USBdongle license is not running for CW for PA V10.4 and MCU V10.4 (sometimes) ->  "LM_NOTTHISHOST"
Get “LM_NOTTHISHOST" license error message
A- Description
Most of the time the “Product Licenses” is working fine but there are some cases where the information provided are wrong.
This is the case for:
  • USBdongle license file is used for NL,
  • Floating license file.
What’s about the USBdongle ?
Under PA V10.4 for instance when the USBDongle is plugged and the license file correctly installed when we launch Eclipse we get a license information:
According to the message there is a problem with the USBDongle or with the license file.
Most of the time the license file is running fine.
Is there a way to check it ?
                ……….. YES.
For MCU V10.6 the error is:
                "Unknown error with key ProfessionalEditionMCU 10.5, LM_NOTTHISHOST.  "
B- Solution
For the USBdongle, we can check the license file using an example project:
  • For MCU V10.6, we can launch the HC08compiler in standalone mode and try to build a big application (requiring a valid license).
  • For PA V10.4 we must use an application using Freescale tool chain (requiring a valid license).
CW for MCU V10.6
                Refer to MCU_full_test.avi attached
                Project file attached too.
By default the USBDongle should work fine.
However I know some customers experienced a problem similar to CW for PA V10.4.
How can we test if an USBdongle license file is running ?
The best way is to create a project using HCS08 for Simulator.
For this test I will create a project and added lot of asm nop code to have a big application.
1st test: Add USBDongle license file in \CW_MCU_v10.6\MCU path.
However the USBdongle is not plugged on the PC. So the license file is not running.
Re-start Eclipse and re-open same project.
2nd test: Same as 1st test but I plugged the USBdongle key now.
Here the license file is correctly recognized - Activated.
However you could have same problem as 1st test.
In this case to check the license you must build the project.
Now the project is built without any license error (even if the license information always provides wrong information).
CW for PA V10.4.
                Refer to the PA_full_test.avi attached
The best way is to create a project using Freescale compiler (GCC is free so more difficult).
For this test I will create a project based on 8250 device.
1st test: Without no license file.
2nd test: Add USBDongle license file in \CW_PA_v10.4.0\PA path.
3rd test: Same as 2nd test but I plugged the USBdongle key now.
Now the project is built without any license error even if the license information always provides wrong information.
Hope this will help you.
Pascal
添付
%3CLINGO-SUB%20id%3D%22lingo-sub-1100041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPA%20V10.4%20%E3%81%8A%E3%82%88%E3%81%B3%20MCU%20V10.4%20%E3%81%AE%20CW%20%E3%81%A7%20USBdongle%20%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%20(%E6%99%82%E3%80%85)%20-%26gt%3B%20%22LM_NOTTHISHOST%22%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20align%3D%22center%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2020.0pt%3B%22%3E%E3%80%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2020.0pt%3B%22%3ELM_NOTTHISHOST%E3%80%8D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2020.0pt%3B%22%3E%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%3C%2FSPAN%3E%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20style%3D%22font-size%3A%2014.0pt%3B%22%3EA-%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%E8%AA%AC%E6%98%8E%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%80%8C%E8%A3%BD%E5%93%81%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%80%8D%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E6%83%85%E5%A0%B1%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AB%E5%BD%93%E3%81%A6%E3%81%AF%E3%81%BE%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CLI%3ENL%E3%81%AB%E3%81%AFUSB%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%3C%2FLI%3E%3CLI%3E%E3%83%95%E3%83%AD%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%20%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22%3B%20text-decoration%3A%20underline%3B%20font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3EUSB%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%E3%81%A8%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81PA%20V10.4%E3%81%A7%E3%81%AF%E3%80%81USBDongle%E3%81%8C%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%80%81Eclipse%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E6%83%85%E5%A0%B1%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2237449_37449.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2237449_37449.png%22%20style%3D%22width%3A%20624px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117396iA0D9CAA4B9C97EE0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2237449_37449.png%22%20alt%3D%2237449_37449.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E37449_37449.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20624px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F24540iC30F9F3841C03A4E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_0.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81USBDongle%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%80%A6%E2%80%A6%E2%80%A6..%20YES.%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EMCU%20V10.6%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Segoe%20UI'%2Csans-serif%3B%22%3E%E3%80%8CProfessionalEditionMCU%2010.5%E3%80%81LM_NOTTHISHOST%E3%81%AE%E3%82%AD%E3%83%BC%E3%81%A7%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%20%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2Csans-serif%3B%22%3E%3CBR%20clear%3D%22all%22%20%2F%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20style%3D%22font-size%3A%2014.0pt%3B%22%3EB-%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EUSBdongle%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CLI%3EMCU%20V10.6%E3%81%A7%E3%81%AF%E3%80%81HC08%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%82%92%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81%E5%A4%A7%E3%81%8D%E3%81%AA%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E6%A7%8B%E7%AF%89%E3%82%92%E8%A9%A6%E3%81%BF%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99(%E6%9C%89%E5%8A%B9%E3%81%AA%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99)%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CUL%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CLI%3EPA%20V10.4%20%E3%81%A7%E3%81%AF%E3%80%81Freescale%20%E3%83%84%E3%83%BC%E3%83%AB%20%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20(%E6%9C%89%E5%8A%B9%E3%81%AA%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99)%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CEM%3ECW%20for%20MCU%20V10.6%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%B7%BB%E4%BB%98MCU_full_test.avi%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%82%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81USBDongle%20%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E4%B8%80%E9%83%A8%E3%81%AE%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%20PA%20V10.4%20%E3%81%AE%20CW%20%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E7%B5%8C%E9%A8%93%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%3CEM%3EUSB%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%3CEM%3E%E6%9C%80%E9%81%A9%E3%81%AA%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81HCS08%20for%20Simulator%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%3CEM%3E%E3%81%93%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E5%A4%A7%E3%81%8D%E3%81%AA%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E6%8C%81%E3%81%A4%E3%81%9F%E3%82%81%E3%81%AB%E5%A4%9A%E3%81%8F%E3%81%AEasm%20nop%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%3CEM%3E1%E5%9B%9E%E7%9B%AE%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3A%5CCW_MCU_v10.6%5CMCU%E3%81%ABUSBDongle%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%BF%BD%E5%8A%A0%E3%83%91%E3%82%B9%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%3CEM%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81USB%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%E3%81%8CPC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%3CEM%3EEclipse%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81%E5%90%8C%E3%81%98%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%86%8D%E5%BA%A6%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%3CEM%3E2%E5%9B%9E%E7%9B%AE%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3A1%E5%9B%9E%E7%9B%AE%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81USB%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E5%B7%AE%E3%81%97%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%3CEM%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%81%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E8%AA%8D%E8%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20-%20%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%3CEM%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%811%E5%9B%9E%E7%9B%AE%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%A8%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%3CEM%3E%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%3CEM%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AF%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AA%E3%81%97%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99(%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E6%83%85%E5%A0%B1%E3%81%8C%E5%B8%B8%E3%81%AB%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E6%83%85%E5%A0%B1%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%A6%E3%82%82)%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CEM%3EPA%20V10.4%20%E3%81%AE%20CW%E3%80%82%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%B7%BB%E4%BB%98%E3%81%AEPA_full_test.avi%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%3CEM%3EUSB%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%3CEM%3E%E6%9C%80%E5%96%84%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81Freescale%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99(GCC%E3%81%AF%E7%84%A1%E6%96%99%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E3%82%88%E3%82%8A%E5%9B%B0%E9%9B%A3%E3%81%A7%E3%81%99)%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%3CEM%3E%E3%81%93%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%AF%E3%80%818250%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%3CEM%3E1%E5%9B%9E%E7%9B%AE%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3A%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AA%E3%81%97%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%3CEM%3E2%E5%9B%9E%E7%9B%AE%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3A%5CCW_PA_v10.4.0%5CPA%E3%83%91%E3%82%B9%E3%81%ABUSBDongle%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%3CEM%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81USB%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%E3%81%8CPC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%3CEM%3E%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%3CEM%3EEclipse%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81%E5%90%8C%E3%81%98%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%86%8D%E5%BA%A6%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%3CEM%3E3%E5%9B%9E%E7%9B%AE%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3A2%E5%9B%9E%E7%9B%AE%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81USB%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E5%B7%AE%E3%81%97%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%3CEM%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E6%83%85%E5%A0%B1%E3%81%8C%E5%B8%B8%E3%81%AB%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E6%83%85%E5%A0%B1%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%A6%E3%82%82%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AF%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AA%E3%81%97%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20background%3A%20%23BDD6EE%3B%20padding%3A%201.0pt%204.0pt%201.0pt%204.0pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%83%91%E3%82%B9%E3%82%AB%E3%83%AB%20(Pascal)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1100041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%85%A8%E8%88%AC%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎06-11-2015 08:53 AM
更新者:
