Example MPC5748G BCTU GHS614
File uploaded by Peter Vlna Employee on Mar 22, 2016Last modified by Peter Vlna Employee on Mar 22, 2016
Version 3Show Document
  • View in full screen mode
* Detailed Description:
* This example implements ADC driver and demonstrated the usage of ADC in BCTU mode.
* When PIT timer exceeds the trigger is sent to BCTU and BCTU triggers ADC_0 conversion.
* Test HW:  MPC57xx
* Maskset:  1N81M
* Target :  SRAM
* Fsys:     160 MHz PLL
Revision History:
1.0     Oct-29-2014     b21190(Vlna Peter)  Initial Version
1.1    Nov-20-2014    b21190(Vlna Peter)  Modified for Cut2.0
1.2    Nov-20-2014    b21190(Vlna Peter)  Added SWT_0 dissabling in startup
1.3    Mar-10-2016    b21190(Vlna Peter)  Fixed clock configuraion for PLL
1.4    Mar-10-2016    b21190(Vlna Peter)  Added ADC driver
1.5    Mar-16-2016    b21190(Vlna Peter)  Added BCTU and PIT drivers
Outcomes
