Example MPC5744P LINFlex UART echo SW polling GHS614
File uploaded by Petr Stancik Employee on Apr 20, 2015Last modified by Petr Stancik Employee on Apr 9, 2019
Version 2Show Document
  • View in full screen mode
* Detailed Description:
* Simple LINFlex UART mode transmit and receive without interrupts (polled UART)
* TXFIFO and RXFIFO macro is used to select between buffer and FIFO mode
* EVB connection:
*   Route LINFlexD_0 TXD/RXD (PB2/PB3) signals to the main board RS-232 transceiver
*   Daughtercard:
*   J17.11–12 ON  .. Connect LINFlexD_0 TXD (PB2) to main board.
*   J17.8–9 ON .. Connect LINFlexD_0 RXD (PB3) to main board.
*   Motherboard
*   J14 - SCI_RX ON
*   J13 - SCI_TX ON
*   J25 - SCI_PWR ON
* See results on PC terminal (19200, 8N1, None).
* Test HW:  MPC57xx
* Maskset:  1N65H
* Target :  RAM, internal_FLASH
* Fsys:     200 MHz PLL with 40 MHz crystal reference
* Terminal: 19200, 8N1, None
Outcomes
