Create MQX for KSDK Project From Scratch in IAR IDE
CREATE MQX FOR KSDK PROJECT FROM SCRATCH IN IAR IDE
Note: ${KSDK_PATH} is used in this guide line to instead of path of KSDK source
(Example: C:/Freescale/KSDK_1.2.0/). This procedure was created for TWR-K64f120M
1     Create new workspace
                Open IAR  --> File  --> New  --> Workspace
2     Create new project
  • Project --> Create New Project  --> C  -> main --> OK
  • Select project directory
3    Add project lib to workspace
        Project  -->  Add Existing Project … then select projects:
{SDK_PATH}/lib/ksdk_mqx_lib/iar/K64F12/ksdk_mqx_lib.ewp
{SDK_PATH}/rtos/mqx/mqx/build/iar/mqx_twrk64f120m/mqx_twrk64f120m.ewp
{SDK_PATH}/rtos/mqx/mqx_stdlib/build/iar/mqx_stdlib_twrk64f120m/mqx_stdlib_twrk64f120m.ewp
4    Build All Lib project
5    Setting Project
On the left workspace pane, right click on Mqx Project and select Options.
  • Setting General Options
        Select device:
  • Setting C/C++ Compiler
         Add include file and define symbols for project at Preprocessor tab:
Additional include directories:
{SDK_PATH}/rtos/mqx/lib/twrk64f120m.iar/debug
{SDK_PATH}/rtos/mqx/lib/twrk64f120m.iar/debug/config
{SDK_PATH}/rtos/mqx/lib/twrk64f120m.iar/debug/mqx
{SDK_PATH}/rtos/mqx/lib/twrk64f120m.iar/debug/mqx_stdlib
{SDK_PATH}/platform/osa/inc
{SDK_PATH}/platform/CMSIS/Include
{SDK_PATH}/platform/devices
{SDK_PATH}/platform/hal/inc
{SDK_PATH}/platform/drivers/inc
{SDK_PATH}/platform/system/inc
{SDK_PATH}/platform/devices/MK64F12/include
{SDK_PATH}/platform/devices/MK64F12/startup
{SDK_PATH}/platform/startup
{SDK_PATH}/platform/utilities/inc
{SDK_PATH}/examples/twrk64f120m
{SDK_PATH}/rtos/mqx/config
{SDK_PATH}/rtos/mqx/mqx/source/include
Defined symbols:
CPU_MK64FN1M0VMD12
TWR_K64F120M
FSL_RTOS_MQX
  • Setting Linker option
          Use linker file in KSDK source:
            {KSDK_PATH}/platform/devices/MK64F12/linker/iar/MK64FN1M0xxx12_flash.icf
          Set stack/heap size and define __ram_vector_table__
__stack_size__=0x400
__heap_size__=0x400
__ram_vector_table__=1
              The project request three librarys: lib_mqx.a, lib_mqx_stdlib.a, libksdk_platform_mqx.a
{KSDK_PATH}/lib/ksdk_mqx_lib/iar/K64F12/Debug/libksdk_platform_mqx.a
{KSDK_PATH}/rtos/mqx/lib/twrk64f120m.iar/debug/mqx/lib_mqx.a
{KSDK_PATH}/rtos/mqx/lib/twrk64f120m.iar/debug/mqx_stdlib/lib_mqx_stdlib.a
             MQX uses owner’s startup-code (boot.S), We need to override default program entry
6     Create project template
Project structure and create group:
         Specific file for board in:
{KSDK_PATH}\examples\twrk64f120m\board.c
{KSDK_PATH}\examples\twrk64f120m\board.h
{KSDK_PATH}\examples\twrk64f120m\gpio_pins.c
{KSDK_PATH}\examples\twrk64f120m\gpio_pins.h
{KSDK_PATH}\examples\twrk64f120m\pin_mux.c
{KSDK_PATH}\examples\twrk64f120m\pin_mux.h
         BSP file in:
{KSDK_PATH}\rtos\mqx\mqx\source\bsp\bsp.h
{KSDK_PATH}\rtos\mqx\mqx\source\bsp\bsp_config.h
{KSDK_PATH}\rtos\mqx\mqx\source\bsp\init_bsp.c
{KSDK_PATH}\rtos\mqx\mqx\source\bsp\mqx_main.c
{KSDK_PATH}\rtos\mqx\mqx\source\include\mqx.h
         Config files in:
{KSDK_PATH}\rtos\mqx\config\common\small_ram_config.h
{KSDK_PATH}\rtos\mqx\config\common\verif_enabled_config.h
{KSDK_PATH}\rtos\mqx\config\board\twrk64f120m\user_config.h
{KSDK_PATH}\rtos\mqx\config\mcu\MK64F12\mqx_sdk_config.h
          Utilities files in:
{KSDK_PATH}\platform\utilities\src\print_scan.c
{KSDK_PATH}\platform\utilities\src\print_scan.h
{KSDK_PATH}\platform\utilities\src\fsl_debug_console.c
{KSDK_PATH}\platform\utilities\inc\fsl_debug_console.h
7    Write code
The code below is used to turn on the LED and print out “hello world”.
#include "stdio.h"
#include "fsl_os_abstraction.h"
#include "board.h"
#include "fsl_debug_console.h"
#define MAIN_TASK        8
void main_task(uint32_t param);
const TASK_TEMPLATE_STRUCT  MQX_template_list[] =
   { MAIN_TASK, main_task, 0xC00, 20, "main_task", MQX_AUTO_START_TASK},
   { 0L, 0L,        0L,    0L, 0L,         0L }
    LED1_EN;
    LED1_ON;
    PRINTF("Hello World\r\n");
    while(1)
8    Run example:
  • Build project:
  • Select debug target
- Set serial console 115200 baud rate, no parity, 8 data bits, 1 stop bit, without flow control
- Set project as active prior we run project
  • Run project
  • See Led1 is On status and string “Hello World” is printed to screen
No ratings
Version history
Last update:
‎06-09-2015 07:32 AM
Updated by:
