AndroidSDCARDMirrorCreator
Document created by Biyong Sun Employee on Jan 7, 2016Last modified by Adrian Puga Candelario on Jan 21, 2020
Version 21Show Document
  • View in full screen mode
This tool is also for emmc user partition mirror. Just give this tool the emmc files.
The typical use case is for emmc mass production by emmc offline programming.
Ver 0.4.0
2/14/2017
Support Android 7 Nougat.
AndroidSDCARDMirrorCreator_Version_0.4.0_02142017.tgz
Ver 0.3.2:
6/13/2016
Using static link simg2img
AndroidSDCARDMirrorCreator_Version_0.3.2_06132016.tgz
Ver 0.3.1:
5/31/2016
Remove some redundent code
AndroidSDCARDMirrorCreator_Version_0.3.1_05312016.tgz
Ver 0.3:
5/25/2016
Add Marshmallow partition layout
AndroidSDCARDMirrorCreator_Version_0.3_05252016.tgz
Ver 0.2:
Add Lollipop partition layout
1. Directory
|-- AndroidSDCARDMirrorCreator.sh        --- main script
|-- CFG.INC                              --- configuration file
|-- KitKat_LAYOUT.INC                    --- KitKat partition layout
|-- LAYOUT.INC -> Lollipop_LAYOUT.INC    --- symbol link to partition layout
|-- Lollipop_LAYOUT.INC                  --- Lollipop partition layout
`-- readme.txt                           --- this file
2. Need "root" run or "sudo" to run
3. parted and kpartx must be installed
   sudo apt-get instal parted kpartx
4. test pass under the debian 8.2 and ubuntu 12.04
5. The AndroidSDCARDMirrorCreator.sh will look for LAYOUT.INC.
   please make symbol link to the correct partition layout.
   The default symbol link has created for Lollipop_LAYOUT.INC (LAYOUT.INC -> Lollipop_LAYOUT.INC)
6. Command
   AndroidSDCARDMirrorCreator.sh -c
   AndroidSDCARDMirrorCreator.sh -p
7. Example:
   Suppose
   The AndroidSDCARDMirrorCreator directory is in
   ~/AndroidSDCARDMirrorCreator
   The Android Images are in
   ~/SD and ~/eMMC
   Sdcdard Mirror:
   cd ~/SD
   ~/AndroidSDCARDMirrorCreator/AndroidSDCARDMirrorCreator.sh -c
   eMMC Mirror:
   cd ~/eMMC
8. Once the Mirror has been created. Can be reused. Just use kpartx.
2 people found this helpful
Outcomes
