Example MPC5775K PinToggleStationery S32DS_1.0
File uploaded by Martin Kovar Employee on Feb 9, 2016Last modified by Martin Kovar Employee on Apr 9, 2019
Version 3Show Document
  • View in full screen mode
* Detailed Description:
* Application performs basic initialization, setup PLL to maximum allowed freq.,
* start both Z7 cores, interrupts initialization, blinking three LED by interrupts,
* initializes and display notice via UART terminal and then terminal ECHO.
* Each core serves one interrupt and one LED.
* The example configures the device for maximum performance by initialization of
* instruction/data cache and enabling of branch prediction for each core
* (startup.s files).
* Test HW:         MPC5775K-356DS, MPC57xx Motherboard
* MCU:             PPC5775KMMY3A 0N38M
* Terminal:        19200-8-no parity-1 stop bit-no flow control on LINFlexD_0
* Fsys:            PLL0 266MHz
*                    Z4 Core 133MHz
*                    Both Z7 Cores 266MHz
* Debugger:        Lauterbach Trace32
*                  PeMicro USB-ML-PPCNEXUS
* Target:          internal_FLASH (debug mode, release mode)
* EVB connection:  USER LED1 connected to P19.0, LED2 connected to P19.5
*                  LED3 connected to P19.8
*                  For correct UART functionality connect:
*                  J14.2 to P12.6
*                  J13.2 to P12.7
Outcomes
