ADAS & Driver Replacement: S32 Configuration Tools Supporting the Next-Generation of S32 Products
S32 Design Studio 3.0 S32V234 focus on configuration tools pin wizard, clocks config, with SDK configuration, FreeRTOS configuration and use building and running a project showing debug with S32 debugger on the m4 with code on target. Configuration tools suite formed from pins, clocks, peripherals, DCD, IVT are offering a complete view of the platform with complete access to all the details directly from the tool and possibility to generate, build and debug the applications.
No ratings
Version history
Last update:
‎10-14-2019 02:22 PM
Updated by:
