Quick Start Guide – Using MCUXpresso SDK with PINs&CLOCKs Config Tools
Document created by ZhangJennie Employee on Jul 27, 2017Last modified by ebiz_ws_prod on Dec 13, 2017
Version 3Show Document
  • View in full screen mode
Last month I had two local customers asked me how to use pin config and clock config tool with MCUXpresso SDK from start. They hoped to have an easy quick start guide to initialize their LPC54608 project developing. Therefore I wrote this article. Just for sharing.
This article takes a hands-on example based on LPCXpresso54608 board, illustrating how to use online Pins Config and Clocks Config tool with MCUXpresso SDK from start, step by step.
Although the article is based on LPC54608, it should also be helpful to the starter who uses MCUXpresso Config Tools for developing other Kinetis and LPC board as quick reference.
With this article, you will learn:
  •        How to use the Pins Config and Clocks Config tools to generate the initialization codes automatically.
  •        How to start a new SDK project with support of Pins Config and Clocks Config tools generated files.
This article is a quick start guide only. For more information, please visit
MCUXpresso Software and Tools
and also the help manual inside the tool package.
Original Attachment has been moved to: LPC54608J512_Project.zip
