lmbench $ cd src
lmbench/src $ make results
lmbench/src $ cd ..
lmbench $ make see
Attached are the benchmarks results from several machines. In case you run them in a different machine, please attach your results file on this document. For more robust results, rerun several times the test and create the result document following these steps:
lmbench $ make results
lmbench $ make rerun
lmbench $ cd results
lmbench/results $ make > results # results is the output file you may want to attach to this document
