S12Z voltage measurement
Document created by Radek Sestak Employee on Aug 22, 2016Last modified by Radek Sestak Employee on Jan 16, 2020
Version 4Show Document
  • View in full screen mode
The ADC measurement is always relative – relative to your voltage reference.
The most of the applications don't allow to use accurate and expensive voltage reference. In that case, VDDA is used as the reference for ADC measurement.
Since the operational VSUP range starts from 3.5V and accuracy of the voltage regulator is limited, we should use internal bandgap reference for compensating ADC voltage results. The bandgap voltage VBG has a narrow variation over temperature and external voltage supply.
The example shows how to compensate ADC results by additional bandgap voltage measurement.
6 people found this helpful
Outcomes
