Start working with NXP Touch Software library
Document created by ZhangJennie Employee on Dec 31, 2015Last modified by Diana Torres on Feb 28, 2017
Version 2Show Document
  • View in full screen mode
NXP Touch software ( ) is designed to speed development of your touch applications and is ideal for use with Kinetis MCUs. Because it is available as both a binary library and also in source code, many customers like using it.
Recently I received several cases from customers that some of our customers can’t run this package successfully. So I start to write this document of how to use this package to make this package “run” on your board!
