Example MPC5744P FlexPWM SGEN synchronization GHS614
* Detailed Description:
* This example shows usage of FlexPWM and Sine Wave generator (SGEN) modules.
* The setting is selected in the way to have a PWM output signal synhronized with
* SGEN output signal. This is necessary for resolver usage in motor control appls.
* See attached Excel sheet for calculation of parammeters used here (AUX0_clk_DIV0,
* AUX0_clk_DIV1, SGEN_IOFREQ, PWM_PRESCALER, PWM_MODULO).
* This example is set for 2.44140625 kHz SGEN/PWM frequency.
* Test HW:  MPC57xx
* Maskset:  1N65H
* Target :  internal_FLASH
* Fsys:     200 MHz PLL with 40 MHz crystal reference
* EVB connection:
* P20.1 - D[7] .. SGEN output
*          connected to FEC PHY's MIIMODE input on motherboard,
*          to see full amplitude remove J26
* P8.12    - A[11] .. FlexPWM A[0] output
* P8.11    - A[10] .. FlexPWM B[0] output
%3CLINGO-SUB%20id%3D%22lingo-sub-1117349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EExample%20MPC5744P%20FlexPWM%20SGEN%20synchronization%20GHS614%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20Detailed%20Description%3A%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20This%20example%20shows%20usage%20of%20FlexPWM%20and%20Sine%20Wave%20generator%20(SGEN)%20modules.%3C%2FP%3E%3CP%3E*%20The%20setting%20is%20selected%20in%20the%20way%20to%20have%20a%20PWM%20output%20signal%20synhronized%20with%3C%2FP%3E%3CP%3E*%20SGEN%20output%20signal.%20This%20is%20necessary%20for%20resolver%20usage%20in%20motor%20control%20appls.%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20See%20attached%20Excel%20sheet%20for%20calculation%20of%20parammeters%20used%20here%20(AUX0_clk_DIV0%2C%3C%2FP%3E%3CP%3E*%20AUX0_clk_DIV1%2C%20SGEN_IOFREQ%2C%20PWM_PRESCALER%2C%20PWM_MODULO).%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20This%20example%20is%20set%20for%202.44140625%20kHz%20SGEN%2FPWM%20frequency.%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20Test%20HW%3A%26nbsp%3B%20MPC57xx%3C%2FP%3E%3CP%3E*%20Maskset%3A%26nbsp%3B%201N65H%3C%2FP%3E%3CP%3E*%20Target%20%3A%26nbsp%3B%20internal_FLASH%3C%2FP%3E%3CP%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20200%20MHz%20PLL%20with%2040%20MHz%20crystal%20reference%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20EVB%20connection%3A%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20P20.1%20-%20D%5B7%5D%20..%20SGEN%20output%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20connected%20to%20FEC%20PHY's%20MIIMODE%20input%20on%20motherboard%2C%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20to%20see%20full%20amplitude%20remove%20J26%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20P8.12%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%20A%5B11%5D%20..%20FlexPWM%20A%5B0%5D%20output%3C%2FP%3E%3CP%3E*%20P8.11%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%20A%5B10%5D%20..%20FlexPWM%20B%5B0%5D%20output%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1117349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20Detailed%20Description%3A%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20This%20example%20shows%20usage%20of%20FlexPWM%20and%20Sine%20Wave%20generator%20(SGEN)%20modules.%3C%2FP%3E%3CP%3E*%20The%20setting%20is%20selected%20in%20the%20way%20to%20have%20a%20PWM%20output%20signal%20synhronized%20with%3C%2FP%3E%3CP%3E*%20SGEN%20output%20signal.%20This%20is%20necessary%20for%20resolver%20usage%20in%20motor%20control%20appls.%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20See%20attached%20Excel%20sheet%20for%20calculation%20of%20parammeters%20used%20here%20(AUX0_clk_DIV0%2C%3C%2FP%3E%3CP%3E*%20AUX0_clk_DIV1%2C%20SGEN_IOFREQ%2C%20PWM_PRESCALER%2C%20PWM_MODULO).%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20This%20example%20is%20set%20for%202.44140625%20kHz%20SGEN%2FPWM%20frequency.%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20Test%20HW%3A%26nbsp%3B%20MPC57xx%3C%2FP%3E%3CP%3E*%20Maskset%3A%26nbsp%3B%201N65H%3C%2FP%3E%3CP%3E*%20Target%20%3A%26nbsp%3B%20internal_FLASH%3C%2FP%3E%3CP%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20200%20MHz%20PLL%20with%2040%20MHz%20crystal%20reference%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20EVB%20connection%3A%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20P20.1%20-%20D%5B7%5D%20..%20SGEN%20output%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20connected%20to%20FEC%20PHY's%20MIIMODE%20input%20on%20motherboard%2C%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20to%20see%20full%20amplitude%20remove%20J26%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20P8.12%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%20A%5B11%5D%20..%20FlexPWM%20A%5B0%5D%20output%3C%2FP%3E%3CP%3E*%20P8.11%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%20A%5B10%5D%20..%20FlexPWM%20B%5B0%5D%20output%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1117349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGeneral%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎04-14-2015 04:33 AM
Updated by:
