Easy set-up of NFC on Raspberry Pi
This document describes step-by-step how to run NFC on Raspberry Pi platform.
Hardware setup:
You need:
   - Raspberry Pi (any model) : https://www.raspberrypi.org/products/:
   - OM5578(PN7150 demokit) in RPi configuration (or OM5577(PN7120 demokit)
Then simply assemble boards together, stacking OM5578RPI (or OM5577RPI) to Raspberry Pi expansion connector:
Software setup:
Use Raspbian  (https://www.raspberrypi.org/software/operating-systems/) or any other Linux distribution (guidelines to set up Linux environment on raspberry pi: https://www.raspberrypi.org/documentation/installation/installing-images/).
Step by step procedure:
  • Enable i2c support:
       On Raspbian:
  1. Run "sudo raspi-config"
  2. Use the down arrow to select "5 Interfacing Options"
  3. Arrow down to "P5 I2C"
  4. Select "yes" when it asks you to enable I2C
  5. Also select "yes" if it asks about automatically loading the kernel module
  6. Use the right arrow to select the <Finish> button
  7. Select "yes" when it asks to reboot
      The system will reboot. when it comes back up, log in and enter the following command "ls /dev/*i2c*".
      The Pi should respond with "/dev/i2c-1" which represents the user-mode I2C interface.
  • Install necessary tools:
        On Raspbian execute the command:
   sudo apt-get install autoconf automake libtool git
  • Clone Linux libnfc-nci library repository:
        Execute the command:
   git clone https://github.com/NXPNFCLinux/linux_libnfc-nci.git
  • Configure the library:
        Execute the commands:
   cd linux_libnfc-nci
   ./bootstrap
   ./configure --enable-alt
  • Build and install the library:
   make
      sudo make install
   export LD_LIBRARY_PATH=/usr/local/lib
  • Run demo application (built and installed together with the library during previous step):
        To simply display all data collected from remote NFC device (Peer, reader/writer or card), run the demo application in poll mode executing the command:
   nfcDemoApp poll
        For more details about the demo application modes execute command:
   nfcDemoApp --help
One step further:
  • Set environment variable to reference library installation:
        Execute command:
        You may wan't to make this setting permanent by adding it to your .bashrc file for instance :
echo "export LD_LIBRARY_PATH=/usr/local/lib" >> .bashrc
  • Write your own application:
        Several simple examples demonstrating use of the linux_libnfc-nci library for different use cases (Reader, Peer to peer, Host Card Emulation) are given as reference: https://github.com/NXPNFCLinux/linux_libnfc-nci_examples
       - Simply clone the repository
   git clone https://github.com/NXPNFCLinux/linux_libnfc-nci_examples.git
       - Browse to the targeted example:
   cd linux_libnfc-nci_examples/xxx_example
       - Build the example:
   make
       - Run the example
   ./xxx_example
Additional information:
  • Another Platform ?
       Using UDOO NEO (with OM5577 or OM5578 in Arduino configuration) ?
          -> Follow step-by-step procedure, just updating src/halimpl/pn54x/tml/i2c/phTmlNfc_alt.h file to set CONFIGURATION flag to value 2, before building the library
       Using BeagleBone Black (with OM5577 or OM5578 in BBB configuration) ?
       Using other Linux platform or others OM5578/OM5577 demokits configuration ?
