Example MPC5777C MCAN simpleTXRX GHS616
* Detailed Description:
* Configures the MCANs to transmit and receive a CAN message.
* In this config, MCAN_0 transmits a message. MCAN_1 receives the message.
* MCAN_0 sends message each 1sec. This interval is generated by PIT.
* Single TX buffer is used to send n bytes. The message ID is changed for each
* transmission. Two standard and 2 extended IDs are sent.
* MCAN_1 is configured to receive a message, SW polling is used.
* There are 2 standard and 2 extended ID filter tables defined. Classic filter
* configuration is set, means filter ID & mask.
* Messages with matched standard ID are received into RXFIFO_0, messages with matched
* extended ID then stored in RXFIFO_1.
* EVB connection:
* J37 and J38 to position 2-3 to connect MCAN1 TX/RX to transceiver
* CAN0-CANH on P15-1 to CAN1-CANH on P14-1
* CAN0-CANL on P15-2 to CAN1-CANL on P14-2
* Test HW:         MPC5777C-512DS Rev.A + MPC57xx MOTHER BOARD Rev.C
* MCU:             PPC5777CMM03 2N45H CTZZS1521A
* Fsys:            PLL1 = core_clk = 264MHz, PLL0 = 192MHz
* Debugger:        Lauterbach Trace32
* Target:          internal_FLASH
* Terminal:        19200-8-no parity-1 stop bit-no flow control on eSCI_A
*           use USB connector (J21) on minimodule
* EVB connection:  ETPUA30 (PortP P23-15) --> USER_LED_1 (P7-1)
*                  ETPUA31 (PortP P23-14) --> USER_LED_2 (P7-2)
附件
评论
Hello Petr, can you help me about a first experiment with your code?
I 'm trying to load the .elf attached into your zip and I note that no activity is present on PIN CAN TX of the uP.
Analyzing the code with trace32 I see that for a first time the microprocessor find  MCAN_0.TXBRP.R=0 and it will execute the code here reported (it is your), but no activity I see in the CAN TX PIN of UP...and after this iteration at the next iteration it will be alwasy find MCAN_0.TXBRP.R=1.
if (MCAN_0.TXBRP.R == 0)
     ....code of your example
    MCAN_0.TXBAR.R = 0x1; // start transmission for M_CAN0 TX buffer 0
Have you any ideas?
I must say that my sample of uP is marked as SPC5777CK3MME3....i.e. I think it has a very old version of chip.
Thanks in advance...and best regards.
Hi Petr,
                Just went through your example code and I noticed you had  mpc577xC.h file. Was this generated file  given by NXP, if yes can you please point me from where you got it ?
Hello Petr,
I cannot receives any  CAN-Message with your code. I use the MPC5777C-516DS evaluation board. I copy and paste your code in the SingleTogglePin example .
Please can you tell me what is wrong in my case ?
%3CLINGO-SUB%20id%3D%22lingo-sub-1109280%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%A4%BA%E4%BE%8B%20MPC5777C%20MCAN%20simpleTXRX%20GHS616%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109280%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3CBR%20%2F%3E%20*%20%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%EF%BC%9A%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%20%E9%85%8D%E7%BD%AE%20MCAN%20%E6%9D%A5%E4%BC%A0%E8%BE%93%E5%92%8C%E6%8E%A5%E6%94%B6%20CAN%20%E6%B6%88%E6%81%AF%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E%20*%20%E5%9C%A8%E6%AD%A4%E9%85%8D%E7%BD%AE%E4%B8%AD%EF%BC%8CMCAN_0%20%E4%BC%A0%E8%BE%93%E4%B8%80%E6%9D%A1%E6%B6%88%E6%81%AF%E3%80%82MCAN_1%E6%8E%A5%E6%94%B6%E6%B6%88%E6%81%AF%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E%20*%20MCAN_0%20%E6%AF%8F%201%20%E7%A7%92%E5%8F%91%E9%80%81%E4%B8%80%E6%AC%A1%E6%B6%88%E6%81%AF%E3%80%82%E8%AF%A5%E9%97%B4%E9%9A%94%E7%94%B1%20PIT%20%E7%94%9F%E6%88%90%E3%80%82%3CBR%20%2F%3E%20*%20%E5%8D%95%E4%B8%AA%20TX%20%E7%BC%93%E5%86%B2%E5%8C%BA%E7%94%A8%E4%BA%8E%E5%8F%91%E9%80%81%20n%20%E4%B8%AA%E5%AD%97%E8%8A%82%E3%80%82%E6%AF%8F%E6%AC%A1%3CBR%20%2F%3E*%20%E4%BC%A0%E6%92%AD%E3%80%82%E5%8F%91%E9%80%81%E4%B8%A4%E4%B8%AA%E6%A0%87%E5%87%86%20ID%20%E5%92%8C%202%20%E4%B8%AA%E6%89%A9%E5%B1%95%20ID%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E%20*%20MCAN_1%20%E9%85%8D%E7%BD%AE%E4%B8%BA%E6%8E%A5%E6%94%B6%E6%B6%88%E6%81%AF%EF%BC%8C%E4%BD%BF%E7%94%A8%20SW%20%E8%BD%AE%E8%AF%A2%E3%80%82%3CBR%20%2F%3E*%20%E5%AE%9A%E4%B9%89%E4%BA%862%E4%B8%AA%E6%A0%87%E5%87%86%E5%92%8C2%E4%B8%AA%E6%89%A9%E5%B1%95ID%E8%BF%87%E6%BB%A4%E8%A1%A8%E3%80%82%E7%BB%8F%E5%85%B8%E8%BF%87%E6%BB%A4%E5%99%A8%3CBR%20%2F%3E*%20%E9%85%8D%E7%BD%AE%E5%B7%B2%E8%AE%BE%E7%BD%AE%EF%BC%8C%E8%A1%A8%E7%A4%BA%E8%BF%87%E6%BB%A4%E5%99%A8%20ID%20%E5%92%8C%E6%8E%A9%E7%A0%81%E3%80%82%3CBR%20%2F%3E*%20%E5%85%B7%E6%9C%89%E5%8C%B9%E9%85%8D%E6%A0%87%E5%87%86%20ID%20%E7%9A%84%E6%B6%88%E6%81%AF%E8%A2%AB%E6%8E%A5%E6%94%B6%E5%88%B0%20RXFIFO_0%20%E4%B8%AD%EF%BC%8C%E5%85%B7%E6%9C%89%E5%8C%B9%E9%85%8D%3CBR%20%2F%3E*%20%E6%89%A9%E5%B1%95ID%E7%84%B6%E5%90%8E%E5%AD%98%E5%82%A8%E5%9C%A8RXFIFO_1%E4%B8%AD%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E%20*%20EVB%E8%BF%9E%E6%8E%A5%EF%BC%9A%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%20J37%20%E5%92%8C%20J38%20%E8%87%B3%E4%BD%8D%E7%BD%AE%202-3%EF%BC%8C%E5%B0%86%20MCAN1%20TX%2FRX%20%E8%BF%9E%E6%8E%A5%E8%87%B3%E6%94%B6%E5%8F%91%E5%99%A8%3CBR%20%2F%3E*%3CBR%20%2F%3E%20*%20P15-1%20%E4%B8%8A%E7%9A%84%20CAN0-CANH%20%E8%87%B3%20P14-1%20%E4%B8%8A%E7%9A%84%20CAN1-CANH%3CBR%20%2F%3E%20*%20P15-2%20%E4%B8%8A%E7%9A%84%20CAN0-CANL%20%E8%87%B3%20P14-2%20%E4%B8%8A%E7%9A%84%20CAN1-CANL%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%20----------------------------------------------------------------------------------------------%3CBR%20%2F%3E%20*%20%E6%B5%8B%E8%AF%95%E7%A1%AC%E4%BB%B6%EF%BC%9AMPC5777C-512DS%20Rev.A%20%2B%20MPC57xx%20%E4%B8%BB%E6%9D%BF%20Rev.C%3CBR%20%2F%3E%20*%20%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%3A%20PPC5777CMM03%202N45H%20CTZZS1521A%3CBR%20%2F%3E%20*%E7%B3%BB%E7%BB%9F%E9%A2%91%E7%8E%87%EF%BC%9APLL1%20%3D%20core_clk%20%3D%20264MHz%EF%BC%8CPLL0%20%3D%20192MHz%3CBR%20%2F%3E%20*%20%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%9ALauterbach%20Trace32%3CBR%20%2F%3E%20*%20%E7%9B%AE%E6%A0%87%EF%BC%9Ainternal_FLASH%3CBR%20%2F%3E%20*%20%E7%BB%88%E7%AB%AF%EF%BC%9A19200-8-%E6%97%A0%E5%A5%87%E5%81%B6%E6%A0%A1%E9%AA%8C-1%20%E5%81%9C%E6%AD%A2%E4%BD%8D-eSCI_A%20%E4%B8%8A%E6%97%A0%E6%B5%81%E9%87%8F%E6%8E%A7%E5%88%B6%3CBR%20%2F%3E*%20%E4%BD%BF%E7%94%A8%E5%BE%AE%E5%9E%8B%E6%A8%A1%E5%9D%97%E4%B8%8A%E7%9A%84%20USB%20%E8%BF%9E%E6%8E%A5%E5%99%A8%20(J21)%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%20EVB%20%E8%BF%9E%E6%8E%A5%EF%BC%9AETPUA30%EF%BC%88PortP%20P23-15%EF%BC%89--%26gt%3B%20USER_LED_1%EF%BC%88P7-1%EF%BC%89%3CBR%20%2F%3E%20*%20ETPUA31%20(%E7%AB%AF%E5%8F%A3%20P23-14)%20--%26gt%3B%20USER_LED_2%20(P7-2)%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1109280%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3CBR%20%2F%3E%20*%20%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%EF%BC%9A%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%20%E9%85%8D%E7%BD%AE%20MCAN%20%E6%9D%A5%E4%BC%A0%E8%BE%93%E5%92%8C%E6%8E%A5%E6%94%B6%20CAN%20%E6%B6%88%E6%81%AF%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E%20*%20%E5%9C%A8%E6%AD%A4%E9%85%8D%E7%BD%AE%E4%B8%AD%EF%BC%8CMCAN_0%20%E4%BC%A0%E8%BE%93%E4%B8%80%E6%9D%A1%E6%B6%88%E6%81%AF%E3%80%82MCAN_1%E6%8E%A5%E6%94%B6%E6%B6%88%E6%81%AF%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E%20*%20MCAN_0%20%E6%AF%8F%201%20%E7%A7%92%E5%8F%91%E9%80%81%E4%B8%80%E6%AC%A1%E6%B6%88%E6%81%AF%E3%80%82%E8%AF%A5%E9%97%B4%E9%9A%94%E7%94%B1%20PIT%20%E7%94%9F%E6%88%90%E3%80%82%3CBR%20%2F%3E%20*%20%E5%8D%95%E4%B8%AA%20TX%20%E7%BC%93%E5%86%B2%E5%8C%BA%E7%94%A8%E4%BA%8E%E5%8F%91%E9%80%81%20n%20%E4%B8%AA%E5%AD%97%E8%8A%82%E3%80%82%E6%AF%8F%E6%AC%A1%3CBR%20%2F%3E*%20%E4%BC%A0%E6%92%AD%E3%80%82%E5%8F%91%E9%80%81%E4%B8%A4%E4%B8%AA%E6%A0%87%E5%87%86%20ID%20%E5%92%8C%202%20%E4%B8%AA%E6%89%A9%E5%B1%95%20ID%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E%20*%20MCAN_1%20%E9%85%8D%E7%BD%AE%E4%B8%BA%E6%8E%A5%E6%94%B6%E6%B6%88%E6%81%AF%EF%BC%8C%E4%BD%BF%E7%94%A8%20SW%20%E8%BD%AE%E8%AF%A2%E3%80%82%3CBR%20%2F%3E*%20%E5%AE%9A%E4%B9%89%E4%BA%862%E4%B8%AA%E6%A0%87%E5%87%86%E5%92%8C2%E4%B8%AA%E6%89%A9%E5%B1%95ID%E8%BF%87%E6%BB%A4%E8%A1%A8%E3%80%82%E7%BB%8F%E5%85%B8%E8%BF%87%E6%BB%A4%E5%99%A8%3CBR%20%2F%3E*%20%E9%85%8D%E7%BD%AE%E5%B7%B2%E8%AE%BE%E7%BD%AE%EF%BC%8C%E8%A1%A8%E7%A4%BA%E8%BF%87%E6%BB%A4%E5%99%A8%20ID%20%E5%92%8C%E6%8E%A9%E7%A0%81%E3%80%82%3CBR%20%2F%3E*%20%E5%85%B7%E6%9C%89%E5%8C%B9%E9%85%8D%E6%A0%87%E5%87%86%20ID%20%E7%9A%84%E6%B6%88%E6%81%AF%E8%A2%AB%E6%8E%A5%E6%94%B6%E5%88%B0%20RXFIFO_0%20%E4%B8%AD%EF%BC%8C%E5%85%B7%E6%9C%89%E5%8C%B9%E9%85%8D%3CBR%20%2F%3E*%20%E6%89%A9%E5%B1%95ID%E7%84%B6%E5%90%8E%E5%AD%98%E5%82%A8%E5%9C%A8RXFIFO_1%E4%B8%AD%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E%20*%20EVB%E8%BF%9E%E6%8E%A5%EF%BC%9A%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%20J37%20%E5%92%8C%20J38%20%E8%87%B3%E4%BD%8D%E7%BD%AE%202-3%EF%BC%8C%E5%B0%86%20MCAN1%20TX%2FRX%20%E8%BF%9E%E6%8E%A5%E8%87%B3%E6%94%B6%E5%8F%91%E5%99%A8%3CBR%20%2F%3E*%3CBR%20%2F%3E%20*%20P15-1%20%E4%B8%8A%E7%9A%84%20CAN0-CANH%20%E8%87%B3%20P14-1%20%E4%B8%8A%E7%9A%84%20CAN1-CANH%3CBR%20%2F%3E%20*%20P15-2%20%E4%B8%8A%E7%9A%84%20CAN0-CANL%20%E8%87%B3%20P14-2%20%E4%B8%8A%E7%9A%84%20CAN1-CANL%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%20----------------------------------------------------------------------------------------------%3CBR%20%2F%3E%20*%20%E6%B5%8B%E8%AF%95%E7%A1%AC%E4%BB%B6%EF%BC%9AMPC5777C-512DS%20Rev.A%20%2B%20MPC57xx%20%E4%B8%BB%E6%9D%BF%20Rev.C%3CBR%20%2F%3E%20*%20%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%3A%20PPC5777CMM03%202N45H%20CTZZS1521A%3CBR%20%2F%3E%20*%E7%B3%BB%E7%BB%9F%E9%A2%91%E7%8E%87%EF%BC%9APLL1%20%3D%20core_clk%20%3D%20264MHz%EF%BC%8CPLL0%20%3D%20192MHz%3CBR%20%2F%3E%20*%20%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%9ALauterbach%20Trace32%3CBR%20%2F%3E%20*%20%E7%9B%AE%E6%A0%87%EF%BC%9Ainternal_FLASH%3CBR%20%2F%3E%20*%20%E7%BB%88%E7%AB%AF%EF%BC%9A19200-8-%E6%97%A0%E5%A5%87%E5%81%B6%E6%A0%A1%E9%AA%8C-1%20%E5%81%9C%E6%AD%A2%E4%BD%8D-eSCI_A%20%E4%B8%8A%E6%97%A0%E6%B5%81%E9%87%8F%E6%8E%A7%E5%88%B6%3CBR%20%2F%3E*%20%E4%BD%BF%E7%94%A8%E5%BE%AE%E5%9E%8B%E6%A8%A1%E5%9D%97%E4%B8%8A%E7%9A%84%20USB%20%E8%BF%9E%E6%8E%A5%E5%99%A8%20(J21)%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%20EVB%20%E8%BF%9E%E6%8E%A5%EF%BC%9AETPUA30%EF%BC%88PortP%20P23-15%EF%BC%89--%26gt%3B%20USER_LED_1%EF%BC%88P7-1%EF%BC%89%3CBR%20%2F%3E%20*%20ETPUA31%20(%E7%AB%AF%E5%8F%A3%20P23-14)%20--%26gt%3B%20USER_LED_2%20(P7-2)%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1109280%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%A6%82%E8%BF%B0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1109283%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPC5777C%20MCAN%20simpleTXRX%20GHS616%E7%A4%BA%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109283%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CPetr%EF%BC%8C%20%3C%2FP%3E%3CP%3E%E6%88%91%E6%97%A0%E6%B3%95%E9%80%9A%E8%BF%87%E6%82%A8%E7%9A%84%E4%BB%A3%E7%A0%81%E6%8E%A5%E6%94%B6%E4%BB%BB%E4%BD%95%20CAN%20%E6%B6%88%E6%81%AF%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8MPC5777C-516DS%E8%AF%84%E4%BC%B0%E6%9D%BF%E3%80%82%E6%88%91%E5%B0%86%E6%82%A8%E7%9A%84%E4%BB%A3%E7%A0%81%E5%A4%8D%E5%88%B6%E5%B9%B6%E7%B2%98%E8%B4%B4%E5%88%B0%20SingleTogglePin%20%E7%A4%BA%E4%BE%8B%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E9%97%AE%E6%82%A8%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E6%88%91%E7%9A%84%E6%83%85%E5%86%B5%E5%87%BA%E4%BA%86%E4%BB%80%E4%B9%88%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1109282%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPC5777C%20MCAN%20simpleTXRX%20GHS616%E7%A4%BA%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109282%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8CPetr%EF%BC%8C%3CBR%20%2F%3E%E5%88%9A%E5%88%9A%E6%B5%8F%E8%A7%88%E4%BA%86%E6%82%A8%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%8C%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%E6%82%A8%E6%9C%89%20mpc577xC.h%E6%96%87%E4%BB%B6%E3%80%82%E8%BF%99%E4%B8%AA%E7%94%9F%E6%88%90%E7%9A%84%E6%96%87%E4%BB%B6%E6%98%AF%E7%94%B1%20NXP%20%E6%8F%90%E4%BE%9B%E7%9A%84%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C%E6%82%A8%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E6%82%A8%E4%BB%8E%E5%93%AA%E9%87%8C%E5%BE%97%E5%88%B0%E5%AE%83%E7%9A%84%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎09-20-2016 02:33 AM
更新人:
