The TRST is active low signal in P1020, thus pulling it down will always keep JTAG in Reset position. For the proper working of SoC, The system must assert HRESET and TRST (Both active low), simultaneously.
If there is no specific use-case which needs JTAG always in reset, then it is better to gate it with HRESET.
