Booting Linux From NAND Flash on the i.MX31 ADS
- In LTIB generate a rootfs.jffs2 with a erase block size of 16KB:
./ltib -c ---Target Image Generation
  Options --->
---Choose your root file system image type
    Target image: (jffs2) --->   (16) jffs2 erase block size in KB
- Copy the generated rootfs.jffs2 to /tftpboot :
cp rootfs.jffs2 /tftpboot
- Program 200732 Redboot binary. The 200732 Redboot is available in the 20071008 BSP iso.
After mounting the iso go to the bootloaders directory, extract the redboot_200732.tar.gz file and use the pre-built mx31ads_redboot.bin inside the bin directory.
- Boot from NAND and setup the network parameters
fis init
load -r -b 0x100000 /tftpboot/zImage
fis create -l 0x200000 kernel
load -r -b 0x100000 /tftpboot/rootfs.jffs2
fis create -l 0x1d000000 root
- Pass the following kernel command line:
fis load kernel
exec -b 0x100000 -l 0x200000 -c "noinitrd console=ttymxc0,115200 root=/dev/mtdblock6 rootfstype=jffs2 init=linuxrc ip=none mtdparts=mx"
You need to replace mtdblock6 with your rootfs partition, see below:
mx31# cat /proc/mtd dev:    size  erasesize  name mtd0: 00040000 00020000 "RedBoot" mtd1: 001a0000 00020000 "kernel" mtd2: 0001f000 00008000 "FIS directory" mtd3: 00001000 00008000 "RedBoot config" mtd4: 00040000 00004000 "RedBoot" mtd5: 00200000 00004000 "kernel" mtd6: 01d00000 00004000 "root" mtd7: 00003000 00004000 "FIS directory" mtd8: 00001000 00004000 "RedBoot config" mx31#
%3CLINGO-SUB%20id%3D%22lingo-sub-1099047%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX31%20ADS%E3%81%A7%E3%81%AENAND%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8B%E3%82%89%E3%81%AELinux%E3%81%AE%E8%B5%B7%E5%8B%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099047%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E-%20LTIB%20%E3%81%A7%E3%80%81%E6%B6%88%E5%8E%BB%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%2016KB%20%E3%81%AE%20rootfs.jffs2%20%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E.%2Fltib%20-c%20---%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E7%94%9F%E6%88%90%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3---%26gt%3B%0A%3C%2FPRE%3E%3CP%3E---%E3%83%AB%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%BF%E3%82%A4%E3%83%97%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%0A%3CP%3E%E5%AF%BE%E8%B1%A1%E7%94%BB%E5%83%8F%3A(jffs2)%20---%26gt%3B%0A%26nbsp%3B%20(16)%20jffs2%20%E6%B6%88%E5%8E%BB%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%82%A4%E3%82%BA%20(KB)%3C%2FP%3E%0A%0A%0A%3C%2FPRE%3E%3CP%3E-%20%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20rootfs.jffs2%20%E3%82%92%20%2Ftftpboot%20%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Ecp%20rootfs.jffs2%20%2Ftftpboot%0A%3C%2FPRE%3E%3CP%3E-%20Redboot%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA200732%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82200732%20Redboot%E3%81%AF%E3%80%8120071008%20BSP%20iso%E3%81%A7%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eiso%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81bootloaders%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81redboot_200732.tar.gz%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%8A%BD%E5%87%BA%E3%81%97%E3%81%A6%E3%80%81bin%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E5%86%85%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%B8%88%E3%81%BFmx31ads_redboot.bin%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-%20NAND%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Efis%20init%0A%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3Eload%20-r%20-b%200x100000%20%2Ftftpboot%2FzImage%0A%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3Efis%20create%20-l%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB0x200000%0A%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E-r%20-b%200x100000%20%2Ftftpboot%2Frootfs.jffs2%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%0A%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3Efis%20create%20-l%200x1d000000%E3%83%AB%E3%83%BC%E3%83%88%0A%3C%2FPRE%3E%3CP%3E-%20%E6%AC%A1%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E6%B8%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Efis%20load%20kernel%0A%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3Eexec%20-b%200x100000%20-l%200x200000%20-c%20%22noinitrd%20console%3Dttymxc0%2C115200%20root%3D%2Fdev%2Fmtdblock6%20rootfstype%3Djffs2%20init%3Dlinuxrc%20ip%3Dnone%20mtdparts%3Dmx%22%0A%3C%2FPRE%3E%3CP%3Emtdblock6%20%E3%82%92%20rootfs%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20(%E4%BB%A5%E4%B8%8B%E3%82%92%E5%8F%82%E7%85%A7)%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%0A%3CP%3EMX31%23%E7%8C%AB%2F%20proc%20%2F%20mtd%0Adev%3A%20size%20erasesize%20name%20(%E3%82%B5%E3%82%A4%E3%82%BA%E6%B6%88%E5%8E%BB%E3%82%B5%E3%82%A4%E3%82%BA%E5%90%8D)%0Amtd0%3A%2000040000%2000020000%20%22RedBoot%22%0Amtd1%3A%20001a0000%2000020000%20%22%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%22%0Amtd2%3A%200001f000%2000008000%20%22FIS%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%22%0Amtd3%3A%2000001000%2000008000%20%22RedBoot%20config%22%0Amtd4%3A%2000040000%2000004000%20%22RedBoot%22%0Amtd5%3A%2000200000%2000004000%20%22%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%22%0Amtd6%3A%2001d00000%2000004000%20%22%E3%83%AB%E3%83%BC%E3%83%88%22%0Amtd7%3A%2000003000%2000004000%20%22FIS%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%22%0Amtd8%3A%2000001000%2000004000%20%22RedBoot%20config%22%0AMX31%E3%81%AE%23%3C%2FP%3E%0A%0A%0A%3C%2FPRE%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎09-10-2020 03:39 AM
更新者:
