%3EK21%E7%94%A8%E3%81%AEUART%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%80%82(%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AFMK21DX128VMC5)%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E128KB_Pflash_64KB_Dflash.icf%E3%81%AF%E3%80%81UART%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%80%81UART%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E4%BD%BF%E7%94%A80x0-0xFFF%E3%81%A8%E4%B8%80%E7%B7%92%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8BMK21DX128%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3EQ%3A%20%E3%81%AA%E3%81%9C%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3EA%3A%E3%82%AA%E3%83%AA%E3%82%B8%E3%83%8A%E3%83%AB%E3%81%AEAN2295%E3%81%AF%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A8%E3%81%97%E3%81%A6%E5%86%85%E9%83%A8RC%E3%81%8A%E3%82%88%E3%81%B3FLL%E5%87%BA%E5%8A%9B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%A1%E3%82%AB%E3%83%8B%E3%82%BA%E3%83%A0%E3%81%8C%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E4%B8%BB%E3%81%AA%E5%A4%89%E6%9B%B4%E7%82%B9%E3%81%AF%E3%80%81PC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A8%E9%80%9A%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A8%E3%81%97%E3%81%A6%E5%A4%96%E9%83%A8%E5%9A%A2%E8%83%9E%E3%81%A8PLL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3EAN2295%E3%81%AE%E5%A4%89%E6%9B%B4%E7%82%B9%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E1)%20K21%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E7%94%A8%E3%81%ABMK21D5.h%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E2)%20K21%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E7%94%A8%E3%81%ABAN2295_TWR_K21_cfg.h%E3%82%92%E8%BF%BD%E5%8A%A0(AN2295_TWR_K60_cfg.h%E3%81%8B%E3%82%89%E3%82%B3%E3%83%94%E3%83%BC)%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E3)%20AN2295_TWR_K21_cfg.h%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E1%26gt%3B%20%23define%20KINETIS_MODEL%20K21_50MHz%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E2%26gt%3B%20%23define%20KINETIS_FLASH%20FLASH_128K%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E3%26gt%3B%20%23define%20BOOT_UART_BASE%20UART2_BASE_PTR%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%23define%20BOOT_UART_GPIO_PORT%20PORTE_BASE_PTR%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%23define%20BOOT_UART_GPIO_PIN_RX%2017%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%23define%20BOOT_UART_GPIO_PIN_TX%2016%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E4%26gt%3B%20%23define%20BOOT_PIN_ENABLE_NUM%207%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E4)%20mcg%20%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%A8%20mcg.c%2Fmcg.h%20%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E5)%20kinetis_params.h%3A%20%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E1%26gt%3B%20SRS_REG%2FSRS_POR_MASK%2FINIT_CLOCKS_TO_MODULES%20%E3%82%92%20MK21D5.h%20%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E2%26gt%3B%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81BOOTLOADER_PIN_ENABLE_INIT%E3%81%AEPORT_PCR_PS_MASK%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E6)%20bootloader.h%3A%20%23define%20BOOT_WAITING_TIMEOUT%20500.PC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%811%E7%A7%92%E3%81%AE%E9%81%85%E5%BB%B6%E3%81%A0%E3%81%91%E3%81%A7%E3%81%AF%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%A8%E9%80%9A%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%20%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E7)%20bootloader.c%3A%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E1%26gt%3B%20%23include%E3%80%8Cmcg.h%E3%80%8D%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E2%26gt%3B%2025MHz%20PEE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3ESIM_CLKDIV1%20%3D%20(%200%20%7CSIM_CLKDIV1_OUTDIV1(1)%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%7CSIM_CLKDIV1_OUTDIV2(1)%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%7CSIM_CLKDIV1_OUTDIV4(1))%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E(void)pll_init(8000000%2C%20%2F*%20CLKIN0%20%E5%91%A8%E6%B3%A2%E6%95%B0%20*%2F%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3ELOW_POWER%2C%20%2F*%20%E7%99%BA%E6%8C%AF%E5%99%A8%E3%82%92%E4%BD%8E%E9%9B%BB%E5%8A%9B%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3ECRYSTAL%E3%80%81%2F%20*%E3%82%AF%E3%83%AA%E3%82%B9%E3%82%BF%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E7%BC%B6%E8%A9%B0%E3%81%AE%E7%99%BA%E6%8C%AF%E5%99%A8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%85%A5%E5%8A%9B*%20%2F%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E4%2C%20%2F*%20PLL%E3%83%97%E3%83%AA%E3%83%87%E3%82%A3%E3%83%90%E3%82%A4%E3%83%80%E5%80%A4%20*%2F%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E25%E3%80%81%2F%20*%20PLL%E4%B9%97%E7%AE%97%E5%99%A8%20*%2F%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3EMCGOUT)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20%E3%81%93%E3%81%AE%20PLL%20%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%20MCGOUT%20%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E3%26gt%3B%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%E3%81%99%E3%82%8B%E5%89%8D%E3%81%ABFEI%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%BE%A9%E5%85%83%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3Epee_pbe(8000000)%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3Epbe_fbe(8000000)%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3Efbe_fei(32768)%3B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%E5%95%8F%E9%A1%8C%E3%82%92%E7%9F%A5%E3%82%8B%3A%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E1)OSJTAG%E3%81%AEvirtualCOM%E3%81%AF%E3%80%81PC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A8%E3%81%AE%E9%80%9A%E4%BF%A1%E3%81%8C%E9%9D%9E%E5%B8%B8%E3%81%AB%E9%9B%A3%E3%81%97%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82TWR-SER2%E3%81%A7%E3%81%AFRS232%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E2)%20BOOTLOADER_CRC_ENABLE%200%20%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%820%20%E3%81%AB%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81PC%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E4%B8%8D%E6%98%8E%E3%81%AA%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E5%A0%B1%E5%91%8A%E3%81%97%E3%81%BE%E3%81%99%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1118844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSTRONG%3E%E7%9A%86%E3%81%95%E3%82%93%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AEAN2295%20UART%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%81%AF%E3%80%81FEI%E3%81%A8%E8%A4%87%E9%9B%91%E3%81%AA%E8%87%AA%E5%8B%95%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%A1%E3%82%AB%E3%83%8B%E3%82%BA%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81K21%2F%E4%BB%96%E3%81%AEKineti%E3%81%A7%E3%81%AF%E3%81%86%E3%81%BE%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81MK21DX128VMC5%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E7%B0%A1%E5%8D%98%E3%81%AA%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EReadm.txt%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CEM%3EK21%E7%94%A8%E3%81%AEUART%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%80%82(%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AFMK21DX128VMC5)%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E128KB_Pflash_64KB_Dflash.icf%E3%81%AF%E3%80%81UART%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%80%81UART%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E4%BD%BF%E7%94%A80x0-0xFFF%E3%81%A8%E4%B8%80%E7%B7%92%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8BMK21DX128%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3EQ%3A%20%E3%81%AA%E3%81%9C%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3EA%3A%E3%82%AA%E3%83%AA%E3%82%B8%E3%83%8A%E3%83%AB%E3%81%AEAN2295%E3%81%AF%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A8%E3%81%97%E3%81%A6%E5%86%85%E9%83%A8RC%E3%81%8A%E3%82%88%E3%81%B3FLL%E5%87%BA%E5%8A%9B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%A1%E3%82%AB%E3%83%8B%E3%82%BA%E3%83%A0%E3%81%8C%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E4%B8%BB%E3%81%AA%E5%A4%89%E6%9B%B4%E7%82%B9%E3%81%AF%E3%80%81PC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A8%E9%80%9A%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A8%E3%81%97%E3%81%A6%E5%A4%96%E9%83%A8%E5%9A%A2%E8%83%9E%E3%81%A8PLL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3EAN2295%E3%81%AE%E5%A4%89%E6%9B%B4%E7%82%B9%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E1)%20K21%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E7%94%A8%E3%81%ABMK21D5.h%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E2)%20K21%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E7%94%A8%E3%81%ABAN2295_TWR_K21_cfg.h%E3%82%92%E8%BF%BD%E5%8A%A0(AN2295_TWR_K60_cfg.h%E3%81%8B%E3%82%89%E3%82%B3%E3%83%94%E3%83%BC)%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E3)%20AN2295_TWR_K21_cfg.h%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E1%26gt%3B%20%23define%20KINETIS_MODEL%20K21_50MHz%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E2%26gt%3B%20%23define%20KINETIS_FLASH%20FLASH_128K%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E3%26gt%3B%20%23define%20BOOT_UART_BASE%20UART2_BASE_PTR%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%23define%20BOOT_UART_GPIO_PORT%20PORTE_BASE_PTR%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%23define%20BOOT_UART_GPIO_PIN_RX%2017%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%23define%20BOOT_UART_GPIO_PIN_TX%2016%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E4%26gt%3B%20%23define%20BOOT_PIN_ENABLE_NUM%207%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E4)%20mcg%20%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%A8%20mcg.c%2Fmcg.h%20%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E5)%20kinetis_params.h%3A%20%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E1%26gt%3B%20SRS_REG%2FSRS_POR_MASK%2FINIT_CLOCKS_TO_MODULES%20%E3%82%92%20MK21D5.h%20%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E2%26gt%3B%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81BOOTLOADER_PIN_ENABLE_INIT%E3%81%AEPORT_PCR_PS_MASK%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E6)%20bootloader.h%3A%20%23define%20BOOT_WAITING_TIMEOUT%20500.PC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%811%E7%A7%92%E3%81%AE%E9%81%85%E5%BB%B6%E3%81%A0%E3%81%91%E3%81%A7%E3%81%AF%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%A8%E9%80%9A%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%20%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E7)%20bootloader.c%3A%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E1%26gt%3B%20%23include%E3%80%8Cmcg.h%E3%80%8D%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E2%26gt%3B%2025MHz%20PEE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3ESIM_CLKDIV1%20%3D%20(%200%20%7CSIM_CLKDIV1_OUTDIV1(1)%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%7CSIM_CLKDIV1_OUTDIV2(1)%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%7CSIM_CLKDIV1_OUTDIV4(1))%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E(void)pll_init(8000000%2C%20%2F*%20CLKIN0%20%E5%91%A8%E6%B3%A2%E6%95%B0%20*%2F%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3ELOW_POWER%2C%20%2F*%20%E7%99%BA%E6%8C%AF%E5%99%A8%E3%82%92%E4%BD%8E%E9%9B%BB%E5%8A%9B%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3ECRYSTAL%E3%80%81%2F%20*%E3%82%AF%E3%83%AA%E3%82%B9%E3%82%BF%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E7%BC%B6%E8%A9%B0%E3%81%AE%E7%99%BA%E6%8C%AF%E5%99%A8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%85%A5%E5%8A%9B*%20%2F%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E4%2C%20%2F*%20PLL%E3%83%97%E3%83%AA%E3%83%87%E3%82%A3%E3%83%90%E3%82%A4%E3%83%80%E5%80%A4%20*%2F%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E25%E3%80%81%2F%20*%20PLL%E4%B9%97%E7%AE%97%E5%99%A8%20*%2F%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3EMCGOUT)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20%E3%81%93%E3%81%AE%20PLL%20%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%20MCGOUT%20%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E3%26gt%3B%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%E3%81%99%E3%82%8B%E5%89%8D%E3%81%ABFEI%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%BE%A9%E5%85%83%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3Epee_pbe(8000000)%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3Epbe_fbe(8000000)%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3Efbe_fei(32768)%3B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%E5%95%8F%E9%A1%8C%E3%82%92%E7%9F%A5%E3%82%8B%3A%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E1)OSJTAG%E3%81%AEvirtualCOM%E3%81%AF%E3%80%81PC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A8%E3%81%AE%E9%80%9A%E4%BF%A1%E3%81%8C%E9%9D%9E%E5%B8%B8%E3%81%AB%E9%9B%A3%E3%81%97%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82TWR-SER2%E3%81%A7%E3%81%AFRS232%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E2)%20BOOTLOADER_CRC_ENABLE%200%20%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%820%20%E3%81%AB%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81PC%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E4%B8%8D%E6%98%8E%E3%81%AA%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E5%A0%B1%E5%91%8A%E3%81%97%E3%81%BE%E3%81%99%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%3C%2FLINGO-TEASER%3E
評価なし
バージョン履歴
最終更新日:
‎06-27-2013 07:45 PM
更新者:
