AMF-DES-T2001 - Power Distribution Made Easy
This presentation will present a simple EM physics and geometry based approach to designing power distribution networks on PCBs. From input power connection to the IC die, the simple rules discussed can be used to reduce power supply noise and improve EMC.
%3CLINGO-SUB%20id%3D%22lingo-sub-1122465%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAMF-DES-T2001%20-%20Power%20Distribution%20Made%20Easy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122465%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20presentation%20will%20present%20a%20simple%20EM%20physics%20and%20geometry%20based%20approach%20to%20designing%20power%20distribution%20networks%20on%20PCBs.%20From%20input%20power%20connection%20to%20the%20IC%20die%2C%20the%20simple%20rules%20discussed%20can%20be%20used%20to%20reduce%20power%20supply%20noise%20and%20improve%20EMC.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1122465%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20presentation%20will%20present%20a%20simple%20EM%20physics%20and%20geometry%20based%20approach%20to%20designing%20power%20distribution%20networks%20on%20PCBs.%20From%20input%20power%20connection%20to%20the%20IC%20die%2C%20the%20simple%20rules%20discussed%20can%20be%20used%20to%20reduce%20power%20supply%20noise%20and%20improve%20EMC.%3C%2FP%3E%3C%2FLINGO-TEASER%3E
No ratings
Version history
Last update:
‎10-24-2016 03:47 PM
Updated by:
