PMIC PF3000/3001 + i.MX 6UL Resources
PMIC PF3000/3001 + i.MX 6UL Resources:
Upload the latest version D as enclosed, SCH-29105 KIT6UL_3000EVM Version D and SCH-29105 KIT6UL_3000EVM Version D.
The attachment SCH-29105 KIT6UL-3000EVM Version C.zip includes i.MX 6UL 14x14 + PMIC PF3000(KIT6UL-3000EVM, SCH-29105 Rev.C) related files:
No.Files in SCH-29105 KIT6UL-3000EVM Version C.zip
1SPF-29105_C.pdf is the corresponding schematic PDF version.
2
SCH-29105_C.zip is the schematic.
3
LAY-29105_C.zip is the PCB layout.
4750-29105_C BOM.xls is the BOM.
Its i.MX 6UL 14x14 + PMIC PF3000 BSP:
  1. Apply PF3000 driver patch in imx_3.14.52_1.1.0_ga
    http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/commit/?h=imx_3.14.52_1.1.0_ga&id=e5a7a72cd51a585b8f1a1e299bf88fff44b94440
    Apply
    0001-add-pf3000-on-imx6ul-evk-board.patch, see the attachment.
    Apply 0003-correct-arm-soc-regulator-for-pf300.patch, see the attachment.
    Apply 0001-u-boot-add-pf3000-support-on-imx6ul-14x14-evk-board.patch, see the attachment.
   2.  Update customer board dts as the above 0001-add-pf3000-on-imx6ul-evk-board.patch.
The attachment SCH-29090 KIT6UL-3001EVM Version C.zip includes i.MX 6UL 14x14 + PMIC PF3001(KIT6UL-3001EVM, SCH-29090 Rev.C) related files:
No.Files in SCH-29090 KIT6UL-3001EVM Version C.zip
1SPF-29090_C.pdf is the corresponding schematic PDF version.
2
SCH-29090_C.zip is the schematic.
3
LAY-29090_C.zip is the PCB layout.
4750-29090_C BOM.xls is the BOM.
Its i.MX 6UL 14x14 + PMIC PF3001 BSP:
  1. Apply PF3001 driver patch in imx_3.14.52_1.1.0_ga http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/commit/drivers/regulator/pfuze100-regula...d=19708058f049be9a5dcc81943d1b9a14080367e8
  2. Update PF3001 dts board file as customer board dts.
PMIC team: Sean Liu
Comments
Hi NXP-Team,
would it be possible to get some Altium (schematic + board) files for this two boards (29090 + 29105).
We only support the board through Cadence design tools which was limited by company.
Some customers export to Altium Design files from Cadence Allegro files, see the link https://community.nxp.com/thread/377756?et=watches.email.outcome, this may be helpful.
Sean Liu
[email protected]
PMIC team
I would suggest some modifications to above patches (sorry for ugly indentation but cannot attach files into comments):
- first edit is for patch PF3001 driver patch in imx_3.14.52_1.1.0_ga (line numbers differ):
diff --git a/drivers/regulator/pfuze100-regulator.c b/drivers/regulator/pfuze100-regulator.c
index 8903399cd87a..2a6fae48235d 100644
--- a/drivers/regulator/pfuze100-regulator.c
+++ b/drivers/regulator/pfuze100-regulator.c
@@ -130,8 +130,26 @@ static int pfuze100_set_ramp_delay(struct regulator_dev *rdev, int ramp_delay)
int id = rdev_get_id(rdev);
unsigned int ramp_bits;
int ret;
+ bool reg_has_ramp_delay;
- if (id < PFUZE100_SWBST) {
+ switch (pfuze100->chip_id) {
+ case PFUZE3001:
+ /* no dynamic voltage scaling for PF3001 */
+ reg_has_ramp_delay = false;
+ break;
+ case PFUZE3000:
+ reg_has_ramp_delay = (id < PFUZE3000_SWBST);
+ break;
+ case PFUZE200:
+ reg_has_ramp_delay = (id < PFUZE200_SWBST);
+ break;
+ case PFUZE100:
+ default:
+ reg_has_ramp_delay = (id < PFUZE100_SWBST);
+ break;
+ if (reg_has_ramp_delay) {
ramp_delay = 12500 / ramp_delay;
ramp_bits = (ramp_delay >> 1) - (ramp_delay >> 3);
ret = regmap_update_bits(pfuze100->regmap,
@@ -139,8 +157,9 @@ static int pfuze100_set_ramp_delay(struct regulator_dev *rdev, int ramp_delay)
0xc0, ramp_bits << 6);
if (ret < 0)
dev_err(pfuze100->dev, "ramp failed, err %d\n", ret);
- } else
+ } else {
ret = -EACCES;
return ret;
this is needed because of regulator IDs are different for each PFuze, so cannot test condition on PFUZE100_SWBST id only.
