i.MX27 ADS Board TV Out
Document created by jesseg Employee on Aug 17, 2012Last modified by Jodi Paul on Apr 17, 2013
Version 2Show Document
  • View in full screen mode
You can use TV Out on i.MX27ADS board by following these steps:
  • Remove the R71 and solder it on R69 place;
See the image before of this process:
And after this process:
  • Set SWITCH S15: 1 = on; [2-5] = off.
See the image for more details:
Add to your Linux command line (in Redboot) the following parameter:
video=mxcfb:TV-NTSC
After this modification, the video signal will operate at 27MHz, that are applicable just with TV-OUT card. The LCD card will not work at this frequency.
    Outcomes
