IPSec demo on T1040RDB
Document created by Ugendreshwar Kudupudi Employee on Apr 15, 2015Last modified by ebiz_ws_prod on Dec 13, 2017
Version 8Show Document
  • View in full screen mode
IPSec Performance Reproducibility Procedure on T1040RDB platform
1. Enable ASF in Linux Kernel
     Step 1: Launch the kernel menu using the command: bitbake -c menuconfig virtual/kernel
     Step 2: Enable ASF under Device Driver -> Networking device support -> Application Specific Fastpath
     Step 3: Build the final binaries that needs to be loaded on T1040RDB using the command : bitbake fsl-image-core
NOTE: The ASF modules are compiled as dynamically loadable modules and placed in the ROOTFS under the path /usr/driver/asf/min and /usr/driver/asf/full
2. Steps to boot the board with 2 cores:  (optional)
=> cpu 2 disable
=> cpu 3 disable
=> boot
Board configuration after Linux is up
A. Enable ip_forwarding and Linux performance parameters
  • echo 1 > /proc/sys/net/ipv4/ip_forward
  • echo 9000 > /proc/sys/net/netfilter/nf_conntrack_udp_timeout
  • echo 9000 >/proc/sys/net/netfilter/nf_conntrack_udp_timeout_stream
B. Insmod ASF ko’s
  • cd /usr/driver/asf/min
  • insmod asf.ko
  • insmod asfctrl.ko
  • insmod asfipsec.ko
  • insmod asfctrl_ipsec.ko
C. Run fmc command :
  • cd /usr/driver/asf/scripts/fmc/
  • fmc -s Soft_FragParser.xml -p asf-fman-perf-policy.xml -c asf-cfg-perf-2041.xml -a
D. Assign interface IP addresses and routes according to setup.
  • Left DUT:
  • ifconfig fm1-gb0 172.18.18.10 netmask 255.255.0.0 up
  • ifconfig fm1-gb3 200.200.200.10/24 up
  • ifconfig fm1-gb1 172.20.20.10 netmask 255.255.0.0 up
  • ifconfig fm1-gb4 20.20.20.10/24 up
  • route add -net 192.168.1.0/24 gw 172.18.18.2
  • route add default gw 200.200.200.20
  • route add -net 172.168.1.0/24 gw 172.20.20.2
  • route add -net 172.168.2.0/24 gw 20.20.20.20
  • arp -s 172.18.18.2 00:00:00:00:00:01 (optional)
  • arp -s 172.20.20.2 00:00:00:00:00:02 (optional)
  • Right DUT:
  • ifconfig fm1-gb0 172.19.19.10 netmask 255.255.0.0 up
  • ifconfig fm1-gb3 200.200.200.20/24 up
  • ifconfig fm1-gb1 172.21.21.10 netmask 255.255.0.0 up
  • ifconfig fm1-gb4 20.20.20.20/24 up
  • route add -net 192.168.2.0/24 gw 172.19.19.2
  • route add default gw 200.200.200.10
  • route add -net 172.168.2.0/24 gw 172.21.21.2
  • route add -net 172.168.1.0/24 gw 20.20.20.10
  • arp -s 172.19.19.2 00:00:00:00:00:02 (optional)
  • arp -s 172.21.21.2 00:00:00:00:00:04 (optional)
E. Configure IPSec policies and SAs (attached below that needs to be downloaded to the box via tftp or sftp)
  • Left DUT:
    • ./left_tun-4port-v1.txt
  • Right DUT:
    • ./right_tun-4port-v1.txt
F. Switch settings
    • killall -9 l2sw_bin
    • l2sw_bin
Using UIO: /dev/uio0
Mapped register memory @ 0xb7b3f000
Chipid: 099530e9
fsl_dpa ethernet.17 fm1-gb0: Err FD status = 0x00040000
fsl_dpa ethernet.18 fm1-gb1: Err FD status = 0x00040000
l2switch>
l2switch>mac add 00:00:00:00:00:01 3 [MAC 00:00...00:01 is reachable on port 3]
m2switch>mac add 00:00:00:00:00:03 7
l2switch>mac add 00:04:9f:03:30:f6 8 [MAC of fm1-gb0]
l2switch>mac add 00:04:9f:03:30:f7 9 [MAC of fm1-gb1]
l2switch>mac dump [Displays MACDB of switch (static & Dynamic)]
Type VID MAC Address Ports
Static 1 00:00:00:00:00:01 3
Static 1 00:00:00:00:00:03 7
Static 1 00:04:9f:03:30:f6 8
Static 1 00:04:9f:03:30:f7 9
Static entries: 4
Dynamic entries: 0
l2switch> l2switch>^Z [Press ctrl+z to stop the process]
[1]+ Stopped(SIGTSTP) l2sw_bin
root@t1040rdb:/mnt/sridhar/asf-bins/qos/bin/full#
G. Configure IXIA/STC to generate the traffic with 128 flows.
H. Start the traffic from both end and verify all the flows are offloaded and packet is going through IPSec ASF.
Note: Except switch settings everything is similar to previous performance releases by IDC.
I. The ASF flow can be observed using the following command
  • cat /proc/asf/flow_debug
Script files
PFA in attachment
Original Attachment has been moved to: right_tun-4port-v1.txt.zip
Original Attachment has been moved to: left_tun-4port-v1.txt.zip
    Outcomes