- second and third edits are:
@@ -360,7 +379,6 @@ static struct pfuze_regulator pfuze3001_regulators[] = {
PFUZE100_SWB_REG(PFUZE3001, SW2, PFUZE100_SW2VOL, 0x7, pfuze3000_sw2lo),
PFUZE3000_SW3_REG(PFUZE3001, SW3, PFUZE100_SW3AVOL, 900000, 1650000, 50000),
PFUZE100_SWB_REG(PFUZE3001, VSNVS, PFUZE100_VSNVSVOL, 0x7, pfuze100_vsnvs),
- PFUZE100_FIXED_REG(PFUZE3001, VREFDDR, PFUZE100_VREFDDRCON, 750000),
PFUZE100_VGEN_REG(PFUZE3001, VLDO1, PFUZE100_VGEN1VOL, 1800000, 3300000, 100000),
PFUZE100_VGEN_REG(PFUZE3001, VLDO2, PFUZE100_VGEN2VOL, 800000, 1550000, 50000),
PFUZE3000_VCC_REG(PFUZE3001, VCCSD, PFUZE100_VGEN3VOL, 2850000, 3300000, 150000),
@@ -434,7 +452,6 @@ static struct of_regulator_match pfuze3001_matches[] = {
{ .name = "sw2", },
{ .name = "sw3", },
{ .name = "vsnvs", },
- { .name = "vrefddr", },
{ .name = "vldo1", },
{ .name = "vldo2", },
{ .name = "vccsd", },
diff --git a/include/linux/regulator/pfuze100.h b/include/linux/regulator/pfuze100.h
index 8cd1874fd29b..58ca77e73c23 100644
--- a/include/linux/regulator/pfuze100.h
+++ b/include/linux/regulator/pfuze100.h
@@ -67,13 +67,12 @@
#define PFUZE3001_SW2 1
#define PFUZE3001_SW3 2
#define PFUZE3001_VSNVS 3
-#define PFUZE3001_VREFDDR 4
-#define PFUZE3001_VLDO1 5
-#define PFUZE3001_VLDO2 6
-#define PFUZE3001_VCCSD 7
-#define PFUZE3001_V33 8
-#define PFUZE3001_VLDO3 9
-#define PFUZE3001_VLDO4 10
+#define PFUZE3001_VLDO1 4
+#define PFUZE3001_VLDO2 5
+#define PFUZE3001_VCCSD 6
+#define PFUZE3001_V33 7
+#define PFUZE3001_VLDO3 8
+#define PFUZE3001_VLDO4 9
since PF3001 doesn't have VREFDDR regulator. Consequently to this edit, example dts file contained into imx6ul-14x14-evk-PF3001 dts.zip should be updated, so
- fourth edit is:
--- imx6ul-14x14-evk-PF3001.dts 2016-03-01 11:34:06.000000000 +0100
+++ imx6ul-14x14-evk-PF3001_edit.dts 2017-07-17 13:57:31.294592294 +0200
@@ -427,7 +427,6 @@
regulator-max-microvolt = <1475000>;
regulator-boot-on;
regulator-always-on;
- regulator-ramp-delay = <6250>;
sw2_reg: sw2 {
@@ -450,11 +449,6 @@
regulator-boot-on;
- vref_reg: vrefddr {
- regulator-boot-on;
- regulator-always-on;
vgen1_reg: vldo1 {
regulator-min-microvolt = <1800000>;
regulator-ramp-delay property should be removed because PF3001 does not have dynamic voltage scaling.
- fifth edit:
diff diff --git a/Documentation/devicetree/bindings/regulator/pfuze100.txt b/Documentation/devicetree/bindings/regulator/pfuze100.txt
index 997174a46518..f4a416c0c0fb 100644
--- a/Documentation/devicetree/bindings/regulator/pfuze100.txt
+++ b/Documentation/devicetree/bindings/regulator/pfuze100.txt
@@ -1,7 +1,7 @@
PFUZE100 family of regulators
Required properties:
-- compatible: "fsl,pfuze100", "fsl,pfuze200", "fsl,pfuze3000"
+- compatible: "fsl,pfuze100", "fsl,pfuze200", "fsl,pfuze3000", "fsl,pfuze3001"
- reg: I2C slave address
- fsl,lpsr-mode: some registers need to be saved and restored in lpsr mode
for pfuze3000
@@ -18,6 +18,8 @@ Required child node:
sw1ab,sw2,sw3a,sw3b,swbst,vsnvs,vrefddr,vgen1~vgen6
--PFUZE3000
sw1a,sw1b,sw2,sw3,swbst,vsnvs,vrefddr,vldo1,vldo2,vccsd,v33,vldo3,vldo4
+ --PFUZE3001
+ sw1,sw2,sw3,vsnvs,vldo1,vldo2,vccsd,v33,vldo3,vldo4
Each regulator is defined using the standard binding for regulators.
@@ -299,3 +301,76 @@ Example 3: PFUZE3000
+Example 4: PFUZE3001
+ pmic: pfuze3001@08 {
+ compatible = "fsl,pfuze3001";
+ reg = <0x08>;
+ regulators {
+ sw1a_reg: sw1 {
+ regulator-min-microvolt = <700000>;
+ regulator-max-microvolt = <1475000>;
+ regulator-boot-on;
+ regulator-always-on;
+ sw2_reg: sw2 {
+ regulator-min-microvolt = <2500000>;
+ regulator-max-microvolt = <3300000>;
+ sw3a_reg: sw3 {
+ regulator-min-microvolt = <900000>;
+ regulator-max-microvolt = <1650000>;
+ snvs_reg: vsnvs {
+ regulator-min-microvolt = <1000000>;
+ regulator-max-microvolt = <3000000>;
+ vgen1_reg: vldo1 {
+ regulator-min-microvolt = <1800000>;
+ vgen2_reg: vldo2 {
+ regulator-min-microvolt = <800000>;
+ regulator-max-microvolt = <1550000>;
+ vgen3_reg: vccsd {
+ regulator-min-microvolt = <2850000>;
+ vgen4_reg: v33 {
+ vgen5_reg: vldo3 {
+ vgen6_reg: vldo4 {
I hope this could help.
Mauro
No ratings
Version history
Last update:
‎06-06-2016 08:27 PM
Updated by:
