LAMA's S12XE unofficial examples
I've just went through my PC and put some examples here. ( I made them "a few" days ago.)
The files are presented with extension BMP because of some firewals.
AN3490.pdf
DOC-XEP100-MMC-Memory_Map-Common_Map-V5_0-MSExcel.xls
EEE.xls
TN263-CodeWarrior IDE.pdf
XEP100 - EEPROM Direct Access - CW45.zip
XEP100 - Initial data in Emulated EEPROM - CW47.zip
XEP100 - MPU - CW47.ZIP
XEP100 - RAM addressing - CW45.zip
XEP100 - SCI - XonXoff_poll - CW47.zip
XEP100 - Security + Backdoor Key Access - CW47.zip
XEP100-ATD wakes up from STOP - CW47.zip
XEP100-ATD-ATDandXGATEandSharedRAM-CW50.zip
XEP100-ATD-CH1toCH4-CW47.ZIP
XEP100-ATD-CH1toCH8-CW47.ZIP
XEP100-ATD-Cntnuos_SingleCh-v1_0-CW47_Data.zip
XEP100-ATD-Tmprture_bandgapV-v1_0-CW47_Data.zip
XEP100-BDM-BDMcommExample-CW50.zip
XEP100-BufferRAMasOneArray-CW51.zip
XEP100-BufferRAMasRAMonly-CW51.zip
XEP100-CAN-CAN0-RxTxIsrLoopback-CW47.zip
XEP100-CAN-CAN0-TxAtXGATE-CW51.zip
XEP100-CAN-CAN0CAN1 - CW45.ZIP
XEP100-CAN-CAN2CAN2-Identifiers SandX-loopback-CW51.zip
XEP100-CAN-CAN2CAN3-CW47.ZIP
XEP100-CAN-CAN2CAN3-FILTER-CW51.ZIP
XEP100-CAN-CAN2CAN3-Identifiers SandX-CW51.zip
XEP100-CAN-LoopbackInterrupt-CW51.zip
XEP100-CAN.ZIP
XEP100-CAN0 - CAN1 - CW45.ZIP
XEP100-CAN0-RxTxIsrLoopback-CW47.zip
XEP100-CAN0-RxTxIsrLoopbackXGATE-CW51.zip
XEP100-CAN0-TxAtXGATE-CW51.zip
XEP100-CRG-COP-CW47.ZIP
XEP100-CRG-PLL-Setup-CW47.zip
XEP100-EBI-MRAM256x16-CS0-CW51.zip
XEP100-EBI-MRAM256x16-CS2-CW51.zip
XEP100-ECT-ECTasPWM-CW47.zip
XEP100-ECT-FreqMeasurement-CW51.zip
XEP100-ECT-InputCapture-CW51.zip
XEP100-ECT-TIM.ZIP
XEP100-EEEPROM-Addressing-Lukas-CW46.zip
XEP100-EEEPROM-DataPlacement-CW51.zip
XEP100-EEEPROM-plusMPU-CW51.zip
XEP100-EEPROM-DirectAccess-CW51.zip
XEP100-EXBUS-EXRAM256x16-CS1-CW47.zip
XEP100-EXBUS-ExRam_MR2A16ACYS35-CS1-CW51.ZIP
XEP100-FLASH-PFLASH-CW47.ZIP
XEP100-FLASH-PFLASH-CW51.ZIP
XEP100-FLASH-PFLASH-PFlashInitData.zip
XEP100-FLASH-PFLASH_reading-CW47.zip
XEP100-GPIO-PJ2isr-CW47.zip
XEP100-GPIO-PortPisrXgate-CW51.zip
XEP100-ID-readPartID-CW47.zip
XEP100-IIC-Master4Flash24C16-CW51.zip
XEP100-INT-INTERRUPTNUMBER-CW51.ZIP
XEP100-INT-TRAPPROC-CW51.ZIP
XEP100-MDDC-delay generator-v1_0-CW47.zip
XEP100-MPU-MPU-CW47.ZIP
XEP100-PFLASH-CW47.ZIP
XEP100-PFLASH-CW51.ZIP
XEP100-PIM-PTPfunctions1-CW47.zip
XEP100-PIT-FLOATING PERIOD-CW51.ZIP
XEP100-PIT-SERIAL_DATA_OUT-CW45.ZIP
XEP100-PIT-XGATE-SEMAPHORES-CW51.ZIP
XEP100-PWM-dutyatXGATE-CW47.zip
XEP100-RAM-addressing-v1_0-CW51.zip
XEP100-RAM-RAMaddressing-CW45.zip
XEP100-SCI_PIT-CW47.zip
XEP100-SCI-ECHO-isr.zip
XEP100-SCI-ECHOatCPU-CW47.zip
XEP100-SCI-ECHOatCPUisr-CW47.zip
XEP100-SCI-ECHOatXGATEisr-CW47.zip
XEP100-SCI-Sci0transmitterOnXGATE-CW45.zip
XEP100-SCI-SciTx-CW45.zip
XEP100-SCI-SCI_PIT-CW47.zip
XEP100-SCI-XonXoff_poll-CW47.zip
XEP100-SciTx-CW45.zip
XEP100-SECURITY-BackdoorKeyAccess-CW47.zip
XEP100-STOP-ATDwakesUp-CW47.zip
XEP100-STOP-RTIwakesUp-CW51.zip
XEP100-STOP-WakeUp-CW47.zip
XEP100-STOP_and_ API_and_PLL-CW47.zip
XEP100-STOP_and_XIRQ_and_PLL-CW47.zip
XEP100-TIM-10msIsr-CW47.zip
XEP100-TIM-FreqMeasurement-CW51.zip
XEP100-UnionInPages.zip
XEP100-UnionInPagesAndECT.zip
XEP100-XGATE-SharedVars-CW51.zip
XEP100PWM-PWM8bit-CW45.zip
XEP100_SPI_master_w_25AA256.zip
XEQ384EXBUS-EXRAM256x16-CS2-4000-7FFF-CW47.zip
XEQ512-PWM-10kHz8bit100point-CW51.zip
XEQ512-RAM-addressing-v1_0-CW51.zip
XEQ512-SWtrigger-CPU_XGATE-CW47.zip
XET256-ECT-asPWM-CW47.zip
XET256-ECT-OC-CW47.ZIP
XET256-EXBUS-ExROM2ExRAM-CW46.zip
XET256-RTI-RTIdec and COP-v1_0-CW47.zip
XET256-SCI-Tx_Poll-CW51.zip
XF256-SCI-ECHOatCPUisr-CW47.zip
XF256-SCI-ECHOatXGATEisr-CW47.zip
添付
コメント
Hello Lama,
thanks for your examples, which are very helpful for my development. However, only S12XE-002.ZIP is available now. Could you please share S12XE-001.ZIP?
Xingqiu
I have updated it more times and the system was unable to accept file 001. it was there for a few days and then it was blocked.
Now I have changed the extension to bmp. Just rename it to zip and unpack.
Ladislav
zqh
Hi,lama:
how can I find de S12XE-001.ZIP after you rename it?I need it.
HZQ
I have scaned the file and tried to put it back again.
We will see what firewall of community system will say because it hates some kind of files.
Ladislav
It was cleared again. I am working on it.......
The colleague of mine removed all obj files and some redundant files which can be created by make file command and suddenly it is accepted....
Hi Dear Lama,
When I try to program PFLASH, it's always something wrong.
Refer to your examples and other documents, Is the launch command function ONLY can be run in RAM memory?
If yes, then Why?
Thanks a lot
Great Job, Lama!
%3CLINGO-SUB%20id%3D%22lingo-sub-1100774%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELAMA%E3%81%AES12XE%E9%9D%9E%E5%85%AC%E5%BC%8F%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100774%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%A1%E3%82%87%E3%81%86%E3%81%A9%E7%A7%81%E3%81%AEPC%E3%82%92%E8%AA%BF%E3%81%B9%E3%81%A6%E3%80%81%E3%81%93%E3%81%93%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E4%BE%8B%E3%82%92%E5%85%A5%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82(%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E3%80%8C%E6%95%B0%E6%97%A5%E5%89%8D%E3%80%8D%E3%81%AB%E4%BD%9C%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81%E4%B8%80%E9%83%A8%E3%81%AEfirewals%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E6%8B%A1%E5%BC%B5%E5%AD%90BMP%E3%81%A7%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EAN3490.pdf%3C%2FP%3E%0A%3CP%3EDOC-XEP100-MMC-Memory_Map-Common_Map-V5_0-MSExcel.xls%3C%2FP%3E%0A%3CP%3EEEE.xls%3C%2FP%3E%0A%3CP%3ETN263-CodeWarrior%20IDE.pdf%3C%2FP%3E%0A%3CP%3EXEP100%20-%20EEPROM%E3%83%80%E3%82%A4%E3%83%AC%E3%82%AF%E3%83%88%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%20-%20CW45.zip%3C%2FP%3E%0A%3CP%3EXEP100%20-%20%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%20EEPROM%20%E3%81%AE%E5%88%9D%E6%9C%9F%E3%83%87%E3%83%BC%E3%82%BF%20-%20CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100%20-%20MPU%20-%20CW47.ZIP%3C%2FP%3E%0A%3CP%3EXEP100%20-%20RAM%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E6%8C%87%E5%AE%9A%20-%20CW45.zip%3C%2FP%3E%0A%3CP%3EXEP100%20-%20SCI%20-%20XonXoff_poll%20-%20CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100%20-%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%20%2B%20%E3%83%90%E3%83%83%E3%82%AF%E3%83%89%E3%82%A2%20%E3%82%AD%E3%83%BC%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%20-%20CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-ATD%E3%81%8CSTOP%E3%81%8B%E3%82%89%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%20-%20CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-ATD-ATDandXGATEandSharedRAM-CW50.zip%3C%2FP%3E%0A%3CP%3EXEP100-ATD-CH1toCH4-CW47.ZIP%3C%2FP%3E%0A%3CP%3EXEP100-ATD-CH1toCH8-CW47.ZIP%3C%2FP%3E%0A%3CP%3EXEP100-ATD-Cntnuos_SingleCh-v1_0-CW47_Data.zip%3C%2FP%3E%0A%3CP%3EXEP100-ATD-Tmprture_bandgapV-v1_0-CW47_Data.zip%3C%2FP%3E%0A%3CP%3EXEP100-BDM-BDMcommExample-CW50.zip%3C%2FP%3E%0A%3CP%3EXEP100-BufferRAMasOneArray-CW51.zip%3C%2FP%3E%0A%3CP%3EXEP100-BufferRAMasRAMonly-CW51.zip%3C%2FP%3E%0A%3CP%3EXEP100-CAN-CAN0-RxTxIsrLoopback-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-CAN-CAN0-TxAtXGATE-CW51.zip%3C%2FP%3E%0A%3CP%3EXEP100-CAN-CAN0CAN1%20-%20CW45.ZIP%3C%2FP%3E%0A%3CP%3EXEP100-CAN-CAN2CAN2-%E8%AD%98%E5%88%A5%E5%AD%90%20SandX-loopback-CW51.zip%3C%2FP%3E%0A%3CP%3EXEP100-CAN-CAN2CAN3-CW47.ZIP%3C%2FP%3E%0A%3CP%3EXEP100-CAN-CAN2CAN3-FILTER-CW51.ZIP%3C%2FP%3E%0A%3CP%3EXEP100-CAN-CAN2CAN3-%E8%AD%98%E5%88%A5%E5%AD%90%20SandX-CW51.zip%3C%2FP%3E%0A%3CP%3EXEP100-CAN-LoopbackInterrupt-CW51.zip%3C%2FP%3E%0A%3CP%3EXEP100-CAN.ZIP%3C%2FP%3E%0A%3CP%3EXEP100-CAN0%20-%20CAN1%20-%20CW45.ZIP%3C%2FP%3E%0A%3CP%3EXEP100-CAN0-RxTxIsrLoopback-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-CAN0-RxTxIsrLoopbackXGATE-CW51.zip%3C%2FP%3E%0A%3CP%3EXEP100-CAN0-TxAtXGATE-CW51.zip%3C%2FP%3E%0A%3CP%3EXEP100-CRG-COP-CW47.ZIP%3C%2FP%3E%0A%3CP%3EXEP100-CRG-PLL-Setup-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-EBI-MRAM256x16-CS0-CW51.zip%3C%2FP%3E%0A%3CP%3EXEP100-EBI-MRAM256x16-CS2-CW51.zip%3C%2FP%3E%0A%3CP%3EXEP100-ECT-ECTasPWM-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-ECT-FreqMeasurement-CW51.zip%3C%2FP%3E%0A%3CP%3EXEP100-ECT-InputCapture-CW51.zip%3C%2FP%3E%0A%3CP%3EXEP100-ECT-TIM.ZIP%3C%2FP%3E%0A%3CP%3EXEP100-EEEPROM-Addressing-Lukas-CW46.zip%3C%2FP%3E%0A%3CP%3EXEP100-EEEPROM-DataPlacement-CW51.zip%3C%2FP%3E%0A%3CP%3EXEP100-EEEPROM-plusMPU-CW51.zip%3C%2FP%3E%0A%3CP%3EXEP100-EEPROM-DirectAccess-CW51.zip%3C%2FP%3E%0A%3CP%3EXEP100-EXBUS-EXRAM256x16-CS1-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-EXBUS-ExRam_MR2A16ACYS35-CS1-CW51.ZIP%3C%2FP%3E%0A%3CP%3EXEP100-FLASH-PFLASH-CW47.ZIP%3C%2FP%3E%0A%3CP%3EXEP100-FLASH-PFLASH-CW51.ZIP%3C%2FP%3E%0A%3CP%3EXEP100-FLASH-PFLASH-PFlashInitData.zip%3C%2FP%3E%0A%3CP%3EXEP100-FLASH-PFLASH_reading-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-GPIO-PJ2isr-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-GPIO-PortPisrXgate-CW51.zip%3C%2FP%3E%0A%3CP%3EXEP100-ID-readPartID-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-IIC-Master4Flash24C16-CW51.zip%3C%2FP%3E%0A%3CP%3EXEP100-INT-INTERRUPTNUMBER-CW51.ZIP%3C%2FP%3E%0A%3CP%3EXEP100-INT-TRAPPROC-CW51.ZIP%3C%2FP%3E%0A%3CP%3EXEP100-MDDC-delay%20generator-v1_0-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-MPU-MPU-CW47.ZIP%3C%2FP%3E%0A%3CP%3EXEP100-PFLASH-CW47.ZIP%3C%2FP%3E%0A%3CP%3EXEP100-PFLASH-CW51.ZIP%3C%2FP%3E%0A%3CP%3EXEP100-PIM-PTPfunctions1-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-%E3%83%94%E3%83%83%E3%83%88%E3%83%95%E3%83%AD%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0PERIOD-CW51.ZIP%3C%2FP%3E%0A%3CP%3EXEP100-PIT-SERIAL_DATA_OUT-CW45.ZIP%3C%2FP%3E%0A%3CP%3EXEP100-PIT-XGATE-SEMAPHORES-CW51.ZIP%3C%2FP%3E%0A%3CP%3EXEP100-PWM-dutyatXGATE-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-RAM-addressing-v1_0-CW51.zip%3C%2FP%3E%0A%3CP%3EXEP100-RAM-RAMaddressing-CW45.zip%3C%2FP%3E%0A%3CP%3EXEP100-SCI_PIT-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-SCI-ECHO-isr.zip%3C%2FP%3E%0A%3CP%3EXEP100-SCI-ECHOatCPU-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-SCI-ECHOatCPUisr-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-SCI-ECHOatXGATEisr-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-SCI-Sci0transmitterOnXGATE-CW45.zip%3C%2FP%3E%0A%3CP%3EXEP100-SCI-SciTx-CW45.zip%3C%2FP%3E%0A%3CP%3EXEP100-SCI-SCI_PIT-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-SCI-XonXoff_poll-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-SciTx-CW45.zip%3C%2FP%3E%0A%3CP%3EXEP100-SECURITY-BackdoorKeyAccess-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-STOP-ATDwakesUp-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-STOP-RTIwakesUp-CW51.zip%3C%2FP%3E%0A%3CP%3EXEP100-STOP-WakeUp-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-STOP_and_%20API_and_PLL-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-STOP_and_XIRQ_and_PLL-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-TIM-10msIsr-CW47.zip%3C%2FP%3E%0A%3CP%3EXEP100-TIM-FreqMeasurement-CW51.zip%3C%2FP%3E%0A%3CP%3EXEP100-UnionInPages.zip%3C%2FP%3E%0A%3CP%3EXEP100-UnionInPagesAndECT.zip%3C%2FP%3E%0A%3CP%3EXEP100-XGATE-SharedVars-CW51.zip%3C%2FP%3E%0A%3CP%3EXEP100PWM-PWM8bit-CW45.zip%3C%2FP%3E%0A%3CP%3EXEP100_SPI_master_w_25AA256.zip%3C%2FP%3E%0A%3CP%3EXEQ384EXBUS-EXRAM256x16-CS2-4000-7FFF-CW47.zip%3C%2FP%3E%0A%3CP%3EXEQ512-PWM-10kHz8bit100point-CW51.zip%3C%2FP%3E%0A%3CP%3EXEQ512-RAM-addressing-v1_0-CW51.zip%3C%2FP%3E%0A%3CP%3EXEQ512-SWtrigger-CPU_XGATE-CW47.zip%3C%2FP%3E%0A%3CP%3EXET256-ECT-asPWM-CW47.zip%3C%2FP%3E%0A%3CP%3EXET256-ECT-OC-CW47.ZIP%3C%2FP%3E%0A%3CP%3EXET256-EXBUS-ExROM2ExRAM-CW46.zip%3C%2FP%3E%0A%3CP%3EXET256-RTI-RTIdec%E3%81%8A%E3%82%88%E3%81%B3COP-v1_0-CW47.zip%3C%2FP%3E%0A%3CP%3EXET256-SCI-Tx_Poll-CW51.zip%3C%2FP%3E%0A%3CP%3EXF256-SCI-ECHOatCPUisr-CW47.zip%3C%2FP%3E%0A%3CP%3EXF256-SCI-ECHOatXGATEisr-CW47.zip%3C%2FP%3E%0A%3CP%3EXF256-SCI-ECHOatXGATEisr-CW47.zip%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100782%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ALAMA%E3%81%AES12XE%E9%9D%9E%E5%85%AC%E5%BC%8F%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100782%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%88%E3%81%8F%E3%82%84%E3%81%A3%E3%81%9F%E3%80%81%E3%83%A9%E3%83%9E!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100781%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ALAMA%E3%81%AES12XE%E9%9D%9E%E5%85%AC%E5%BC%8F%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100781%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Dear%20Lama%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPFLASH%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%84%E3%81%A4%E3%82%82%E4%BD%95%E3%81%8B%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E4%BE%8B%E3%82%84%E4%BB%96%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%E8%B5%B7%E5%8B%95%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E6%A9%9F%E8%83%BD%E3%81%AFRAM%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%A7%E3%81%AE%E3%81%BF%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100780%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ALAMA%E3%81%AES12XE%E9%9D%9E%E5%85%AC%E5%BC%8F%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100780%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AE%E5%90%8C%E5%83%9A%E3%81%AF%E3%80%81make%20file%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEobj%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%86%97%E9%95%B7%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%80%81%E7%AA%81%E7%84%B6%E5%8F%97%E3%81%91%E5%85%A5%E3%82%8C%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ALAMA%E3%81%AES12XE%E9%9D%9E%E5%85%AC%E5%BC%8F%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%86%8D%E3%81%B3%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99.......%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100778%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ALAMA%E3%81%AES12XE%E9%9D%9E%E5%85%AC%E5%BC%8F%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100778%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%97%E3%81%A6%E3%80%81%E5%86%8D%E5%BA%A6%E6%88%BB%E3%81%9D%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%82%A2%E3%82%A6%E3%82%A9%E3%83%BC%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8B%E7%A8%AE%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%AB%8C%E3%81%86%E3%81%9F%E3%82%81%E3%80%81%E4%BD%95%E3%81%8C%E8%A8%80%E3%81%86%E3%81%8B%E3%82%92%E8%A6%8B%E3%81%A6%E3%81%84%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ELadislav%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ALAMA%E3%81%AES12XE%E9%9D%9E%E5%85%AC%E5%BC%8F%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%EF%BC%8Clama%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%E5%90%8D%E5%89%8D%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E5%BE%8C%3C%2FSPAN%3E%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6de%20S12XE-001.ZIP%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3EHZQ%E3%81%AE%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ALAMA%E3%81%AES12XE%E9%9D%9E%E5%85%AC%E5%BC%8F%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E4%BD%95%E5%BA%A6%E3%82%82%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB001%E3%82%92%E5%8F%97%E3%81%91%E5%85%A5%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%E6%95%B0%E6%97%A5%E9%96%93%E3%81%9D%E3%81%93%E3%81%AB%E3%81%82%E3%82%8A%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%8A%E3%80%81%E6%8B%A1%E5%BC%B5%E5%AD%90%E3%82%92bmp%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%90%8D%E5%89%8D%E3%82%92zip%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E8%A7%A3%E5%87%8D%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ELadislav%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100775%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ALAMA%E3%81%AES12XE%E9%9D%9E%E5%85%AC%E5%BC%8F%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100775%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20Lama%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E9%96%8B%E7%99%BA%E3%81%AB%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E4%BE%8B%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E7%8F%BE%E5%9C%A8%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%81%AE%E3%81%AFS12XE-002.ZIP%E3%81%AE%E3%81%BF%E3%81%A7%E3%81%99%E3%80%82S12XE-001.ZIP%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E8%A1%8C%E7%A7%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎10-26-2020 12:52 AM
更新者:
