List of MagniV and S12(X) Application notes
AN12086 Simple Serial Bootloader for S12Z AN12086 SW
AN5330 Migration Guide for S12ZVM Devices AN5330
AN5327 Three-phase Sensorless Single-Shunt Current-Sensing PMSM Motor Control Application with MagniV MC9S12ZVM AN5327
AN5264 Emulating I2C Master Mode AN5264 SW
AN5207 Hardware Design Guidelines for S12ZVM Microcontrollers AN5207
AN5190 S12ZVM Derivatives Configuring PMF Module AN5190 SW
AN5168 Using the ADC Module in S12ZVM AN5168 SW
AN5135 3-phase Sensorless PMSM Motor Control Kit with MagniV MC9S12ZVM AN5135
AN5122 Using Freescale’s LIN Driver with the MagniV Family AN5122 SW
AN5084 Hardware Design Guidelines for S12ZVL Microcontrollers AN5084
AN5082 MagniV in 24V Applications AN5082
AN4975 Using MSCAN on the MagniV Family AN4975 SW
AN4912 Tuning 3-Phase PMSM Sensorless Control Application Using MCAT Tool AN4912
AN4867 Hardware Design Guide lines for S12ZVC AN4867
AN4852 Using the SENT Transmitter Module in S12ZVC Devices AN4852 SW
AN4842 S12ZVL LIN Enabled RGB LED Lighting Application AN4842 SW
AN4841 S12ZVL LIN Enabled Ultrasonic Distance Measurement AN4841 SW
AN4731 Understanding Injection Current on Freescale Automotive Microcontrollers AN4731
AN4723 S12Z MagniV Bootloader AN4723 SW
AN4722 Real Time Counter (RTC) on the S12ZVH Family AN4722
AN4721 S12ZVH: Hardware Design Guidelines AN4721
AN4718 3-Phase BLDC Hall Sensor Application Using S12ZVM AN4718 SW
AN4704 3-phase Sensorless BLDC Motor Control Kit with the S12 MagniV MC9S12ZVM AN4704
AN4680 PMSM Electrical Parameters Measurement AN4680
AN4643 S12VR - Hardware Design Guidelines AN4643
AN4642 Motor Control Application Tuning (MCAT) Tool for 3-Phase PMSM AN4642
AN4618 Sensorless BLDC Motor Control Using S12G240 Based on HVAC Platform AN4618
AN4617 HMI Design Using HVAC Platform AN4617
AN4616 Flap Motor Control Based On HVAC Platform AN4616
AN4558 3-phase Sensorless BLDC Motor Control Development Kit with MC9S12G128 MCU AN4558 SW
AN4540 Comparison Between the MC9S12VR and MM912_634 AN4540
AN4506 Software Analysis in CodeWarrior for MCU AN4506
AN4505 Safety Considerations S12G-Family AN4505
AN4483 Emulated EEPROM Routines for the S12P Family AN4483 SW
AN4455 MC9S12G128_A240 Demonstration Lab Training AN4455 SW
AN4448 MC9S12VR Family Demonstration Lab Training AN4448 SW
AN4418 MC9S12G64 Demonstration Lab Training AN4418 SW
AN4388 Quad Flat Package (QFP) AN4388
AN4364 Glucose Meter Fundamentals and Design AN4364 SW
AN4320 Introduction to the 16-bit Tower Boards Using the MC9S12GN32 AN4320
AN4303 Light control and diagnostics using a MC9S12GN32 MCU AN4303 SW
AN4302 Introduction to the S12G Family EEPROM AN4302 SW
AN4283 Migrating Software Applications from the S12 (XEXSP) and S08 to S12G Microcontrollers AN4283
AN4268 Three-phase Sensorless BLDC Motor Control Kit with the Qorivva MPC5604P AN4268
AN4263 Modification of the eGUI (D4D) Driver for char Displays (D4CD) AN4263 SW
AN4258 Serial Bootloader for S12(X) Microcontrollers Based on 180 nm Technology AN4258 SW
AN4236 MC9S12XHY-Family Demonstration Lab Training AN4236 SW
AN4143 Migrating from the 16-bit S12XE to 32-bit MPC5604B Family of Microcontrollers AN4143
AN4058 BLDC Motor Control with Hall Effect Sensors Using the 9S08MP AN4058
AN4024 High Speed Stall Detection on the S12HY Family AN4024 SW
AN4021 MC9S12HY-Family Demonstration Lab Training AN4021 SW
AN3961 EEPROM Emulation for the MC9S12XS and MC9S12P Families Using AN2302 as a Reference AN3961 SW
AN3937 MC9S12P-Family Demonstration Lab Training AN3937 SW
AN3936 How to install and run Classic CodeWarrior products on 64-bit Windows 7 PC AN3936
AN3832 Sensorless BLDC Motor Control Using MC9S08AC16 AN3832 SW
AN3784 Understanding the Memory Scheme in the S12(X) Architecture AN3784
AN3743 Emulated EEPROM Quick Start Guide AN3743
AN3624 S12X Temperature Sensor AN3624
AN3622 Comparison of the S12XS CRG Module with S12P CPMU Module AN3622
AN3613 Using the MC9S12XS Family as a Development Platform for MC9S12P Family AN3613
AN3589 Optically-Isolated Multilink BDM Interface for the S08-S12 Microcontrollers AN3589
AN3555 Investigating XGATE Software Errors AN3555
AN3510 S12HZ and S12XHZ Family Compatibility AN3510
AN3497 S12XS Family Compatibility Considerations AN3497
AN3493 TFT display AN3493 SW
AN3490 Overview of the MC9S12XE Emulated EEPROM AN3490
AN3469 S12 and S12XE Family Compatibility AN3469
AN3458 Debugging XGATE Code AN3458
AN3419 System Integrity Techniques for the S12XE AN3419
AN3391 LFAE Bootloader Example and Interface for use with AN2546 (CAN bootloader for S12XE) AN3391
AN3333 Implementing CAN and LIN Signal Level Gateway AN3333 SW
AN3330 Introduction to the Stepper Stall Detector Module AN3330 SW
AN3328 HCS12XD Family Compatibility Considerations AN3328
AN3327 Using the S12XE-Family as a Development Platform for the S12XS-Family AN3327
AN3300 General Soldering Temperature Process Guidelines AN3300
AN3298 Solder Joint Temperature and Package Peak Temperature AN3298
AN3292 XGATE Library SCI Emulation AN3292 SW
AN3291 How to Use IIC Module on M68HC08, HCS08, and HCS12 MCUs AN3291
AN3289 Low-Power Techniques for the S12X Family AN3289
AN3275 S12 All-Access Bootloader for the HCS12 Microcontroller Family AN3275 SW
AN3262 Designing Hardware for the HCS12X D-Family AN3262
AN3257 Meeting IEC 60730 Class B Compliance with the MC9S08AW60 AN3257
AN3253 XGATE Library Load Measurement AN3253 SW
AN3242 S12XD and S12XE Family Compatibility AN3242
AN3226 XGATE Library ATD Average AN3226 SW
AN3225 XGATE Library PWM Driver AN3225 SW
AN3224 Tutorial Introducing the XGATE Module to Consumer and Industrial Application Developers AN3224
AN3219 XGATE Library TN STN LCD Driver AN3219 SW
AN3208 Crystal guide AN3208
AN3153 USB - HID - ZSTAR AN3153 SW
AN3145 XGATE Library Using the Freescale XGATE Software Library AN3145
AN3144 Using XGATE to Implement a Simple Buffered SCI AN3144 SW
AN3034 Using MSCAN on the HCS12 Family AN3034 SW
AN3031 Temperature Sensor for the HCS08 Microcontroller Family AN3031 SW
AN3015 Using the XGATE for Manchester Decoding AN3015 SW
AN2974 Quick Start for Beginners to Drive a Stepper Motor AN2974
AN2881 Mapping Memory Resources on HCS12 Microcontrollers AN2881
AN2880 Using Backdoor Access Capability to Unsecure HCS12 MCUs AN2880 SW
AN2836 Web Server Development with MC9S12NE64 and OpenTCP AN2836 SW SW2 SW3
AN2764 Improving the Transient Immunity Performance of MCU-based Applications AN2764
AN2759 Implementing an Ethernet Interface with the MC9S12NE64 AN2759 SW
AN2734 HCS12X Family Memory Organization AN2734
AN2732 Using XGATE to Implement LIN Communication on HCS12X AN2732
AN2727 Designing Hardware for the HCS12 D-Family AN2727
AN2726 XGATE Library CAN Driver AN2726 SW
AN2724 Using the HCS12X PIT as a 24-bit Elapsed Timer AN2724
AN2720 A Utility for Programming Single FLASH Array HCS12 MCUs, with Minimum RAM Overhead AN2720 SW SW2
AN2708 An Introduction to the External Bus Interface on the HCS12X AN2708
AN2700 Basic Web Server Development with MC9S12NE64 and CMX-MicroNetT TCP-IP Stack AN2700 SW
AN2692 MC9S12NE64 Integrated Ethernet Controller AN2692
AN2685 How to Configure and Use the XGATE on S12X Devices AN2685
AN2678 Using the HCS12 NVM Standard Software Drivers with the Cosmic Compiler AN2678
AN2624 Basic Web Server Development with the CMX-MicroNet TCP-IP Stack AN2624 SW
AN2617 A Software Piority Interrupt Scheme on HCS12 Microcontrollers AN2617 SW
AN2615 HCS12 and S12X Family Compatibility AN2615
AN2612 PWM Generation Using HCS12 Timer Channels AN2612 SW
AN2597 Using the MC9S12E128 to Implement an IrDA Interface AN2597 SW
AN2573 LINkits LIN Evaluation Boards AN2573
AN2554 Clearing and Disabling Interrupt Flags AN2554
AN2552 Configuring the System and Peripheral Clocks in the MC9C12E128 AN2552 SW
AN2548 Serial Monitor Program for HCS12 MCUs AN2548 SW
AN2546 HCS12 Load RAM and Execute Bootloader User Guide AN2546 SW
AN2485 HCS12 Software Stationery AN2485 SW
AN2461 Low Power Management using HCS12 and SBC devices AN2461
AN2438 ADC Definitions and Specifications AN2438
AN2434 Input-Output Pin Drivers on HCS12 Family MCUs AN2434
AN2433 5V to 3V Design Considerations AN2433
AN2429 Interfacing to the HCS12 ATD Module AN2429
AN2428 An Overview of the HCS12 ATD Module AN2428
AN2408 Examples of HCS12 External Bus Design AN2408
AN2400 HCS12 NVM Guidelines AN2400
AN2396 Servo Motor Control Application on a LIN AN2396 SW
AN2342 Opto Isolation Circuits For In Circuit Debugging of 68HC9(S)12 and 68HC908 Microcontrollers AN2342
AN2321 Designing for Board Level Electromagnetic Compatibility AN2321
AN2318 Using the I2C Bus with HCS12 Microcontrollers AN2318 SW
AN2304 Implementation of a UDP-IP (User Datagram Protocol) Stack on HCS12 Microcontrollers AN2304 SW
AN2302 EEPROM Emulation for the MC9S12C32 AN2302 SW
AN2295 Developer's Serial Bootloader for M68HC08 abd HCS08 MCUs AN2295
AN2287 HCS12 External Bus Design AN2287
AN2283 Scalable Controller Area Network (MSCAN) Interrupts AN2283
AN2263 PC Master Software: Creation of Advanced Control Pages AN2263
AN2255 MSCAN Low-Power Applications AN2255
AN2250 Audio Reproduction on HCS12 Microcontrollers AN2250 SW SW2 SW3
AN2221 MI Bus Software Driver for the MC9S12DP256 AN2221 SW
AN2216 MC9S12DP256 Software Development Using Metrowerk's Codewarrior AN2216
AN2213 Using Cosmic Software's M68HC12 Compiler for MC9S12DP256 Software Development AN2213
AN2204 Fast NVM Programming for the MC9S12DP256 AN2204 SW
AN2201 Low Battery Cranking Pulse in Automotive Applications AN2201
AN2189 Using the Clock Generation Module on the HC12 D Family AN2189
AN2153 A Serial Bootloader for reprogramming the MC9S12DP256 FLASH Memory AN2153 SW
AN2104 Using Background Debug Mode for the M68HC12 Family AN2104
AN2103 Local Interconnect Network (LIN) Demonstration AN2103
AN2011 The MSCAN on the MC9S12DP256 compared with the MSCAN on the HC12 family AN2011
AN1954 MPXY8000 Series Tire Pressure Monitoring Sensor AN1954
AN1837 Non-Volatile Memory Technology Overview AN1837
AN1798 CAN Bit Timing Requirements AN1798
AN1783 Determining MCU Oscillator Start-up Parameters AN1783
AN1775 Expanding Digital Input with an AD converter AN1775
AN1771 Precision Sine-Wave Tone Synthesis Using 8-Bit MCUs AN1771
AN1716 Using M68HC12 Indexed Indirect Addressing AN1716
AN1705 Noise Reduction Techniques for Microcontroller-Based Systems AN1705
AN1284 Transporting M68HC11 Code to M68HC12 Devices AN1284
AN1280 Using and Extending D-Bug12 Routines AN1280
AN1263 System Design and Layout Techniques with Single-Chip Microcontrollers AN1263
AN1259 System Design and Layout Techniques for Noise Reduction in MCU-Based Systems AN1259
AN1058 Reducing A_D Errors in Microcontroller Applications AN1058
AN1051 Transmission Line Effects in PCB Applications AN1051
AN1050 Designing for Electromagnetic Compatibility (EMC) with HCMOS Microcontrollers AN1050
AN5389 S12Z MagniV LIN Bootloader AN5389 SW
AN11967 S12ZVM Family in 48 V Applications AN11967
タグ(2)
%3CLINGO-SUB%20id%3D%22lingo-sub-1120728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMagniV%E3%81%8A%E3%82%88%E3%81%B3S12(X)%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AE%E4%B8%80%E8%A6%A7%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CTABLE%20width%3D%22719%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN12086%20S12Z%E7%94%A8%E3%82%B7%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DAN12086%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN12086%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN12086SW.ZIP%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN5330%20S12ZVM%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%94%A8%E7%A7%BB%E8%A1%8C%E3%82%AC%E3%82%A4%E3%83%89%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN5330.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN5330%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN5327%20MagniV%20MC9S12ZVM%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E4%B8%89%E7%9B%B8%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%AC%E3%82%B9%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E9%9B%BB%E6%B5%81%E6%A4%9C%E5%87%BAPMSM%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E5%88%B6%E5%BE%A1%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN5327.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN5327%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN5264%20I2C%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BB%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN5264.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN5264%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN5264SW.zip%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN5207%20S12ZVM%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E8%A8%AD%E8%A8%88%E3%82%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DAN5207%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN5207%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN5190%20S12ZVM%E6%B4%BE%E7%94%9F%E8%A3%BD%E5%93%81%EF%BC%9APMF%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fzh%2Fapplication-note%2FAN5190.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN5190%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN5190SW.zip%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN5168%20S12ZVM%E3%81%A7%E3%81%AEADC%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN5168.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN5168%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN5168SW.zip%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN5135%20MagniV%20MC9S12ZVM%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F3%E7%9B%B8%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%AC%E3%82%B9PMSM%E3%83%A2%E3%83%BC%E3%82%BF%E5%88%B6%E5%BE%A1%E3%82%AD%E3%83%83%E3%83%88%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN5135.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN5135%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN5122%20MagniV%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%A7%E3%81%AEFreescale%20LIN%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN5122.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN5122%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DAN5122SW%26amp%3BdocLang%3Den%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN5084%20S12ZVL%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E8%A8%AD%E8%A8%88%E3%82%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DAN5084%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN5084%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN5082%20MagniV%E3%81%A7%E3%81%AE24V%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN5082.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN5082%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4975%20MagniV%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%A7%E3%81%AEMSCAN%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4975.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4975%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN4975SW.zip%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4912%20MCAT%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F3%E7%9B%B8PMSM%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%AC%E3%82%B9%E5%88%B6%E5%BE%A1%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%81%E3%83%A5%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4912.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4912%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4867%20S12ZVC%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E8%A8%AD%E8%A8%88%E3%82%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Ffiles-static%2Fmicrocontrollers%2Fdoc%2Fapp_note%2FAN4867.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4867%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4852%20S12ZVC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%AESENT%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9F%E3%83%83%E3%82%BF%E3%83%BB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4852.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4852%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN4852SW.zip%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4842%20S12ZVL%20LIN%E5%AF%BE%E5%BF%9CRGB%20LED%E7%85%A7%E6%98%8E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.google.com%2Furl%3Fsa%3Dt%26amp%3Brct%3Dj%26amp%3Bq%3D%26amp%3Besrc%3Ds%26amp%3Bsource%3Dweb%26amp%3Bcd%3D%26amp%3Bved%3D2ahUKEwjo5bew_4ryAhWuh_0HHZVrBZAQFjAAegQIBBAD%26amp%3Burl%3Dhttps%253A%252F%252Fcommunity.nxp.com%252Fpwmxy87654%252Fattachments%252Fpwmxy87654%252F16-bit%252F17163%252F1%252FAN4842.pdf%26amp%3Busg%3DAOvVaw1x6OQCkJfHbXQU7Xijqvy7%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4842%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN4842SW.zip%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4841%20S12ZVL%20LIN%E5%AF%BE%E5%BF%9C%E8%B6%85%E9%9F%B3%E6%B3%A2%E8%B7%9D%E9%9B%A2%E6%B8%AC%E5%AE%9A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4841.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4841%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN4841SW.zip%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4731%20Freescale%E8%BB%8A%E8%BC%89%E7%94%A8%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E6%B3%A8%E5%85%A5%E9%9B%BB%E6%B5%81%E3%81%AE%E7%90%86%E8%A7%A3%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4731.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4731%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4723%20S12Z%20MagniV%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4723.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4723%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN4723_SW.zip%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4722%20S12ZVH%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%AE%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%BB%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%EF%BC%88RTC%EF%BC%89%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4722.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4722%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4721%20S12ZVH%3A%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E8%A8%AD%E8%A8%88%E3%82%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4721.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4721%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4718%20S12ZVM%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F3%E7%9B%B8BLDC%E3%83%9B%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4718.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4718%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN4718SW.zip%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4704%203%E7%9B%B8%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%AC%E3%82%B9BLDC%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E5%88%B6%E5%BE%A1%E3%82%AD%E3%83%83%E3%83%88%EF%BC%88S12%20MagniV%20MC9S12ZVM%E4%BB%98%E3%81%8D%EF%BC%89%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4704.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4704%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4680%20PMSM%E3%81%AE%E9%9B%BB%E6%B0%97%E7%9A%84%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AE%E6%B8%AC%E5%AE%9A%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4680.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4680%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4643%20S12VR%20-%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E8%A8%AD%E8%A8%88%E3%82%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4643.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4643%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4642%203%E7%9B%B8PMSM%E7%94%A8%E3%83%A2%E3%83%BC%E3%82%BF%E5%88%B6%E5%BE%A1%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%BB%E3%83%81%E3%83%A5%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%EF%BC%88MCAT%EF%BC%89%E3%83%84%E3%83%BC%E3%83%AB%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4642.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4642%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4618%20HVAC%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8FS12G240%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%AC%E3%82%B9BLDC%E3%83%A2%E3%83%BC%E3%82%BF%E5%88%B6%E5%BE%A1%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4618.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4618%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4617%20HVAC%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FHMI%E8%A8%AD%E8%A8%88%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4617.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4617%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EHVAC%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8FAN4616%E3%83%95%E3%83%A9%E3%83%83%E3%83%97%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E5%88%B6%E5%BE%A1%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4616.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4616%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4558%203%E7%9B%B8%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%AC%E3%82%B9BLDC%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E5%88%B6%E5%BE%A1%E9%96%8B%E7%99%BA%E3%82%AD%E3%83%83%E3%83%88%EF%BC%88MC9S12G128%20MCU%E6%90%AD%E8%BC%89%EF%BC%89%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4558.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4558%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN4558SW.zip%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4540%20MC9S12VR%E3%81%A8MM912_634%E3%81%AE%E6%AF%94%E8%BC%83%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4540.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4540%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4506%20MCU%E7%94%A8CodeWarrior%E3%81%A7%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E8%A7%A3%E6%9E%90%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4506.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4506%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4505%20S12G%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%AE%E5%AE%89%E5%85%A8%E4%B8%8A%E3%81%AE%E8%80%83%E6%85%AE%E4%BA%8B%E9%A0%85%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4505.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4505%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4483%20S12P%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E7%94%A8%E3%81%AE%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%83%88EEPROM%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4483.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4483%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN4483SW.zip%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4455%20MC9S12G128_A240%20%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%A9%E3%83%9C%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4455.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4455%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN4455SW.zip%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4448%20MC9S12VR%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BB%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%BB%E3%83%A9%E3%83%9C%E3%83%BB%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4448.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4448%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DAN4448SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4418%20MC9S12G64%20%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%A9%E3%83%9C%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4418.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4418%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN4418SW.zip%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4388%20%E3%82%AF%E3%82%A2%E3%83%83%E3%83%89%E3%83%95%E3%83%A9%E3%83%83%E3%83%88%E3%83%BB%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%20(QFP)%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DAN4388%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4388%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4364%20%E8%A1%80%E7%B3%96%E5%80%A4%E8%A8%88%E3%81%AE%E5%9F%BA%E7%A4%8E%E3%81%A8%E8%A8%AD%E8%A8%88%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4364.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4364%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN4364SW.zip%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4320%20MC9S12GN32%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F16%E3%83%93%E3%83%83%E3%83%88Tower%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%9F%BA%E7%A4%8E%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4320.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4320%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4303%20MC9S12GN32%20MCU%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E7%85%A7%E6%98%8E%E5%88%B6%E5%BE%A1%E3%81%A8%E8%A8%BA%E6%96%AD%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4303.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4303%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN4303SW.zip%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4302%20S12G%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AAEEPROM%E3%81%AE%E6%A6%82%E8%A6%81%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4302.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4302%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN4302SW.zip%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4283%20S12%EF%BC%88XEXSP%EF%BC%89%E3%81%8A%E3%82%88%E3%81%B3S08%E3%81%8B%E3%82%89S12G%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%B8%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E7%A7%BB%E8%A1%8C%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4283.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4283%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4268%20%E4%B8%89%E7%9B%B8%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%AC%E3%82%B9BLDC%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E5%88%B6%E5%BE%A1%E3%82%AD%E3%83%83%E3%83%88%EF%BC%88Qorivva%20MPC5604P%E4%BB%98%E3%81%8D%EF%BC%89%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4268.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4268%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4263%20%E3%82%AD%E3%83%A3%E3%83%A9%E3%82%AF%E3%82%BF%E3%83%BB%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E7%94%A8eGUI%EF%BC%88D4D%EF%BC%89%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%EF%BC%88D4CD%EF%BC%89%E3%81%AE%E5%A4%89%E6%9B%B4%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4263.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4263%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN4263_SW.ZIP%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3E180%20nm%E3%83%86%E3%82%AF%E3%83%8E%E3%83%AD%E3%82%B8%E3%83%BC%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8FS12(X)%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E7%94%A8AN4258%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4258.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4258%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN4258SW.zip%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4236%20MC9S12XHY%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%20%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%A9%E3%83%9C%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4236.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4236%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN4236SW.zip%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4143%2016%E3%83%93%E3%83%83%E3%83%88S12XE%E3%81%8B%E3%82%8932%E3%83%93%E3%83%83%E3%83%88MPC5604B%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%AE%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%B8%E3%81%AE%E7%A7%BB%E8%A1%8C%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4143.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4143%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4058%209S08MP%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%9B%E3%83%BC%E3%83%AB%E5%8A%B9%E6%9E%9C%E3%82%BB%E3%83%B3%E3%82%B5%E4%BB%98%E3%81%8DBLDC%E3%83%A2%E3%83%BC%E3%82%BF%E5%88%B6%E5%BE%A1%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4058.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4058%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4024%20S12HY%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E9%AB%98%E9%80%9F%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E6%A4%9C%E5%87%BA%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4024.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4024%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN4024SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN4021%20MC9S12HY%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%20%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%A9%E3%83%9C%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4021.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN4021%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN4021SW.zip%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3961%20AN2302%E3%82%92%E5%9F%BA%E3%81%AB%E3%81%97%E3%81%9FMC9S12XS%E3%81%8A%E3%82%88%E3%81%B3MC9S12P%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E5%90%91%E3%81%91%E3%81%AEEEPROM%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3961.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3961%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN3961SW.zip%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3937%20MC9S12P%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BB%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%BB%E3%83%A9%E3%83%9C%E3%83%BB%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3937.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3937%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN3937SW.zip%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3936%2064%E3%83%93%E3%83%83%E3%83%88Windows%207%20PC%E3%81%A7%E3%82%AF%E3%83%A9%E3%82%B7%E3%83%83%E3%82%AFCodeWarrior%E8%A3%BD%E5%93%81%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3936.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3936%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3832%20MC9S08AC16%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%AC%E3%82%B9BLDC%E3%83%A2%E3%83%BC%E3%82%BF%E5%88%B6%E5%BE%A1%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3832.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3832%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN3832SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3784%20S12(X)%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%BB%E3%82%B9%E3%82%AD%E3%83%BC%E3%83%A0%E3%81%AE%E7%90%86%E8%A7%A3%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3784.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3784%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3743%20%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%83%88EEPROM%E3%81%AE%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E3%83%BB%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%83%BB%E3%82%AC%E3%82%A4%E3%83%89%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3743.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3743%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3624%20S12X%E6%B8%A9%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3624.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3624%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3622%20S12XS%20CRG%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%A8S12P%20CPMU%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E6%AF%94%E8%BC%83%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3622.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3622%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3613%20MC9S12XS%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%82%92MC9S12P%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%AE%E9%96%8B%E7%99%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3613.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3613%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3589%20S08%2FS12%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E7%94%A8%E5%85%89%E7%B5%B6%E7%B8%81%E3%83%9E%E3%83%AB%E3%83%81%E3%83%AA%E3%83%B3%E3%82%AFBDM%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3589.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3589%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3555%20XGATE%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E8%AA%BF%E6%9F%BB%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3555.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3555%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3510%20S12HZ%E3%81%8A%E3%82%88%E3%81%B3S12XHZ%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%AE%E4%BA%92%E6%8F%9B%E6%80%A7%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3510.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3510%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3497%20S12XS%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%AE%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%80%83%E6%85%AE%E4%BA%8B%E9%A0%85%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3497.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3497%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3493%20TFT%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3493.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3493%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN3493SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3490%20MC9S12XE%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%83%88EEPROM%E3%81%AE%E6%A6%82%E8%A6%81%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3490.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3490%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3469%20S12%E3%81%8A%E3%82%88%E3%81%B3S12XE%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%AE%E4%BA%92%E6%8F%9B%E6%80%A7%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3469.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3469%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3458%20XGATE%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3458.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3458%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3419%20S12XE%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E6%95%B4%E5%90%88%E6%80%A7%E6%8A%80%E8%A1%93%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3419.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3419%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3391%20AN2546%E3%81%A8%E5%85%B1%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8BLFAE%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%81%AE%E4%BE%8B%E3%81%A8%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%EF%BC%88S12XE%E7%94%A8CAN%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%EF%BC%89%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3391.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3391%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3333%20CAN%E3%81%8A%E3%82%88%E3%81%B3LIN%E4%BF%A1%E5%8F%B7%E3%83%AC%E3%83%99%E3%83%AB%E3%83%BB%E3%82%B2%E3%83%BC%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A4%E3%81%AE%E5%AE%9F%E8%A3%85%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3333.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3333%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN3333SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3330%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%83%BB%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E6%A4%9C%E5%87%BA%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E6%A6%82%E8%A6%81%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3330.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3330%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN3330SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3328%20HCS12XD%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%AE%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%80%83%E6%85%AE%E4%BA%8B%E9%A0%85%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3328.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3328%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3327%20S12XE%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%82%92S12XS%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%AE%E9%96%8B%E7%99%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3327.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3327%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3300%20%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91%E6%B8%A9%E5%BA%A6%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3300.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3300%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3298%20%E3%81%AF%E3%82%93%E3%81%A0%E6%8E%A5%E5%90%88%E6%B8%A9%E5%BA%A6%E3%81%A8%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%83%BB%E3%83%94%E3%83%BC%E3%82%AF%E6%B8%A9%E5%BA%A6%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3298.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3298%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3292%20XGATE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%20SCI%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3292.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3292%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN3292SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3291%20M68HC08%E3%80%81HCS08%E3%80%81HCS12%20MCU%E3%81%A7%E3%81%AEIIC%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3291.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3291%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3289%20S12X%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E5%90%91%E3%81%91%E3%81%AE%E4%BD%8E%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%E6%8A%80%E8%A1%93%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3289.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3289%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3275%20HCS12%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E5%90%91%E3%81%91S12%E3%82%AA%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%83%BB%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3275.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3275%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN3275SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3262%20HCS12X%20D%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E5%90%91%E3%81%91%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E8%A8%AD%E8%A8%88%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3262.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3262%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3257%20MC9S08AW60%E3%81%AB%E3%82%88%E3%82%8BIEC%2060730%E3%82%AF%E3%83%A9%E3%82%B9B%E5%AE%89%E5%85%A8%E8%A6%8F%E6%A0%BC%E3%81%AE%E6%BA%96%E6%8B%A0%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3257.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3257%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3253%20XGATE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E8%B2%A0%E8%8D%B7%E6%B8%AC%E5%AE%9A%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3253.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3253%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN3253SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3242%20S12XD%E3%81%8A%E3%82%88%E3%81%B3S12XE%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%AE%E4%BA%92%E6%8F%9B%E6%80%A7%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3242.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3242%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3226%20XGATE%20%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%20ATD%20%E5%B9%B3%E5%9D%87%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3226.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3226%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN3226SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3225%20XGATE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AAPWM%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3225.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3225%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN3225SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3224%20%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%EF%BC%9A%E6%B0%91%E7%94%9F%E7%94%A8%E3%81%8A%E3%82%88%E3%81%B3%E7%94%A3%E6%A5%AD%E7%94%A8%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E9%96%8B%E7%99%BA%E8%80%85%E5%90%91%E3%81%91%E3%81%AEXGATE%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E6%A6%82%E8%A6%81%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3224.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3224%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3219%20XGATE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AATN%20STN%20LCD%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3219.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3219%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN3219SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3208%20%E6%B0%B4%E6%99%B6%E3%82%AC%E3%82%A4%E3%83%89%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3208.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3208%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3153%20USB%20-%20HID%20-%20ZSTAR%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3153.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3153%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN3153SW%26amp%3BappType%3Dfile2%26amp%3BDOWNLOAD_ID%3Dnull%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3145%20XGATE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%EF%BC%9AFreescale%20XGATE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3145.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3145%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3144%20XGATE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B7%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AA%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E4%BB%98%E3%81%8DSCI%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3144.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3144%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN3144SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3034%20HCS12%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%A7%E3%81%AEMSCAN%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3034.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3034%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN3034SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3031%20HCS08%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E7%94%A8%E6%B8%A9%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3031.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3031%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN3031SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN3015%20%E3%83%9E%E3%83%B3%E3%83%81%E3%82%A7%E3%82%B9%E3%82%BF%E3%83%BC%E5%BE%A9%E5%8F%B7%E3%81%ABXGATE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3015.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN3015%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN3015SW%26amp%3BappType%3Dfile1%26amp%3BDOWNLOAD_ID%3Dnull%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2974%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%83%BB%E3%83%A2%E3%83%BC%E3%82%BF%E3%82%92%E9%A7%86%E5%8B%95%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E5%88%9D%E5%BF%83%E8%80%85%E5%90%91%E3%81%91%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E3%83%BB%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2974.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2974%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2881%20HCS12%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%A7%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%BB%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2881.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2881%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2880%20%E3%83%90%E3%83%83%E3%82%AF%E3%83%89%E3%82%A2%E3%83%BB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E6%A9%9F%E8%83%BD%E3%81%AB%E3%82%88%E3%82%8BHCS12%20MCU%E3%81%AE%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E8%A7%A3%E9%99%A4%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2880.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2880%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2880SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2836%20MC9S12NE64%E3%81%8A%E3%82%88%E3%81%B3OpenTCP%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FWeb%E3%82%B5%E3%83%BC%E3%83%90%E9%96%8B%E7%99%BA%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2836.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2836%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2836SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2836SW2%26amp%3BappType%3Dfile2%26amp%3BDOWNLOAD_ID%3Dnull%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW2%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2836SW3%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW3%3C%2FA%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2764%20MCU%E3%83%99%E3%83%BC%E3%82%B9%E3%83%BB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B8%E3%82%A7%E3%83%B3%E3%83%88%E8%80%90%E6%80%A7%E3%81%AE%E5%90%91%E4%B8%8A%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2764.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2764%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2759%20MC9S12NE64%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AE%E5%AE%9F%E8%A3%85%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2759.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2759%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2759SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2734%20HCS12X%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E6%A7%8B%E6%88%90%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2734.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2734%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2732%20XGATE%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20HCS12X%20%E4%B8%8A%E3%81%A7%20LIN%20%E9%80%9A%E4%BF%A1%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2732.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2732%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2727%20HCS12%20D%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%E5%90%91%E3%81%91%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E8%A8%AD%E8%A8%88%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2727.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2727%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2726%20XGATE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AACAN%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2726.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2726%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2726SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2724%20HCS12X%20PIT%E3%82%9224%E3%83%93%E3%83%83%E3%83%88%E7%B5%8C%E9%81%8E%E3%82%BF%E3%82%A4%E3%83%9E%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2724.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2724%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2720%20RAM%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%98%E3%83%83%E3%83%89%E3%82%92%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AB%E6%8A%91%E3%81%88%E3%81%9F%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%BB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%82%A2%E3%83%AC%E3%82%A4HCS12%20MCU%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E7%94%A8%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2720.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2720%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2720_SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2720SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW2%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2708%20HCS12X%E3%81%AE%E5%A4%96%E9%83%A8%E3%83%90%E3%82%B9%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AE%E6%A6%82%E8%A6%81%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2708.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2708%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2700%20MC9S12NE64%E3%81%8A%E3%82%88%E3%81%B3CMX-MicroNet%20TCP-IP%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%82%92%E7%94%A8%E3%81%84%E3%81%9F%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AAWeb%E3%82%B5%E3%83%BC%E3%83%90%E9%96%8B%E7%99%BA%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2700.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2700%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2700SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2692%20MC9S12NE64%E7%B5%B1%E5%90%88%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2692.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2692%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2685%20S12X%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%AEXGATE%E3%81%AE%E8%A8%AD%E5%AE%9A%E6%96%B9%E6%B3%95%E3%81%A8%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2685.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2685%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2678%20Cosmic%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%A7%E3%81%AEHCS12%20NVM%E6%A8%99%E6%BA%96%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2678.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2678%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2624%20CMX-MicroNet%20TCP-IP%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%82%92%E7%94%A8%E3%81%84%E3%81%9F%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AAWeb%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E9%96%8B%E7%99%BA%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2624.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2624%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2624SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2617%20HCS12%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%A7%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E5%84%AA%E5%85%88%E5%BA%A6%E5%89%B2%E8%BE%BC%E3%81%BF%E6%96%B9%E5%BC%8F%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2617.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2617%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2617SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2615%20HCS12%E3%81%8A%E3%82%88%E3%81%B3S12X%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%AE%E4%BA%92%E6%8F%9B%E6%80%A7%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2615.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2615%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2612%20HCS12%20%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20PWM%20%E7%94%9F%E6%88%90%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2612.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2612%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2612SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2597%20MC9S12E128%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20IrDA%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2597.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2597%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2597SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2573%20LINkits%20LIN%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2573.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2573%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2554%20%E5%89%B2%E8%BE%BC%E3%81%BF%E3%83%95%E3%83%A9%E3%82%B0%E3%81%AE%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%A8%E7%84%A1%E5%8A%B9%E5%8C%96%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2554.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2554%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2552%20MC9C12E128%E3%81%A7%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%BB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A8%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%83%BB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2552.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2552%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2552SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EHCS12%20MCU%E7%94%A8%20AN2548%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%A2%E3%83%8B%E3%82%BF%E3%83%BC%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2548.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2548%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2548SW1%26amp%3BappType%3Dfile1%26amp%3BDOWNLOAD_ID%3Dnull%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2546%20HCS12%20RAM%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2546.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2546%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2546SW%26amp%3BappType%3Dfile1%26amp%3BDOWNLOAD_ID%3Dnull%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2485%20HCS12%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%8A%E3%83%AA%E3%83%BC%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2485.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2485%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2485SW%26amp%3BappType%3Dfile1%26amp%3BDOWNLOAD_ID%3Dnull%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2461%20HCS12%E3%81%8A%E3%82%88%E3%81%B3SBC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E4%BD%8E%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%E7%AE%A1%E7%90%86%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2461.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2461%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2438%20ADC%20%E5%AE%9A%E7%BE%A9%E3%81%A8%E4%BB%95%E6%A7%98%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2438.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2438%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2434%20HCS12%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AAMCU%E3%81%AE%E5%85%A5%E5%87%BA%E5%8A%9B%E3%83%94%E3%83%B3%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2434.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2434%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2433%205V%E3%81%8B%E3%82%893V%E3%81%B8%E3%81%AE%E8%A8%AD%E8%A8%88%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%80%83%E6%85%AE%E4%BA%8B%E9%A0%85%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2433.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2433%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2429%20HCS12%20ATD%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%B8%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2429.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2429%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2428%20HCS12%20ATD%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E6%A6%82%E8%A6%81%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2428.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2428%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2408%20HCS12%E5%A4%96%E9%83%A8%E3%83%90%E3%82%B9%E8%A8%AD%E8%A8%88%E3%81%AE%E4%BE%8B%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2408.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2408%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2400%20HCS12%20NVM%20%E3%82%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2400.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2400%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2396%20LIN%E3%81%A7%E3%81%AE%E3%82%B5%E3%83%BC%E3%83%9C%E3%83%A2%E3%83%BC%E3%82%BF%E5%88%B6%E5%BE%A1%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2396.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2396%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2396SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2342%2068HC9(S)12%E3%81%8A%E3%82%88%E3%81%B368HC908%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B5%E3%83%BC%E3%82%AD%E3%83%83%E3%83%88%E3%83%BB%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E7%94%A8%E5%85%89%E7%B5%B6%E7%B8%81%E5%9B%9E%E8%B7%AF%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2342.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2342%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2321%20%E3%83%9C%E3%83%BC%E3%83%89%E3%83%BB%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E9%9B%BB%E7%A3%81%E7%92%B0%E5%A2%83%E9%81%A9%E5%90%88%E6%80%A7%EF%BC%88EMC%EF%BC%89%E3%81%AB%E5%90%91%E3%81%91%E3%81%9F%E8%A8%AD%E8%A8%88%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2321.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2321%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2318%20HCS12%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%A7I2C%E3%83%90%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2318.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2318%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2318SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2304%20HCS12%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%A7%E3%81%AEUDP-IP%EF%BC%88%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%BB%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B0%E3%83%A9%E3%83%A0%E3%83%BB%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%EF%BC%89%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AE%E5%AE%9F%E8%A3%85%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2304.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2304%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2304SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EMC9S12C32%E7%94%A8AN2302%20EEPROM%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2302.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2302%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2302SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2295%20M68HC08%E3%81%8A%E3%82%88%E3%81%B3HCS08%20MCU%E7%94%A8%E3%81%AE%E9%96%8B%E7%99%BA%E8%80%85%E5%90%91%E3%81%91%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%BB%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2295.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2295%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2287%20HCS12%20%E5%A4%96%E9%83%A8%E3%83%90%E3%82%B9%E8%A8%AD%E8%A8%88%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2287.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2287%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2283%20%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%A9%E3%83%96%E3%83%AB%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BB%E3%82%A8%E3%83%AA%E3%82%A2%E3%83%BB%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%20(MSCAN)%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2283.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2283%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2263%20PC%20Master%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%EF%BC%9A%E9%AB%98%E5%BA%A6%E3%81%AA%E5%88%B6%E5%BE%A1%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2263.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2263%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2255%20MSCAN%20%E4%BD%8E%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2255.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2255%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2250%20HCS12%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%A7%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E5%86%8D%E7%94%9F%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2250.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2250%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2250SW1%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2250SW2%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW2%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2250SW3%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW3%3C%2FA%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EMC9S12DP256%E7%94%A8%20AN2221%20MI%E3%83%90%E3%82%B9%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2221.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2221%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2221SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2216%20Metrowerk%E3%81%AECodeWarrior%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FMC9S12DP256%E5%90%91%E3%81%91%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E9%96%8B%E7%99%BA%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2216.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2216%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2213%20Cosmic%20Software%E3%81%AEM68HC12%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FMC9S12DP256%E5%90%91%E3%81%91%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E9%96%8B%E7%99%BA%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2213.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2213%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2204%20MC9S12DP256%E5%90%91%E3%81%91%E3%81%AE%E9%AB%98%E9%80%9FNVM%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2204.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2204%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DAN2204SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2201%20%E8%BB%8A%E8%BC%89%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E4%BD%8E%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BB%E3%82%AF%E3%83%A9%E3%83%B3%E3%82%AD%E3%83%B3%E3%82%B0%E3%83%BB%E3%83%91%E3%83%AB%E3%82%B9%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2201.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2201%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2189%20HC12%20D%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%A7%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E7%94%9F%E6%88%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2189.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2189%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2153%20MC9S12DP256%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E5%86%8D%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%BB%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2153.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2153%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2252%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DAN2153SW%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2244%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2243%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2104%20M68HC12%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%A7%E3%81%AE%E3%83%90%E3%83%83%E3%82%AF%E3%82%B0%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%BB%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%BB%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2104.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2104%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2103%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%88%E3%83%BB%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%EF%BC%88LIN%EF%BC%89%E3%81%AE%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2103.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2103%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN2011%20MC9S12DP256%E3%81%AEMSCAN%E3%81%A8HC12%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%AEMSCAN%E3%81%AE%E6%AF%94%E8%BC%83%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2011.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN2011%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN1954%20MPXY8000%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%BB%E3%82%BF%E3%82%A4%E3%83%A4%E7%A9%BA%E6%B0%97%E5%9C%A7%E7%9B%A3%E8%A6%96%E3%82%BB%E3%83%B3%E3%82%B5%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN1954.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN1954%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN1837%20%E4%B8%8D%E6%8F%AE%E7%99%BA%E6%80%A7%E3%83%A1%E3%83%A2%E3%83%AA%E6%8A%80%E8%A1%93%E3%81%AE%E6%A6%82%E8%A6%81%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN1837.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN1837%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN1798%20CAN%E3%83%93%E3%83%83%E3%83%88%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E8%A6%81%E4%BB%B6%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN1798.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN1798%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN1783%20MCU%E3%82%AA%E3%82%B7%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%83%BB%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AE%E6%B1%BA%E5%AE%9A%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN1783.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN1783%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN1775%20AD%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E5%85%A5%E5%8A%9B%E3%81%AE%E6%8B%A1%E5%BC%B5%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN1775.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN1775%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN1771%208%E3%83%93%E3%83%83%E3%83%88MCU%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E7%B2%BE%E5%AF%86%E3%81%AA%E6%AD%A3%E5%BC%A6%E6%B3%A2%E3%83%88%E3%83%BC%E3%83%B3%E5%90%88%E6%88%90%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN1771.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN1771%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN1716%20M68HC12%E3%81%AE%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E9%96%93%E6%8E%A5%E3%82%A2%E3%83%89%E3%83%AC%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN1716.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN1716%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN1705%20%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%BB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%83%8E%E3%82%A4%E3%82%BA%E4%BD%8E%E6%B8%9B%E6%8A%80%E8%A1%93%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN1705.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN1705%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN1284%20M68HC11%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%20M68HC12%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN1284.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN1284%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN1280%20D-Bug12%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%A8%E6%8B%A1%E5%BC%B5%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN1280.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN1280%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN1263%20%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%81%E3%83%83%E3%83%97%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%82%92%E7%94%A8%E3%81%84%E3%81%9F%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E8%A8%AD%E8%A8%88%E3%81%8A%E3%82%88%E3%81%B3%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E6%8A%80%E8%A1%93%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN1263.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN1263%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN1259%20MCU%E3%83%99%E3%83%BC%E3%82%B9%E3%83%BB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%81%AE%E3%83%8E%E3%82%A4%E3%82%BA%E4%BD%8E%E6%B8%9B%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E8%A8%AD%E8%A8%88%E3%81%A8%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E6%8A%80%E8%A1%93%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN1259.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN1259%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN1058%20%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BA%2FD%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E4%BD%8E%E6%B8%9B%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN1058.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN1058%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN1051%20PCB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E4%BC%9D%E9%80%81%E7%B7%9A%E5%8A%B9%E6%9E%9C%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN1051.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN1051%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN1050%20HCMOS%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%A7%E3%81%AE%E9%9B%BB%E7%A3%81%E4%B8%A1%E7%AB%8B%E6%80%A7%EF%BC%88EMC%EF%BC%89%E3%81%AE%E8%A8%AD%E8%A8%88%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN1050.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN1050%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN5389%20S12Z%20MagniV%20LIN%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN5389.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN5389%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN5389SW.zip%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ESW%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22517%22%20style%3D%22font-weight%3A%20400%3B%22%3EAN11967%2048V%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AES12ZVM%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%3C%2FTD%3E%0A%3CTD%20width%3D%2263%22%20style%3D%22font-weight%3A%20400%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN11967.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN11967%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-weight%3A%20400%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎05-22-2023 04:34 AM
更新者:
