MPC5777C DCF Configurator
Document created by Petr Stancik Employee on Oct 12, 2017Last modified by Petr Stancik Employee on Jan 14, 2020
Version 4Show Document
  • View in full screen mode
Detailed Description:
This config tool simplifies DCF records calculation for MPC5746R device.
Look at HowToUse sheet for simple guideline, then work with DCF sheet
Notes:
- Macros have to be enabled!
- Programming more than 104 DCF records on Cut1.0b will result in incorrect device operation (FCCU faults, SSCM[CER] bit set, etc)
BR, Petr
6 people found this helpful
Outcomes
