IMX31ADS Compiling Linux kernel mainline
Document created by jesseg Employee on Aug 22, 2012Last modified by Jodi Paul on Apr 18, 2013
Version 2Show Document
  • View in full screen mode
Download Linux kernel 2.6.29:
$ wget -c
Extract this:
$ tar jxvf linux-2.6.29.tar.bz2
Apply the patches:
$ cd linux-2.6.29
Edit the file drivers/net/cs89x0.c adding:
#include <mach/hardware.h>
Export CROSS_COMPILE environmet:
$ export PATH="$PATH:/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/"
$ export CROSS_COMPILE=arm-none-linux-gnueabi-
Unselect all no essentials features:
$ make ARCH=arm allnoconfig
Start the configuration menu:
$ make ARCH=arm menuconfig
Change/Select the kernel options below.
Select the MXC/iMX platform and iMX31ADS board:
System Type ->
            ARM system type -> (X) Freescale MXC/iMX-based
            Freescale MXC Implementations  ->
                           MXC/iMX Base Type -> (X) MX3-based
                           MX3 Options  -> [*] Support MX31ADS platforms (NEW)
Select ARM EABI standard to compile the kernel:
Kernel Features  --->
          [*] Use the ARM EABI to compile the kernel
Add support to Linux Binary Format ELF:
Userspace binary formats ->
             [*] Kernel support for ELF binaries
Add support to Network (TCP/IP):
[*] Networking support  ->
         Networking options  ->
                         [*] Packet socket
                         [*] Unix domain sockets
                         [*] PF_KEY sockets
                         [*] TCP/IP networking
                                  [*] IP: kernel level autoconfiguration
                                  [*]     IP: DHCP support
Select network driver (CS89x0), serial driver and unselect VGA console:
Device Drivers  ->
              [*] Network device support  --->
                                     [*]   Ethernet (10 or 100Mbit)  --->
                                            [*]   CS89x0 support
              Character devices  ->
                             Serial drivers  --->
                                      [*] IMX serial port support
                                      [*]   Console on IMX serial port
              Graphics support  ->
                            Console display driver support  --->
                                       [ ] VGA text console
Add support to NFS and support to use it as root file system:
File systems  ->
                           [*] Network File Systems (NEW)  ->
                                       [*]   NFS client support
                                       [*]     Root file system on NFS
Compile the kernel:
$ make ARCH=arm
Copy the created zImage to tftp directory:
$ cp arch/arm/boot/zImage /tftpboot/
Configure your RedBoot to boots with this kernel:
load -r -b 0x100000 /tftpboot/zImage
exec -b 0x100000 -l 0x200000 -c "noinitrd console=ttymxc0,115200 root=/dev/nfs nfsroot= ip=dhcp"
