All Board Android Getevent
Document created by jesseg Employee on Aug 3, 2012Last modified by Jodi Paul on May 16, 2013
Version 6Show Document
  • View in full screen mode
The getevent function shows kernel events like press button events, touchscreen events, sensor events (like accelerometers or magnetometers).
bash-3.2# getevent -h
Usage: getevent [-t] [-n] [-s switchmask] [-S] [-v [mask]] [-p] [-q] [-c count] [-r] [device]
      -t: show time stamps
      -n: don't print newlines
      -s: print switch states for given bits
      -S: print all switch states
      -v: verbosity mask (errs=1, dev=2, name=4, info=8, vers=16, pos. events=32)
      -p: show possible events (errs, dev, name, pos. events)
      -q: quiet (clear verbosity mask)
      -c: print given number of events then exit
      -r: print rate events are received
Bellow an example of all events on some board
bash-3.2# getevent -p
add device 1: /dev/input/event2
  events:
      SYN (0000): 0000  0001  0003
      KEY (0001): 014a
      ABS (0003): 0000  value 0, min 0, max 0, fuzz 0 flat 0
                        0001  value 0, min 0, max 0, fuzz 0 flat 0
                        0018  value 0, min 0, max 0, fuzz 0 flat 0
could not get driver version for /dev/input/mouse0, Not a typewriter
add device 2: /dev/input/event1
  events:
    KEY (0001): 003e
add device 3: /dev/input/event0
  events:
    KEY (0001): 0002  0003  0004  0005  003b  003c  003d  003e
                      0066  0067  0069  006a  006c  008b  009e  0161
could not get driver version for /dev/input/mice, Not a typewriter
For example, some touchscreen event. Any touchscreen press-up or press-down will return a vector of values related with the event (please, see include/linux/input.h for detail)
bash-3.2# getevent /dev/input/event2
0003 0000 0000020e
0003 0001 0000014a
0003 0018 00000037
0001 014a 00000001
0000 0000 00000000
0003 0000 00000209
0003 0001 00000147
1 person found this helpful
    Outcomes