          -> Follow step-by-step procedure, just updating src/halimpl/pn54x/tml/i2c/phTmlNfc_alt.h file to set CONFIGURATION flag to value 0 and defining I2C_BUS, PIN_INT and PIN_ENABLE flags according to the HW connection, before building the library
%3CLINGO-SUB%20id%3D%22lingo-sub-1099034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERaspberry%20Pi%E3%81%A7%E3%81%AENFC%E3%81%AE%E7%B0%A1%E5%8D%98%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CFONT%20size%3D%224%22%3E%E3%81%93%E3%81%AE%E6%96%87%E6%9B%B8%E3%81%AF%E3%80%81Raspberry%20Pi%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7%20NFC%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%82%92%E6%AE%B5%E9%9A%8E%E7%9A%84%E3%81%AB%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CH2%20id%3D%22toc-hId--1436515630%22%20id%3D%22toc-hId--493809284%22%3E%3CFONT%20size%3D%225%22%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%EF%BC%9A%3C%2FFONT%3E%3C%2FH2%3E%0A%3CH4%20id%3D%22toc-hId-1752061781%22%20id%3D%22toc-hId--1600199169%22%3E%3CSTRONG%3E%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%82%E3%81%AE%EF%BC%9A%3C%2FSTRONG%3E%3C%2FH4%3E%0A%3CP%3E%3CFONT%20size%3D%223%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B-%20Raspberry%20Pi%EF%BC%88%E4%BB%BB%E6%84%8F%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%EF%BC%89%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fwww.raspberrypi.org%2Fproducts%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.raspberrypi.org%2Fproducts%2F%3A%3C%2FA%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_9.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F104979i3616CEE3C02783CD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22pastedImage_9.jpg%22%20alt%3D%22pastedImage_9.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_9.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CFONT%20size%3D%223%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B-%20RPi%E6%A7%8B%E6%88%90%E3%81%AE%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fidentification-and-security%2Fnfc%2Fnfc-reader-ics%2Fdevelopment-kits-for-pn7150-plugn-play-nfc-controller%3AOM5578%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EOM5578%EF%BC%88PN7150%E3%83%87%E3%83%A2%E3%82%AD%E3%83%83%E3%83%88%EF%BC%89%3C%2FA%3E%E3%81%BE%E3%81%9F%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fidentification-and-security%2Fnfc%2Fnfc-reader-ics%2Fdevelopment-kits-for-pn7120-plugn-play-nfc-controller%3AOM5577%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EOM5577%EF%BC%88PN7120%E3%83%87%E3%83%A2%E3%82%AD%E3%83%83%E3%83%88%EF%BC%89%3C%2FA%3E%3C%2FFONT%3E%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_1.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F104980i7292D6BE90761001%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22pastedImage_1.jpg%22%20alt%3D%22pastedImage_1.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_11.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F61762iC1CBAF1336EAC399%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22pastedImage_11.jpg%22%20alt%3D%22pastedImage_11.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_11.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%E6%AC%A1%E3%81%AB%E3%80%81OM5578RPI%EF%BC%88%E3%81%BE%E3%81%9F%E3%81%AFOM5577RPI%EF%BC%89%E3%82%92Raspberry%20Pi%E6%8B%A1%E5%BC%B5%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%AB%E7%A9%8D%E3%81%BF%E9%87%8D%E3%81%AD%E3%81%A6%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E7%B5%84%E3%81%BF%E7%AB%8B%E3%81%A6%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_4.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F61765i70A14667683B1B21%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22pastedImage_4.jpg%22%20alt%3D%22pastedImage_4.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_4.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH2%20id%3D%22toc-hId--756457260%22%20id%3D%22toc-hId-186249086%22%3E%26nbsp%3B%3C%2FH2%3E%0A%3CH2%20id%3D%22toc-hId-1731055573%22%20id%3D%22toc-hId--1621205377%22%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%EF%BC%9A%3C%2FH2%3E%0A%3CP%20data-unlink%3D%22true%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20data-unlink%3D%22true%22%3ERaspbian%EF%BC%88%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.raspberrypi.org%2Fsoftware%2Foperating-systems%2F%22%20href%3D%22https%3A%2F%2Fwww.raspberrypi.org%2Fsoftware%2Foperating-systems%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.raspberrypi.org%2Fsoftware%2Foperating-systems%2F%3C%2FA%3E%EF%BC%89%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AELinux%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88Raspberry%20Pi%E3%81%A7Linux%E7%92%B0%E5%A2%83%E3%82%92%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%EF%BC%9A%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.raspberrypi.org%2Fdocumentation%2Finstallation%2Finstalling-images%2F%22%20href%3D%22https%3A%2F%2Fwww.raspberrypi.org%2Fdocumentation%2Finstallation%2Finstalling-images%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%EF%BC%9A%2F%2Fwww.raspberrypi.org%2Fdocumentation%2Finstallation%2Finstalling-images%2F%3C%2FA%3E%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId--1873350249%22%20id%3D%22toc-hId--930643903%22%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%83%BB%E3%83%90%E3%82%A4%E3%83%BB%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AE%E6%89%8B%E9%A0%86%EF%BC%9A%3C%2FH3%3E%0A%3CUL%3E%0A%3CLI%3E%0A%3CH6%20id%3D%22toc-hId--481724197%22%20id%3D%22toc-hId-460982149%22%3E%3CSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3Ei2c%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E6%9C%89%E5%8A%B9%E5%8C%96%EF%BC%9A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FH6%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Raspbian%E3%81%A7%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%93%8D%E4%BD%9C%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CDIV%20style%3D%22margin-left%3A%202em%3B%22%3E%0A%3COL%3E%0A%3CLI%3E%0A%3CP%3ERun%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2015px%3B%22%3E%22sudo%20raspi-config%22%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E4%B8%8B%E7%9F%A2%E5%8D%B0%E3%82%AD%E3%83%BC%E3%81%A7%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2015px%3B%22%3E%E3%80%8C5%20Interfacing%20Options%E3%80%8D%3C%2FSPAN%3E%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E4%B8%8B%E7%9F%A2%E5%8D%B0%E3%82%AD%E3%83%BC%E3%81%A7%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2015px%3B%22%3E%E3%80%8C%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3EP5%E2%80%AFI2C%E3%80%8D%3C%2FSPAN%3E%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3EI2C%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%8B%E5%B0%8B%E3%81%AD%E3%82%89%E3%82%8C%E3%81%9F%E3%82%89%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2015px%3B%22%3E%E3%80%8C%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3EYes%E3%80%8D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%BB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E8%87%AA%E5%8B%95%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E5%B0%8B%E3%81%AD%E3%82%89%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%E3%82%82%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2015px%3B%22%3E%E3%80%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3EYes%E3%80%8D%3C%2FSPAN%3E%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E5%8F%B3%E7%9F%A2%E5%8D%B0%E3%82%AD%E3%83%BC%E3%81%A7%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%E3%80%8CFinish%E3%80%8D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E5%86%8D%E8%B5%B7%E5%8B%95%E3%82%92%E6%B1%82%E3%82%81%E3%82%89%E3%82%8C%E3%81%9F%E3%82%89%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2015px%3B%22%3E%E3%80%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3EYes%E3%80%8D%3C%2FSPAN%3E%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_34.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_34.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F104981i138EBEE866041EB1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22pastedImage_34.png%22%20alt%3D%22pastedImage_34.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_34.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3C%2FDIV%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E8%B5%B7%E5%8B%95%E5%BE%8C%E3%81%AB%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%97%E3%81%A6%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2015px%3B%22%3E%E3%80%8C%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3Els%20%2Fdev%2F*i2c*%E3%80%8D%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Raspberry%20Pi%E3%81%8B%E3%82%89%E3%81%AF%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2015px%3B%22%3E%E3%80%8C%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%2Fdev%2Fi2c-1%E3%80%8D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E3%81%A8%E3%81%84%E3%81%86%E5%BF%9C%E7%AD%94%E3%81%8C%E8%BF%94%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AEI2C%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E8%A1%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3E%0A%3CH6%20id%3D%22toc-hId-2005788636%22%20id%3D%22toc-hId--1346472314%22%3E%3CSTRONG%3E%3CFONT%20size%3D%223%22%3E%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%EF%BC%9A%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FH6%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3ERaspbian%E3%81%A7%3C%2FSPAN%3E%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3Esudo%20apt-get%20install%20autoconf%20automake%20libtool%20git%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%3E%0A%3CH6%20id%3D%22toc-hId-198334173%22%20id%3D%22toc-hId-1141040519%22%3E%3CSTRONG%3E%3CFONT%20size%3D%223%22%3ELinux%20libnfc-nci%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%83%BB%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%EF%BC%9A%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FH6%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3C%2FSPAN%3E%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3Bgit%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPNFCLinux%2Flinux_libnfc-nci.git%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPNFCLinux%2Flinux_libnfc-nci.git%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%3E%0A%3CH6%20id%3D%22toc-hId--1609120290%22%20id%3D%22toc-hId--666413944%22%3E%3CSTRONG%3E%3CFONT%20size%3D%223%22%3E%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E8%A8%AD%E5%AE%9A%EF%BC%9A%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FH6%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3C%2FSPAN%3E%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3Ecd%20linux_libnfc-nci%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B.%2Fbootstrap%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%2Fconfigure%20--enable-alt%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%3E%0A%3CH6%20id%3D%22toc-hId-878392543%22%20id%3D%22toc-hId-1821098889%22%3E%3CSTRONG%3E%3CFONT%20size%3D%223%22%3E%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%A8%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%EF%BC%9A%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FH6%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3C%2FSPAN%3E%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3Emake%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3Esudo%20make%20install%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%26nbsp%3B%26nbsp%3B%20export%20LD_LIBRARY_PATH%3D%2Fusr%2Flocal%2Flib%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%3CFONT%20size%3D%223%22%3E%E3%83%87%E3%83%A2%E3%83%BB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E5%AE%9F%E8%A1%8C%EF%BC%88%E5%89%8D%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%A7%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%A8%E5%85%B1%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%8A%E3%82%88%E3%81%B3%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E6%B8%88%E3%81%BF%EF%BC%89%EF%BC%9A%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CFONT%20size%3D%223%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88NFC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%EF%BC%88%E3%83%94%E3%82%A2%E3%80%81%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%2F%E3%83%A9%E3%82%A4%E3%82%BF%E3%83%BC%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%AB%E3%83%BC%E3%83%89%EF%BC%89%E3%81%8B%E3%82%89%E5%8F%8E%E9%9B%86%E3%81%95%E3%82%8C%E3%81%9F%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8D%98%E7%B4%94%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%80%81%E3%83%87%E3%83%A2%E3%83%BB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%BB%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3EnfcDemoApp%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_73.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_73.png%22%20style%3D%22width%3A%20510px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F104982i1278D0BB27DBDFAC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_73.png%22%20alt%3D%22pastedImage_73.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_73.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CFONT%20size%3D%223%22%3E%E3%83%87%E3%83%A2%E3%83%BB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%3C%2FFONT%3E%3C%2FSPAN%3E%3CFONT%20size%3D%223%22%3E%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3BnfcDemoApp%20--help%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CBR%20%2F%3E%0A%3CH2%20id%3D%22toc-hId--657421337%22%20id%3D%22toc-hId-285285009%22%3E%E6%AC%A1%E3%81%AE%E4%B8%80%E6%AD%A9%EF%BC%9A%3C%2FH2%3E%0A%3CUL%3E%0A%3CLI%3E%0A%3CH3%20id%3D%22toc-hId-1959174215%22%20id%3D%22toc-hId--1393086735%22%3E%3CSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E5%A0%B4%E6%89%80%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%81%AE%E8%A8%AD%E5%AE%9A%EF%BC%9A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FH3%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3Eexport%20LD_LIBRARY_PATH%3D%2Fusr%2Flocal%2Flib%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%81%93%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E6%B0%B8%E7%B6%9A%E5%8C%96%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81.bashrc%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%80%81%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3Eecho%20%22export%20LD_LIBRARY_PATH%3D%2Fusr%2Flocal%2Flib%22%20%26gt%3B%26gt%3B%20.bashrc%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%3E%0A%3CH3%20id%3D%22toc-hId-151719752%22%20id%3D%22toc-hId-1094426098%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E7%8B%AC%E8%87%AA%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E4%BD%9C%E6%88%90%EF%BC%9A%3C%2FSPAN%3E%3C%2FH3%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CFONT%20size%3D%223%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%83%A6%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%82%B9%EF%BC%88%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%80%81%E3%83%94%E3%82%A2%E3%83%BB%E3%83%84%E3%83%BC%E3%83%BB%E3%83%94%E3%82%A2%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%E3%83%BB%E3%82%AB%E3%83%BC%E3%83%89%E3%83%BB%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%EF%BC%89%E3%81%A7%E3%81%AElinux_libnfc-nci%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%E3%82%92%E7%A4%BA%E3%81%99%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E7%B0%A1%E5%8D%98%E3%81%AA%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%8C%E5%8F%82%E8%80%83%E3%81%A8%E3%81%97%E3%81%A6%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPNFCLinux%2Flinux_libnfc-nci_examples%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPNFCLinux%2Flinux_libnfc-nci_examples%3C%2FA%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%223%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%3C%2FSPAN%3E%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E5%8D%98%E7%B4%94%E3%81%AB%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3Bgit%20clone%20%3CA%20class%3D%22unlinked%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPNFCLinux%2Flinux_libnfc-nci_examples.git%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%20%E7%9B%AE%E7%9A%84%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3Ecd%20linux_libnfc-nci_examples%2F%3CSTRONG%3Exxx%3C%2FSTRONG%3E_example%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%26nbsp%3B%26nbsp%3B%20make%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E.%2F%3CSTRONG%3Exxx%3C%2FSTRONG%3E_example%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH2%20id%3D%22toc-hId--1784817430%22%20id%3D%22toc-hId--842111084%22%3E%E8%BF%BD%E5%8A%A0%E6%83%85%E5%A0%B1%EF%BC%9A%3C%2FH2%3E%0A%3CUL%3E%0A%3CLI%3E%0A%3CH3%20id%3D%22toc-hId-831778122%22%20id%3D%22toc-hId-1774484468%22%3E%3CFONT%20size%3D%223%22%3E%E5%88%A5%E3%81%AE%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AE%E5%A0%B4%E5%90%88%3C%2FFONT%3E%3C%2FH3%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CA%20href%3D%22https%3A%2F%2Fwww.udoo.org%2Fudoo-neo%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EUDOO%20NEO%3C%2FA%3E%EF%BC%88Arduino%E6%A7%8B%E6%88%90%E3%81%A7%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fidentification-and-security%2Fnfc%2Fnfc-reader-ics%2Fdevelopment-kits-for-pn7120-plugn-play-nfc-controller%3AOM5577%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EOM5577%3C%2FA%3E%E3%81%BE%E3%81%9F%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fidentification-and-security%2Fnfc%2Fnfc-reader-ics%2Fdevelopment-kits-for-pn7150-plugn-play-nfc-controller%3AOM5578%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EOM5578%3C%2FA%3E%EF%BC%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%26gt%3B%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%83%BB%E3%83%90%E3%82%A4%E3%83%BB%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81src%2Fhalimpl%2Fpn54x%2Ftml%2Fi2c%2FphTmlNfc_alt.h%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%80%81CONFIGURATION%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E5%80%A42%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E3%81%86%E3%81%88%E3%81%A7%E3%80%81%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CA%20href%3D%22https%3A%2F%2Fbeagleboard.org%2Fblack%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EBeagleBone%20Black%3C%2FA%3E%EF%BC%88BBB%E6%A7%8B%E6%88%90%E3%81%A7%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fidentification-and-security%2Fnfc%2Fnfc-reader-ics%2Fdevelopment-kits-for-pn7120-plugn-play-nfc-controller%3AOM5577%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EOM5577%3C%2FA%3E%E3%81%BE%E3%81%9F%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fidentification-and-security%2Fnfc%2Fnfc-reader-ics%2Fdevelopment-kits-for-pn7150-plugn-play-nfc-controller%3AOM5578%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EOM5578%3C%2FA%3E%EF%BC%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%26gt%3B%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%83%BB%E3%83%90%E3%82%A4%E3%83%BB%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81src%2Fhalimpl%2Fpn54x%2Ftml%2Fi2c%2FphTmlNfc_alt.h%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%80%81CONFIGURATION%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E5%80%A42%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E3%81%86%E3%81%88%E3%81%A7%E3%80%81%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BB%96%E3%81%AE%20Linux%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%BE%E3%81%9F%E3%81%AF%E4%BB%96%E3%81%AE%20OM5578%2FOM5577%20%E3%83%87%E3%83%A2%E3%82%AD%E3%83%83%E3%83%88%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%26gt%3B%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%83%BB%E3%83%90%E3%82%A4%E3%83%BB%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81src%2Fhalimpl%2Fpn54x%2Ftml%2Fi2c%2FphTmlNfc_alt.h%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%80%81CONFIGURATION%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E5%80%A40%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81I2C_BUS%E3%80%81PIN_INT%E3%80%81PIN_ENABLE%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E6%8E%A5%E7%B6%9A%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%9F%E3%81%86%E3%81%88%E3%81%A7%E3%80%81%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%0A%3CH3%20id%3D%22toc-hId--975676341%22%20id%3D%22toc-hId--32969995%22%3E%3CFONT%20size%3D%223%22%3EAndroid%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%3C%2FFONT%3E%3C%2FH3%3E%0A-%26gt%3B%20%E9%96%A2%E9%80%A3%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN11690.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN11690.pdf%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1099034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%83%A2%E3%83%90%E3%82%A4%E3%83%AB%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎09-02-2021 12:39 AM
更新者:
