Processor Expert Tools in Microcontroller Driver Suite - Training Videos
Document created by -nilda Employee on Sep 28, 2012
Version 1Show Document
  • View in full screen mode
Training Videos
Processor Expert - Introduction (Driver Suite)
(Video 04:01) - Learn the Processor Expert UI, what components are, and how to add one to a project..
Processor Expert: Working with Components (Driver Suite)
(Video 03:53) - Using Microcontroller Driver Suite, learn how to add, configure, and remove a component, and how to generate code.
Processor Expert: The Code Model (Driver Suite)
(Video 04:45) - Using Microcontroller Driver Suite, learn the answers to the questions: What code does Processor Expert generate? Where does it put the code? And how do I use it?
Processor Expert: Creating an MQX Lite Project (Driver Suite)
(Video 05:15) - Using Microcontroller Driver Suite, learn how to create an MQX Lite component from scratch. You'll also learn where Processor Expert puts the task functions and the RTOS code itself.
Processor Expert: An MQX Lite Example (Driver Suite)
(Video 04:39) - See how a full MQX Lite application works, how the tasks are implemented, and how they interact with other components in Microcontroller Driver Suite.
Processor Expert: Exporting and Importing Templates (Driver Suite)
(Video 03:56) - Learn how to export and import a file that can completely configure and generate the code required for an arbitrarily complex hardware and software system with Microcontroller Driver Suite.
Processor Expert: Integrating with IAR Embedded
(Video 06:22) - Learn how to incorporate Processor Expert's generated code into an IAR Embedded Workbench project.
Processor Expert: Integrating with Keil Microvision
(Video 04:54) - Learn how to incorporate Processor Expert's generated code into a Keil Microvision project.
    Outcomes
