How to merge multiple floating and NL license files in 1 file
Document created by Pascal Irrle Employee on Aug 12, 2015Last modified by Diana Torres on Feb 28, 2017
Version 2Show Document
  • View in full screen mode
How to merge several license files in 1 file?
I’ve created 2 videos showing/explaining how to generate a license file for several products in same time.
The doc explains the process to:
  1. Download multiple NL license files for different products based on 1 registration
  2. Download multiple Floating license files for different products based on 1 registration and how to merge them in 1 file.
If you have several floating registrations and want to merge the license files in one file, the process is similar to 2.
You must copy all license files in 1 file and keep only the first 3 server lines.
The other must be commented by adding a # as explained above.
Outcomes
