Example MPC5643L-LVD_HVD_self_test+FCCU_F CW210
File uploaded by David Tosenovjan Employee on Feb 9, 2016
Version 1Show Document
  • View in full screen mode
* Detailed Description:
* Inject and handles HVD and LVD faults. Application also configures FCCU_F pins
* to see possible faults externally - normally these two pins toggles antiphase,
* in case error these pins toggles inphase. If you step the code not allowing
* alarm interrupt to be handled on time, device goes to safe mode and FCCU_F
* pins toggles in phase.
* Test HW:         xPC564xLKIT, PPC5643L Cut3 silicon
* Target :         internal_FLASH, RAM
* Fsys:            120 MHz PLL0
* Debugger:        Lauterbach Trace32
*                  PeMicro USB-ML-PPCNEXUS
* Terminal:        19200-8-no parity-1 stop bit-no flow control via LINFlex0
* EVB connection:  FCCU_F0 and FCCU_F1 connected to the scope - pay attention to
*                  J16 and J18 jumpers on mini-module (FCCU_F0 and FCCU_F1).
Outcomes
