playbin2 Introduction
Document created by Joan Xie Employee on Oct 8, 2015
Version 1Show Document
  • View in full screen mode
Playbin2 provides a stand-alone everything-in-one abstraction for an audio and/or video player.
Audio sink and video sink can be specified by application
Supports subtitle for video files
Adjustable A/V offset
Selects audio/video/subtitle streams by input selector
Audio post-processing by audio convert, audio resample and volume
The pipeline is created by playbin2 dynamically:
Typefind checks the source type
Demuxer parses the source data and create pads for all the streams, respectively
Playbin2 searches for and creates decoders in element factory who have capability to decode specific format of audio/video
Playbin2 creates and connects audio sink chain and video sink chain
Playbin2: interaction with application
Set/get properties of playbin2
“audio-sink”, “video-sink”
“current-audio”, “current-video”, “current-text”
“n-audio”, “n-video”, “n-text” (read only)
uri”, “suburi”, “av-offset”, “volume”, “mute”
Bidirectional: flush start, flush end
Downstream: eos, new segment, tag
Upstream: qos, seek
Position, duration, latency, rate, seeking, segment
Eos, error, warning, info, tag, buffering, state changed, duration, latency,
“video-changed”, “audio-changed”, “text-changed”
“video-tags-changed”, “audio-tags-changed”, “text-tags-changed”
Playback: track selection
Pipeline for audio/video/subtitle multi-track file
Demuxer creates src pads for all the tracks, respectively
Each track has its own decoder and sink pad of input selector
One sink pad in input selector is activated to play corresponding track
Audio, video and subtitle have separated input selectors.
Take audio for example:
Input selector
Only push the data from active sink pad to its src pad
The data from all the sink pads shall be synchronized, so that timestamps can be consecutive when switch to another track. Otherwise, there will be no sound or video for a long time after switching track.
If demuxer gets samples in file mode (need a large queue before decoder):
             A lock is set for each inactive tracks to synchronize tracks. Otherwise, the inactive tracks would be decoded in full speed (usually much more faster than active track).
             The lock compares the received timestamp with the last timestamp of active track. If larger, waits until the next timestamp (buffer) of acitived track arrives; if smaller, drop this buffer and get the next buffer.
If demuxer gets samples in track mode and the queue is small:
            All tracks is synchronized by demuxer
