LS1088ARDB/LS1088ARDB-PB - How to update composite firmware image in QSPI NOR flash
Follow these steps to update the composite firmware image in QSPI NOR flash.
qixis_reset boots the board from QSPI NOR flash0 and qixis_reset altbank boots the board from QSPI NOR flash1.
sf probe 0:1 means that the alternate bank will be written to. So, if the board boots from QSPI NOR flash0 and sf probe 0:1 is entered at the U-Boot prompt, the commands that follow will program QSPI NOR flash1.
Obtaining composite firmware image
LSDK includes pre-built firmware images for QSPI NOR flash. The LSDK composite firmware includes RCW+PBI, boot loader firmware, DPAA1 FMan ucode, QE/uQE firmware, Ethernet PHY firmware, DPAA2 MC firmware, DPAA2 DPL, DPAA2 DPC, device tree, and lsdk_linux_<arch>.itb images.
Refer the Layerscape Software Development Kit <version> Documention for the complete flash memory layout of the images.
 On a Linux host machine, download composite firmware image from nxp.com.
$ wget http://www.nxp.com/lgfiles/sdk/lsdk<lsdk_version>/firmware_<RDB_name>_uboot_qspiboot.img
For example:
For LS1088ARDB:
$ wget http://www.nxp.com/lgfiles/sdk/lsdk1809/firmware_ls1088ardb_uboot_qspiboot.img
For LS1088ARDB-PB:
$ wget https://www.nxp.com/lgfiles/sdk/lsdk1809/firmware_ls1088ardb_pb_uboot_qspiboot.img
Flashing composite firmware images to QSPI NOR flash
  1. Boot LS1088ARDB/LS1088ARDB-PB from QSPI. Ensure that the switches are set to boot the board from QSPI. For booting from QSPI , SW1[1:8] + SW2[1] = 0011_0001_X
  2. Boot from QSPI NOR flash0: => qixis_reset
    For LS1088ARDB, in boot log, you’ll see:
    Board: LS1088A-RDB, Board Arch: V1, Board version: C, boot from QSPI:0
    For LS1088ARDB-PB, in boot log, you'll see:
    Board: LS1088ARDB-PB, Board Arch: V1, Board version: A, boot from QSPI:0
Composite firmware image can be loaded to the LS1088ARDB/LS1088ARDB from a TFTP server or from a mass storage device (SD, USB, or SATA).
Option 1: Load image from the TFTP server
Set up Ethernet connection
When board boots up, U-Boot prints a list of enabled Ethernet interfaces.
DPMAC1@xgmii, DPMAC2@xgmii, DPMAC3@qsgmii, DPMAC4@qsgmii, DPMAC5@qsgmii, DPMAC6@qsgmii, DPMAC7@qsgmii, DPMAC8@qsgmii, DPMAC9@qsgmii, DPMAC10@qsgmii
  1. Set server IP address to the IP address of the host machine on which you have configured the TFTP server.
    => setenv serverip <ipaddress1>
  2. Set ethact and ethprime as the ethernet interface connected to the TFTP server.
    See LS1088ARDB/LS1088RDB-PB Ethernet port mapping for the mapping of Ethernet port names appearing on the chassis front panel with the port names in U-Boot and Linux.
    => setenv ethprime <name of interface connected to TFTP server>
    For example:
    => setenv ethprime DPMAC3@qsgmii
    => setenv ethact <name of interface connected to TFTP server>
    For example:
    => setenv ethact DPMAC3@qsgmii
  3. Set IP address of the board. You can set a static IP address or, if the board can connect to a dhcp server, you can use the dhcp command.
    Static IP address assignment:
    => setenv ipaddr <ipaddress2>
    => setenv netmask <subnet mask>
    Dynamic IP address assignment:
    => dhcp
  4. Save the settings. => saveenv
  5. Check the connection between the board and the TFTP server.
=> ping $serverip
Using DPMAC3@qsgmii device
host 192.168.1.1 is alive
Load U-Boot image from the TFTP server
  1. Program QSPI NOR flash1: => sf probe 0:1
  2. Flash LS1088ARDB or LS1088ARDB-PB composite firmware image:
    • For LS1088ARDB:
      1. => tftp 0xa0000000 firmware_ls1088ardb_uboot_qspiboot.img
      2. => print filesize
        filesize=2351db0
    • For LS1088ARDB-PB:
      1. => tftp 0xa0000000 firmware_ls1088ardb_pb_uboot_qspiboot.img
        filesize=2351db0
  3. Program composite firmware image to QSPI NOR flash: => sf erase 0x0 +$filesize && sf write 0xa0000000 0x0 $filesize
  4. Boot from QSPI NOR flash1: => qixis_reset altbank
    Board: LS1088A-RDB, Board Arch: V1, Board version: C, boot from QSPI:1
    Board: LS1088ARDB-PB, Board Arch: V1, Board version: A, boot from QSPI:1
    Ensure that SD card, USB flash drive, or SCSI hard disk installed with LSDK Ubuntu distribution is plugged into the board to boot the board to Ubuntu. If U-Boot does not find LSDK on a mass storage device, it will boot TinyDistro from lsdk_linux_arm64_ tiny.itb stored in QSPI NOR flash.
Option 2: Load image from partition on mass storage device (SD, USB, or SATA)
  1. Select mass storage device to use.
    => mmc rescan
    => mmc info
    Or
    => usb start
    => usb info
    Or
    => scsi scan
    => scsi info
  2. Optional – List files on storage device
    => ls mmc <device:partition>
    For example:
    => ls mmc 0:2
    Or
    => ls usb <device:partition>
    For example:
    => ls usb 0:1
    Or
    => ls scsi <device:partition>
    For example:
    => ls scsi 0:2
  3. Program QSPI NOR flash1: => sf probe 0:1
  4. Load composite firmware image from the storage device
    => load mmc 0:2 a0000000 <image name>
    => print filesize
    For example, for LS1088ARDB:
    => load mmc 0:2 a0000000 firmware_ls1088ardb_uboot_qspiboot.img
    => print filesize
    filesize=235bd40
    For example, for LS1088ARDB-PB:
    => load mmc 0:2 a0000000 firmware_ls1088ardb_pb_uboot_qspiboot.img
    => print filesize
    filesize=2351db0
    Or
    => load usb 0:2 a0000000 <image name>
    => print filesize
    Or
    => load scsi 0:2 a0000000 <image name>
    => print filesize
  5. Program image to QSPI NOR flash: => sf erase 0x0 +$filesize && sf write 0xa0000000 0x0 $filesize
  6.  Boot from QSPI NOR flash1: => qixis_reset altbank
    In boot log, you’ll see:
No ratings
Version history
Last update:
‎09-10-2020 01:50 AM
Updated by:
