Example MPC5644A TSENS Temperature calculation CW210
File uploaded by Petr Stancik Employee on Apr 22, 2015Last modified by Petr Stancik Employee on Apr 9, 2019
Version 3Show Document
  • View in full screen mode
* Detailed Description:
* Example shows MCU's temperature measurement with the help of TSENS.
* Calibration constants for TSENS are read from TSENS registers and
* eQADC is set to measure Vbg and TSENS outputs. eQADC calibration is also done.
* Calculated internal temperature can be displayed on the Terminal.
* See results on PC terminal (19200, 8N1, None). You should see following text
* (with different values for sure)
*    fsys = 150MHz
*    TSENS temperature calculation
*    Calibration constants read from TSENS registers
*    T_LOW = 25
*    T_HIGH = 145
*    TSENS_CODE_T_LOW = 5441
*    TSENS_CODE_T_HIGH = 7305
*    VBG_CODE_T_LOW = 4010
*                 (TSENS_CODE_T*beta - TSENS_CODE_T_LOW)*(T_HIGH - T_LOW)
*    T = T_LOW - --------------------------------------------------------- [degC]
*                       (TSENS_CODE_T_HIGH - TSENS_CODE_T_LOW)
*    VBG_CODE_T (ch45)  = 3959 => beta = 1.01288
*    TSENS_CODE_T (ch128) = 5608
*    Temp = 31.80 degC
* Test HW:        XPC564AKIT208S and XPC564AKIT324S
* MCU:            SPC5644AMMG1,0M14X and SPC5644AMVZ1,0M14X
* Fsys:           150/132/120/12 MHz
* Debugger:       Lauterbach Trace32
*                 PeMicro USB-ML-PPCNEXUS
* Target:         RAM, internal_FLASH
* Terminal:       19200-8-no parity-1 stop bit-no flow control on eSCI_A
* EVB connection: default
Outcomes
