i.MX51 EVK Changing Env
Changing the storage for U-boot environment variables
U-Boot on Freescale BSP has a compiling option that allows you to choose the storage for environment variables.
1 - Extract the u-boot source using LTIB:
./ltib -m prep -p u-boot
2 - The source will be extracted to <ltib path>/rpm/BUILD/u-boot-2009.08
3 - On u-Boot source locate the i.MXEVK config file, <ltib path>/rpm/BUILD/u-boot-2009.08/include/configs/mx51_bbg.h
4 - To change the storage of variables environment to SD card, on this file, comment out CONFIG_FSL_ENV_IN_SF and define CONFIG_FSL_ENV_IN_MMC:
//#define CONFIG_FSL_ENV_IN_SF
#define CONFIG_FSL_ENV_IN_MMC
5 - Adjust CONFIG_ENV_SECT_SIZE and CONFIG_ENV_OFFSET accordingly. Recall that sd card read block size is 512B.
For example:
#define CONFIG_ENV_SECT_SIZE (256 * 512)
#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE
#if defined(CONFIG_FSL_ENV_IN_MMC)
#define CONFIG_ENV_IS_IN_MMC 1 #define CONFIG_ENV_OFFSET (1023 * 512)
6 - Save the file.
7 - Recompile u-boot:
./ltib -m scbuild -p u-boot
8 - Your new compiled u-boot image will be saved at: <ltib path>/rpm/BUILD/u-boot-2009.08/u-boot.bin
%3CLINGO-SUB%20id%3D%22lingo-sub-1122750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX51%20EVK%20%E7%92%B0%E5%A2%83%E5%A4%89%E6%9B%B4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CH1%20id%3D%22toc-hId-382398481%22%20id%3D%22toc-hId-382398481%22%20id%3D%22toc-hId-1303320944%22%3E%3CSPAN%20class%3D%22mw-headline%22%3EU-boot%20%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%81%AE%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%81%AE%E5%A4%89%E6%9B%B4%3C%2FSPAN%3E%3C%2FH1%3E%26nbsp%3B%20%3CP%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABBSP%E3%81%AEU-Boot%E3%81%AB%E3%81%AF%E3%80%81%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%81%AE%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%26nbsp%3B%20%3CP%3E1%20-%20LTIB%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20u-boot%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E6%8A%BD%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E.%2Fltib%20-m%20prep%20-p%20u-boot%20%3C%2FPRE%3E%26nbsp%3B%20%3CP%3E2%20-%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AF%20%3CLTIB%20path%3D%22%22%3Erpm%2FBUILD%2Fu-boot-2009.08%20%E3%81%AB%E6%8A%BD%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FLTIB%3E%3C%2FP%3E%26nbsp%3B%20%3CP%3E3%20-%20u-Boot%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A7%20i.MXEVK%20%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3CLTIB%20path%3D%22%22%3Erpm%2FBUILD%2Fu-boot-2009.08%2Finclude%2Fconfigs%2Fmx51_bbg.h%20%E3%82%92%E6%8E%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLTIB%3E%3C%2FP%3E%26nbsp%3B%20%3CP%3E4%20-%20%E5%A4%89%E6%95%B0%E3%81%AE%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%82%92SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7CONFIG_FSL_ENV_IN_SF%E3%82%92%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%80%81CONFIG_FSL_ENV_IN_MMC%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive-quote%22%3E%26nbsp%3B%20%3CP%3E%23define%20CONFIG_FSL_ENV_IN_SF%3C%2FP%3E%26nbsp%3B%20%3CP%3E%23define%20CONFIG_FSL_ENV_IN_MMC%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E5%20-%20%E3%81%9D%E3%82%8C%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6CONFIG_ENV_SECT_SIZE%E3%81%A8CONFIG_ENV_OFFSET%E3%82%92%E8%AA%BF%E6%95%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF512B%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%80%9D%E3%81%84%E5%87%BA%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%26nbsp%3B%20%3CP%3E%E4%BE%8B%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive-quote%22%3E%26nbsp%3B%20%3CP%3E%23define%20CONFIG_ENV_SECT_SIZE%20(256%20*%20512)%3C%2FP%3E%26nbsp%3B%20%3CP%3E%23define%20CONFIG_ENV_SIZE%20CONFIG_ENV_SECT_SIZE%3C%2FP%3E%26nbsp%3B%20%3CP%3E%23if%20%E5%AE%9A%E7%BE%A9(CONFIG_FSL_ENV_IN_MMC)%3C%2FP%3E%26nbsp%3B%20%3CP%3E%23define%20CONFIG_ENV_IS_IN_MMC%201%20%23define%20CONFIG_ENV_OFFSET%20(1023%20*%20512)%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%26nbsp%3B%20%3CP%3E6%20-%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%26nbsp%3B%20%3CP%3E7%20-%20u-boot%20%E3%82%92%E5%86%8D%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E.%2Fltib%20-m%20scbuild%20-p%20u-boot%20%3C%2FPRE%3E%26nbsp%3B%20%3CP%3E8%20-%20%E6%96%B0%E3%81%97%E3%81%8F%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%20u-boot%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AF%20%3CLTIB%20path%3D%22%22%3Erpm%2FBUILD%2Fu-boot-2009.08%2Fu-boot.bin%20%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FLTIB%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1122750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX51%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎09-10-2020 02:55 AM
更新者:
