Interfacing Solutions – Designing with NXP Analog Switches, High-Speed Switches, Voltage Translators and GPIO Expanders
In automotive sub-system applications, it is typical to have a central processing unit that interfaces with other peripheral devices, other sub-systems or the user. Often, the signals from these interconnects may be incompatible on both ends. Therefore, various semiconductor devices such as analog switches, high-speed switches, voltage level translators and GPIO expanders are often used to bridge between the interconnects on the board. In this session, we will explore the application of these interface devices from NXP and discuss their applications in automotive sub-systems.
%3CLINGO-SUB%20id%3D%22lingo-sub-1120147%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EInterfacing%20Solutions%20%E2%80%93%20Designing%20with%20NXP%20Analog%20Switches%2C%20High-Speed%20Switches%2C%20Voltage%20Translators%20and%20GPIO%20Expanders%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120147%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIn%20automotive%20sub-system%20applications%2C%20it%20is%20typical%20to%20have%20a%20central%20processing%20unit%20that%20interfaces%20with%20other%20peripheral%20devices%2C%20other%20sub-systems%20or%20the%20user.%20Often%2C%20the%20signals%20from%20these%20interconnects%20may%20be%20incompatible%20on%20both%20ends.%20Therefore%2C%20various%20semiconductor%20devices%20such%20as%20analog%20switches%2C%20high-speed%20switches%2C%20voltage%20level%20translators%20and%20GPIO%20expanders%20are%20often%20used%20to%20bridge%20between%20the%20interconnects%20on%20the%20board.%20In%20this%20session%2C%20we%20will%20explore%20the%20application%20of%20these%20interface%20devices%20from%20NXP%20and%20discuss%20their%20applications%20in%20automotive%20sub-systems.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1120147%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIn%20automotive%20sub-system%20applications%2C%20it%20is%20typical%20to%20have%20a%20central%20processing%20unit%20that%20interfaces%20with%20other%20peripheral%20devices%2C%20other%20sub-systems%20or%20the%20user.%20Often%2C%20the%20signals%20from%20these%20interconnects%20may%20be%20incompatible%20on%20both%20ends.%20Therefore%2C%20various%20semiconductor%20devices%20such%20as%20analog%20switches%2C%20high-speed%20switches%2C%20voltage%20level%20translators%20and%20GPIO%20expanders%20are%20often%20used%20to%20bridge%20between%20the%20interconnects%20on%20the%20board.%20In%20this%20session%2C%20we%20will%20explore%20the%20application%20of%20these%20interface%20devices%20from%20NXP%20and%20discuss%20their%20applications%20in%20automotive%20sub-systems.%3C%2FP%3E%3C%2FLINGO-TEASER%3E
No ratings
Version history
Last update:
‎10-22-2018 04:40 PM
Updated by:
