Getting started with CDE in Kinetis Design Studio
Hello community!
Attached is a document that introduces the usage of Component Development Environment (CDE) by creating a software component that will use the Kinetis Software Development Kit (KSDK) drivers to control a 16x2 LCD.
The code provided on the below document will be used as starting point for the creation of the component:
Driving 16x2 LCD using KSDK drivers:
https://community.freescale.com/docs/DOC-329190
Contents:
1. Glossary
2. Overview and concepts
2.1 Processor Expert Software
2.1.1 Embedded Components
3. Creating a new embedded component
3.1 Adding properties
3.2 Adding a method
3.3 Adding inherited components
4. Testing component.
Appendix A - References
I hope you can benefit from this post, if you have questions please let me know.
Best Regards!
Carlos Mendoza
No ratings
Version history
Last update:
‎01-06-2016 03:09 PM
Updated by:
