Introduction the BSP configuration file in MQX for Kinetis SDK
1  Overview of BSP directory in MQX classic  and MQX for KSDK
If you compare the BSP directory of MQX classic and MQX for KSDK , you will find that there are significant differences in how the Board Support Package for MQX for KSDK and classic MQX are configured.  For MQX classic directory, the compiled BSP library is used for drivers and hardware configuration (see picture 1), there are 35 files, while for MQX for KSDK directory (see picture 2), the BSP directory is nearly empty, much of the equivalent functionality of the BSP library is now moved to the example board directory. See picture 3. If you want to port your application to your custom board, these files are very important, you need to review them carefully.
Picture 1   BSP in MQX classic
Picture 2  BSP in MQX for KSDK
Picture 3   board directory in MQX for KSDK
2  Introduction of the BSP configuration file in MQX for KSDK
The BSP configuration  files are located at  sdk_install_folder/examples. Please see picture 3. We need to modify these files according to schematic and reference manual
2.1 Board.c/h:
The C file contains clock and oscillator initialization functions. The header file contains board-specific configuration macros for things such as debug terminal configuration, push buttons, LEDs and other board-specific items.
2.2 Gpio_pins.c/h:
Kinetis SDK uses pin configuration structures for each pin
--Pin configuration structures in gpio_pin.c configures input/output, pull-up/pull-down, pin filtering, interrupt enabled/disabled, initial output polarity, slew rate and driver strength setting
Gpio_pins.h
--declares Pin names used by board, PORT pin to use  (ie: PTE3)
--contains definitions for LED, switch, and SD card chip select
/*! @brief Pin names */
enum _gpio_pins_pinNames{
  kGpioSW2      = GPIO_MAKE_PIN(GPIOC_IDX, 6U),
  kGpioSW3      = GPIO_MAKE_PIN(GPIOA_IDX, 4U),
  kGpioSdhc0Cd  = GPIO_MAKE_PIN(GPIOE_IDX, 6U),
  kGpioLED1     = GPIO_MAKE_PIN(GPIOE_IDX, 26U),
  kGpioLED2     = GPIO_MAKE_PIN(GPIOB_IDX, 22U),
  kGpioLED3     = GPIO_MAKE_PIN(GPIOB_IDX, 21U),
#endif
Gpio_pins.c
Contains GPIO options for each pin
const gpio_output_pin_user_config_t ledPins[] = {
    .pinName = kGpioLED1,
.config.outputLogic = 1,
    .config.slewRate = kPortSlowSlewRate,
    .config.isOpenDrainEnabled = false,
.config.driveStrength = kPortLowDriveStrength,
    .pinName = kGpioLED2,
    .pinName = kGpioLED3,
    .pinName = GPIO_PINS_OUT_OF_RANGE,
2.3  Pin_mux.c/h:
Kinetis devices provide great flexibility in muxing signals, each digital port pin has up to 8 signals muxed on pin, some peripherals route same signals to multiple pins. In Pin_mux.c:  It implements functions to set pin mux option for all pins used on board, and functions for each peripheral type, like configure_can_pins()
void configure_can_pins(uint32_t instance)
  /* PORTB_PCR19 */
  PORT_HAL_SetMuxMode(PORTB,19u,kPortMuxAlt2);
  /* PORTB_PCR18 */
  PORT_HAL_SetMuxMode(PORTB,18u,kPortMuxAlt2);
Not all instances will be populated so may need to add
void configure_i2c_pins(uint32_t instance)
  switch(instance) {
    case I2C0_IDX:                       /* I2C0 */
      /* Affects PORTE_PCR24 register */
PORT_HAL_SetMuxMode(PORTE,24u,kPortMuxAlt5);
      PORT_HAL_SetOpenDrainCmd(PORTE,24u,true);
      /* Affects PORTE_PCR25 register */
PORT_HAL_SetMuxMode(PORTE,25u,kPortMuxAlt5);
PORT_HAL_SetOpenDrainCmd(PORTE,25u,true);
      break;
    case I2C1_IDX:                       /* I2C1 */
      /* Affects PORTC_PCR10 register */
PORT_HAL_SetMuxMode(PORTC,10u,kPortMuxAlt2);
PORT_HAL_SetOpenDrainCmd(PORTC,10u,true);
      /* Affects PORTC_PCR11 register */
PORT_HAL_SetMuxMode(PORTC,11u,kPortMuxAlt2);
PORT_HAL_SetOpenDrainCmd(PORTC,11u,true);
      break;
    default:
      break;
2.4  hardware_init:
Project specified hardware initialization, it uses functions provided in board configuration layers in pin_mux.c during startup
void hardware_init(void) {
/* enable clock for PORTs */
CLOCK_SYS_EnablePortClock(PORTA_IDX);
CLOCK_SYS_EnablePortClock(PORTB_IDX);
CLOCK_SYS_EnablePortClock(PORTC_IDX);
CLOCK_SYS_EnablePortClock(PORTE_IDX);
/* Init board clock */
BOARD_ClockInit();
dbg_uart_init();
3   Kinetis SDK Porting example—Change Default UART
To change default UART port, we need to change the UART instance in board.h, and change the pin muxing in pin_mux.c
3.1   Modify board.h to select the UART and baud rate to use
/* The UART to use for debug messages. */
#ifndef BOARD_DEBUG_UART_INSTANCE
    #define BOARD_DEBUG_UART_INSTANCE   0
    #define BOARD_DEBUG_UART_BASEADDR   UART0
#endif
#ifndef BOARD_DEBUG_UART_BAUD
    #define BOARD_DEBUG_UART_BAUD       115200
#endif
3.2  Modify pin_mux.c to select the pins to use
void configure_uart_pins(uint32_t instance)
  switch(instance) {
    case UART0_IDX:                      /* UART0 */
      /* Affects PORTB_PCR16 register */
PORT_HAL_SetMuxMode(PORTB,16u,kPortMuxAlt3);
      /* Affects PORTB_PCR17 register */
PORT_HAL_SetMuxMode(PORTB,17u,kPortMuxAlt3);
      break;
    case UART4_IDX:                      /* UART4 */
      /* Affects PORTC_PCR14 register */
PORT_HAL_SetMuxMode(PORTC,14u,kPortMuxAlt3);
      /* Affects PORTC_PCR15 register */
PORT_HAL_SetMuxMode(PORTC,15u,kPortMuxAlt3);
      break;
    default:
      break;
添付
%3CLINGO-SUB%20id%3D%22lingo-sub-1125605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%AF%E3%81%98%E3%82%81%E3%81%AB%20MQX%20for%20Kinetis%20SDK%E3%81%AEBSP%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20align%3D%22center%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%E3%81%AF%E3%81%98%E3%82%81%E3%81%AB%20MQX%20for%20Kinetis%20SDK%E3%81%AEBSP%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20align%3D%22center%22%20style%3D%22text-align%3A%20center%3B%22%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E1%20MQX%20%E3%82%AF%E3%83%A9%E3%82%B7%E3%83%83%E3%82%AF%E3%81%A8%20MQX%20for%20KSDK%20%E3%81%AE%20BSP%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AE%E6%A6%82%E8%A6%81%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EMQX%20classic%20%E3%81%A8%20MQX%20for%20KSDK%20%E3%81%AE%20BSP%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E6%AF%94%E8%BC%83%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81Board%20Support%20Package%20for%20MQX%20for%20KSDK%20%E3%81%A8%20classic%20MQX%20%E3%81%AE%E8%A8%AD%E5%AE%9A%E6%96%B9%E6%B3%95%E3%81%AB%E5%A4%A7%E3%81%8D%E3%81%AA%E9%81%95%E3%81%84%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82MQX%E3%82%AF%E3%83%A9%E3%82%B7%E3%83%83%E3%82%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9FBSP%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A8%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C(%E5%9B%B31%E3%82%92%E5%8F%82%E7%85%A7)%E3%80%8135%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81MQX%20for%20KSDK%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA(%E5%9B%B32%E3%82%92%E5%8F%82%E7%85%A7)%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81BSP%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E7%A9%BA%E3%81%A7%E3%80%81BSP%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E5%90%8C%E7%AD%89%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%AE%E5%A4%9A%E3%81%8F%E3%81%8C%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%9C%E3%83%BC%E3%83%89%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%86%99%E7%9C%9F3%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E9%87%8D%E8%A6%81%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E6%85%8E%E9%87%8D%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22classic-bsp.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22classic-bsp.jpg%22%20style%3D%22width%3A%20960px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F56131iA011309221B37464%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22classic-bsp.jpg%22%20alt%3D%22classic-bsp.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%86%99%E7%9C%9F1%20MQX%E3%82%AF%E3%83%A9%E3%82%B7%E3%83%83%E3%82%AF%E3%81%AEBSP%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ksdk-bsp.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ksdk-bsp.jpg%22%20style%3D%22width%3A%20960px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F56172iCCD3DDB3CDF49BAA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22ksdk-bsp.jpg%22%20alt%3D%22ksdk-bsp.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9B%B32%20KSDK%E3%81%AEMQX%E3%81%A7%E3%81%AEBSP%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22board.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22board.jpg%22%20style%3D%22width%3A%20960px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F56224i940613D0726A12A3%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22board.jpg%22%20alt%3D%22board.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%86%99%E7%9C%9F3%20MQX%20for%20KSDK%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E2%20MQX%20for%20KSDK%E3%81%A7%E3%81%AEBSP%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EBSP%20%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%20sdk_install_folder%2Fexamples%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%86%99%E7%9C%9F3%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%81%A8%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E2.1%20%E3%83%9C%E3%83%BC%E3%83%89.c%2Fh%3A%20%3C%2FP%3E%3CP%3EC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8A%E3%82%88%E3%81%B3%E7%99%BA%E6%8C%AF%E5%99%A8%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E9%96%A2%E6%95%B0%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%80%81%E3%83%97%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%9C%E3%82%BF%E3%83%B3%E3%80%81LED%E3%80%81%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E5%9B%BA%E6%9C%89%E3%81%AE%E3%82%A2%E3%82%A4%E3%83%86%E3%83%A0%E3%81%AA%E3%81%A9%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E5%9B%BA%E6%9C%89%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%83%9E%E3%82%AF%E3%83%AD%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.2%20Gpio_pins.c%2Fh%3A%20%3C%2FP%3E%3CP%3EKinetis%20SDK%E3%81%AF%E3%80%81%E5%90%84%E3%83%94%E3%83%B3%E3%81%AB%E3%83%94%E3%83%B3%E6%A7%8B%E6%88%90%E6%A7%8B%E9%80%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E--gpio_pin.c%E3%81%AE%E3%83%94%E3%83%B3%E6%A7%8B%E6%88%90%E6%A7%8B%E9%80%A0%E5%85%A5%E5%8A%9B%2F%E5%87%BA%E5%8A%9B%E3%80%81%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%2F%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%80%81%E3%83%94%E3%83%B3%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%AA%E3%83%B3%E3%82%B0%E3%80%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%AE%E6%9C%89%E5%8A%B9%2F%E7%84%A1%E5%8A%B9%E3%80%81%E5%88%9D%E6%9C%9F%E5%87%BA%E5%8A%9B%E6%A5%B5%E6%80%A7%E3%80%81%E3%82%B9%E3%83%AB%E3%83%BC%E3%83%AC%E3%83%BC%E3%83%88%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E5%BC%B7%E5%BA%A6%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E6%A7%8B%E6%88%90%3C%2FP%3E%3CP%3EGpio_pins.h%3C%2FP%3E%3CP%3E--%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%94%E3%83%B3%E5%90%8D%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8BPORT%E3%83%94%E3%83%B3%E3%82%92%E5%AE%A3%E8%A8%80%E3%81%97%E3%81%BE%E3%81%99(%E4%BE%8B%3APTE3)%3C%2FP%3E%3CP%3E%E2%97%8FLED%E3%80%81%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%80%81SD%E3%82%AB%E3%83%BC%E3%83%89%E3%83%81%E3%83%83%E3%83%97%E3%82%BB%E3%83%AC%E3%82%AF%E3%83%88%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%82%92%E5%8F%8E%E9%8C%B2%3C%2FP%3E%3CP%3E%2F*!%40brief%20%E3%83%94%E3%83%B3%E5%90%8D%20*%2F%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3Eenum%20_gpio_pins_pinNames%7B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%26nbsp%3B%20kGpioSW2%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20GPIO_MAKE_PIN(GPIOC_IDX%2C%206U)%2C%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%26nbsp%3B%20kGpioSW3%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20GPIO_MAKE_PIN(GPIOA_IDX%2C%204U)%2C%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%26nbsp%3B%20kGpioSdhc0Cd%26nbsp%3B%20%3D%20GPIO_MAKE_PIN(GPIOE_IDX%2C%206U)%2C%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%26nbsp%3B%20kGpioLED1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20GPIO_MAKE_PIN(GPIOE_IDX%2C%2026U)%2C%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%26nbsp%3B%20kGpioLED2%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20GPIO_MAKE_PIN(GPIOB_IDX%2C%2022U)%2C%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%26nbsp%3B%20kGpioLED3%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20GPIO_MAKE_PIN(GPIOB_IDX%2C%2021U)%2C%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%7D%3B%20%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%23endif%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EGpio_pins.c%3C%2FP%3E%3CP%3E%E5%90%84%E3%83%94%E3%83%B3%E3%81%AEGPIO%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Econst%20gpio_output_pin_user_config_t%20ledPins%5B%5D%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E.pinName%20%3D%20kGpioLED1%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E.config.outputLogic%20%3D%201%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E.config.slewRate%20%3D%20kPortSlowSlewRate%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E.config.isOpenDrainEnabled%3D%20false%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E.config.driveStrength%20%3D%20kPortLowDriveStrength%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E.pinName%20%3D%20kGpioLED2%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E.config.outputLogic%20%3D%201%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E.config.slewRate%20%3D%20kPortSlowSlewRate%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E.config.isOpenDrainEnabled%20%3D%20false%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E.config.driveStrength%20%3D%20kPortLowDriveStrength%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E.pinName%20%3D%20kGpioLED3%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E.config.outputLogic%20%3D%201%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E.config.slewRate%20%3D%20kPortSlowSlewRate%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E.config.isOpenDrainEnabled%20%3D%20false%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E.config.driveStrength%20%3D%20kPortLowDriveStrength%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E.pinName%20%3D%20GPIO_PINS_OUT_OF_RANGE%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.3%26nbsp%3B%20Pin_mux.c%2Fh%3A%3C%2FP%3E%3CP%3EKinetis%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E3%80%81%E4%BF%A1%E5%8F%B7%E3%81%AE%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AC%E3%82%AF%E3%82%B5%E3%81%AB%E5%84%AA%E3%82%8C%E3%81%9F%E6%9F%94%E8%BB%9F%E6%80%A7%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%80%81%E5%90%84%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%83%BB%E3%83%9D%E3%83%BC%E3%83%88%E3%83%BB%E3%83%94%E3%83%B3%E3%81%AB%E3%81%AF%E6%9C%80%E5%A4%A78%E3%81%A4%E3%81%AE%E4%BF%A1%E5%8F%B7%E3%81%8C%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AC%E3%82%AF%E3%82%B5%E3%81%95%E3%82%8C%E3%80%81%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AF%E5%90%8C%E3%81%98%E4%BF%A1%E5%8F%B7%E3%82%92%E8%A4%87%E6%95%B0%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82Pin_mux.c%20%E3%81%AE%E5%A0%B4%E5%90%88%3A%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AB%E3%83%94%E3%83%B3%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AC%E3%82%AF%E3%82%B5%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E9%96%A2%E6%95%B0%E3%81%A8%E3%80%81configure_can_pins()%E3%81%AA%E3%81%A9%E3%81%AE%E5%90%84%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E9%96%A2%E6%95%B0%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CEM%3Evoid%20configure_can_pins(uint32_t%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9)%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%7B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%26nbsp%3B%20%2F*%20PORTB_PCR19%20*%2F%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%26nbsp%3B%20PORT_HAL_SetMuxMode(PORTB%2C19u%2CkPortMuxAlt2)%3B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%26nbsp%3B%20%2F*%20PORTB_PCR18%20*%2F%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%26nbsp%3B%20PORT_HAL_SetMuxMode(PORTB%2C18u%2CkPortMuxAlt2)%3B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%7D%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%8C%E5%85%A5%E5%8A%9B%E3%81%95%E3%82%8C%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3Evoid%20configure_i2c_pins(uint32_t%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9)%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%7B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3Eswitch(%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9)%20%7B%20%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20case%20I2C0_IDX%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20I2C0%20*%2F%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%2F*%20PORTE_PCR24%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%20PORT_HAL_SetMuxMode(PORTE%2C24u%2CkPortMuxAlt5)%3B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3EPORT_HAL_SetOpenDrainCmd(PORTE%E3%80%8124u%E3%80%81true)%3B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%2F*%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BFPORTE_PCR25%E5%BD%B1%E9%9F%BF%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%20PORT_HAL_SetMuxMode(PORTE%2C25u%2CkPortMuxAlt5)%3B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%20PORT_HAL_SetOpenDrainCmd(PORTE%E3%80%8125u%E3%80%81true)%3B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20break%3B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20case%20I2C1_IDX%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20I2C1%20*%2F%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%2F*%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BFPORTC_PCR10%E5%BD%B1%E9%9F%BF%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%20PORT_HAL_SetMuxMode(PORTC%2C10u%2CkPortMuxAlt2)%3B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%20PORT_HAL_SetOpenDrainCmd(PORTC%E3%80%8110u%E3%80%81true)%3B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%2F*%20PORTC_PCR11%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%20PORT_HAL_SetMuxMode(PORTC%2C11u%2CkPortMuxAlt2)%3B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%20PORT_HAL_SetOpenDrainCmd(PORTC%2C11u%2Ctrue)%3B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20break%3B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%EF%BC%9A%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20break%3B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%26nbsp%3B%20%7D%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.4%20hardware_init%3A%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E6%8C%87%E5%AE%9A%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AF%E3%80%81pin_mux.c%20%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E6%A7%8B%E6%88%90%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%A7%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%82%8B%E9%96%A2%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E8%B5%B7%E5%8B%95%E6%99%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Evoid%20hardware_init(void)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%2F*%20PORT%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ECLOCK_SYS_EnablePortClock(PORTA_IDX)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ECLOCK_SYS_EnablePortClock(PORTB_IDX)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ECLOCK_SYS_EnablePortClock(PORTC_IDX)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ECLOCK_SYS_EnablePortClock(PORTE_IDX)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%2F*%20%E3%82%A4%E3%83%8B%E3%83%83%E3%83%88%E3%83%9C%E3%83%BC%E3%83%89%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EBOARD_ClockInit()%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Edbg_uart_init()%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E3%20Kinetis%20SDK%E3%81%AE%E7%A7%BB%E6%A4%8D%E4%BE%8B%20-%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88UART%E3%81%AE%E5%A4%89%E6%9B%B4%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AEUART%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81board.h%E3%81%AEUART%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82pin_mux.c%E3%81%A7%E3%83%94%E3%83%B3%E3%81%AE%E5%A4%9A%E9%87%8D%E5%8C%96%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E3.1%20board.h%20%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%20UART%20%E3%81%A8%E3%83%9C%E3%83%BC%20%E3%83%AC%E3%83%BC%E3%83%88%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%2F*%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%20UART%E3%80%82*%2F%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%23ifndef%20BOARD_DEBUG_UART_INSTANCE%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%23define%20BOARD_DEBUG_UART_INSTANCE%200%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%23define%20BOARD_DEBUG_UART_BASEADDR%20UART0%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%23endif%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%23ifndef%20BOARD_DEBUG_UART_BAUD%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%23define%20BOARD_DEBUG_UART_BAUD%20115200%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%23endif%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E3.2%20pin_mux.c%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%94%E3%83%B3%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3Evoid%20configure_uart_pins(uint32_t%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9)%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%7B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3Eswitch(%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9)%20%7B%20%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20case%20UART0_IDX%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20UART0%20*%2F%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%2F*%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BFPORTB_PCR16%E5%BD%B1%E9%9F%BF%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%20PORT_HAL_SetMuxMode(PORTB%2C16u%2CkPortMuxAlt3)%3B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%2F*%20PORTB_PCR17%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%20PORT_HAL_SetMuxMode(PORTB%2C17u%2CkPortMuxAlt3)%3B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20break%3B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20case%20UART4_IDX%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20UART4%20*%2F%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%2F*%20PORTC_PCR14%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%20PORT_HAL_SetMuxMode(PORTC%2C14u%2CkPortMuxAlt3)%3B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%2F*%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BFPORTC_PCR15%E5%BD%B1%E9%9F%BF%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%20PORT_HAL_SetMuxMode(PORTC%2C15u%2CkPortMuxAlt3)%3B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20break%3B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%EF%BC%9A%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20break%3B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%26nbsp%3B%20%7D%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%7D%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎09-14-2015 11:05 PM
更新者:
