Power Distribution Made Easy: Case Studies
Full power helm! A new way to design your power system, focused on the “Plumbing”! A simple EM physics and geometry based approach to designing power distribution networks on PCBs. From input power connection to the IC die, the simple rules discussed can be used to reduce power supply noise and improve EMC. Examples with results will be discussed.
%3CLINGO-SUB%20id%3D%22lingo-sub-1107410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPower%20Distribution%20Made%20Easy%3A%20Case%20Studies%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1107410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFull%20power%20helm!%20A%20new%20way%20to%20design%20your%20power%20system%2C%20focused%20on%20the%20%E2%80%9CPlumbing%E2%80%9D!%20A%20simple%20EM%20physics%20and%20geometry%20based%20approach%20to%20designing%20power%20distribution%20networks%20on%20PCBs.%20From%20input%20power%20connection%20to%20the%20IC%20die%2C%20the%20simple%20rules%20discussed%20can%20be%20used%20to%20reduce%20power%20supply%20noise%20and%20improve%20EMC.%20Examples%20with%20results%20will%20be%20discussed.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1107410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFull%20power%20helm!%20A%20new%20way%20to%20design%20your%20power%20system%2C%20focused%20on%20the%20%E2%80%9CPlumbing%E2%80%9D!%20A%20simple%20EM%20physics%20and%20geometry%20based%20approach%20to%20designing%20power%20distribution%20networks%20on%20PCBs.%20From%20input%20power%20connection%20to%20the%20IC%20die%2C%20the%20simple%20rules%20discussed%20can%20be%20used%20to%20reduce%20power%20supply%20noise%20and%20improve%20EMC.%20Examples%20with%20results%20will%20be%20discussed.%3C%2FP%3E%3C%2FLINGO-TEASER%3E
No ratings
Version history
Last update:
‎10-22-2018 04:37 PM
Updated by:
